New to TRS, what mods / tips for a 2020 RR 250
Since yesterday i am a proud owner of a new 2020 TRS RR 250 (coming from a 2017 Montesa 300RR).
Which mods do you advice or tips do you have for this bike?
Thnx in advance
About the only things I'd recommend is to put a tube on the carb overflow (under the float bowl) and if you can be bothered, grease the electrical connections.
I've got a 9t front sprocket which is quite common. Started with a slow throttle but have gone back to standard (but use the wet map mostly).
Seems like apart from CDIs, these bikes don't really need anything.
52 minutes ago, midlife said:
Put oil in petrol :D
Haha, that i will not forget.
Does anyone know who sells / which brands sell bar risers for a 2020 TRS 250RR?
:popcorn:
3 hours ago, lineaway said:
Did you have risers on tne Montesa?
No, but want to try them. But i can not find them on the internet, someone recommended them on this forum. That is why i am asking for more information who sells them / which brands make them.
Edited by Cooter78
2 hours ago, lineaway said:
 Bend your knees instead.
That is not what i am asking for.
If you are going to ride trials - don't bother. I am 6-5 with 38 inch inseam and stock is best.
8 hours ago, baldilocks said:
Jitsie do higher fatbars than standard?
Yes they do. I have the 6 inch version on my 125RR. Not as sexy as Renthal but functional.
