- Past hour
ukbta started following Shed & Buried Beta
I have just picked up a shed Beta Rev 3 in need of some love - but is 'running' - though missing parts like levers, kill switch, and rear brake seems empty of inop. Brave? Mad? Maybe... All I can guarantee is - I may well be asking, many, many questions!😁
- Today
Sbrown started following MONTESA COTA 248 (POSSIBLY FROM 1971)
sproket started following Talking down and Talking down
A lot of you are dickheads, stop talking down to people, if someone posts, stop treating them like a c...
A lot of you are dickheads, stop talking down to people, if someone posts, stop treating them like a ****
gas2222 joined the community
Technical Resources for Electric Motion Trials Bikes
gas2222 replied to konrad's topic in EM (Electric Motion)
Ciao on 9/1/2025 I installed a Kelly KLS7260RM on Electric Motion 5.7 ..... -
Time Left: 27 days and 3 hours
- FOR SALE
- USED
My Sprite 197cc 9e Villiers Classic Trials bike is for sale. Has had a new rod kit, balanced, new piston, rebore, new bushes, bearings, selector, chain, sprockets, selector. 4 Speed. Renthals, Akronts, Did Chain, Electrex World ignition, Mk1 Concentric etc. British Hubs. I bought it a couple of years ago as a replacement for my beloved C15, which is too heavy for me now, as at 82 am 'past it'. Not being a fan of two strokes, as I have now found out...... have hung up my crash hat and boots and retired from Pre 65 ACU competition. The Sprite does have a V5c in my name. If you need any further information on my Sprite, please email me. I definitely won't be competing any more, which is reason for this advert. The Sprite must be ridden first, then you are able to see if it's the right machine for you. It was imported back to the UK in 2010, where it received the age related number plate. Originally when new in 1965 it was exported to Europe in kit form. A genuine Pre65 Classic Sprite English manufactured trials bike. My Sprite was featured in the August edition of the Old Bike Mart.2,500.00 GBP
Cheers John…..Answer your insta massage 😄
Arty joined the community
I used a bum bag for a couple of years but found they wriggle around too much. Last year I used a fender bag and it was nice to have the bike carry tools instead of me. They are a bit limited for room so you’ve got to be ruthless with what you put in them I don’t carry a drink for me but 250ml for the bike instead. The rucksack allows plenty of room for everything you need but it’s easy to go overboard and end up carrying too much weight, Make sure tools are wrapped in a cloth or something and don’t move, otherwise they’ll rub a hole in your back
eddie70 joined the community
kwackerzak started following Scott trial - Rucksack or bum bag
So I’ve signed up for the Scott trial this year, and can’t decide whether to use my camelback rucksack or purchase a bum bag. All I plan on carrying is a drink, energy gels, tyre plugs & tool, few bolts, couple of Allen keys, phone. What are people’s thoughts on comfort/practicality between the 2? Edit - I’ve looked at fender bags, but they don’t offer a way of carrying a drink.
tommybuildsbikes joined the community
Hey man this looks great i’m about to start a project of my own, do you happen to have a photo of the exhaust and airbox as i don’t have one and can’t find any online so hoping to source one similar
honda65 started following 300 One R Intake spacer and cylinder head insert
Hi, I was poking around through the parts manuals and noticed that the 2021 300 One R uses an intake spacer between the reed cage and case. None of the newer 300s of any configuration runs one. It does seem that the 2021 250 and 280 run it as well. I know that use\d to be a trick back in the day to get more bottom end but why remove it? And on the same topic, I also noticed the the head insert for the 21 (&22) One R model is different than the newer ones. However the insert for the 21 & 22 One R is the same for the One RR. The newer One R inserts have new part number and are called low compression So my question is this: has anyone messed around with the reed insert, mainly removing it? And does anyone know if the 21 & 22 insert the same comp as the S3 hi comp one? S3 lists the same hi comp insert for all the 300s except the Gold Did any of that make sense?
Greenland motocross had one and i got the front disc from italy
This link shows the many Lifan engines produced: https://gzbawo.en.made-in-china.com/product-group/lqKanTtOOzcr/LIFAN-engine-1.html Search in your own country, but this is an example from the USA: https://www.amazon.com/CUBELLIN-200CC-250CC-Motor-Engine/dp/B0D81ZTJDH
Hi i dont really know the lifan motor. And the previous owners say its was 200cc. And i hav thinking just get another engine from gasgas 250ccm. If i fine it somewhere 🥴
You are probably not going to find much information about that enduro bike (?) on a trials forum. It appears to currently have a Lifan motor (which is a Chinese copy of the Honda XR100). Lifan built them in a variety of sizes up to about 200cc. You can measure the bore and stroke to determine its displacement. Have you considered that it will cost more to repair that bike than it will be worth?
Unfortunately, it likely seized. Start by draining the coolant and removing the head to inspect the cylinder wall. It's possible to remove the cylinder and piston as a unit without removing the engine from the chassis. Of course, you must first remove the piston pin.
- 1 reply
- 1
Glatisant started following 2016 Explorer starting problems after fuel shortage and Fiat Ducato with bike holder
A converted bike holder (brand Eufab) sitting on the car coupling. Total cost: ~40,- Euro
Hi Folks! My Explorer ran out of fuel on a 10mile road trip at about 45mph. After hearing a strange sound I immediately pulled the clutch and the engine stopped. After refueling I noticed that compression is lower than it was before but still present. I am worried that the piston seized as the engine doesn't start any more. Any ideas what I can look at before I start dismantling the whole engine? Thanks! Felix
Oset 16 36V - In series 18v Batteries or other options
konrad replied to skippydave's topic in OSET Electric Trials Bikes
It's certainly possible, but will require technical knowledge. The best place to learn about building small lithium-ion batteries is a forum devoted to electric bicycles. Lead-acid batteries have an energy density of 30-50 Wh/kg and specific energy of 20-50 Wh/L. Compare this to lithium-ion batteries, which presently have an energy density of 150-200 Wh/kg and specific energy of 250-670 Wh/L. The improvement will be dramatic! -
Talon was super-expensive plus 8 weeks delivery! In the end I found Adam Hodson (oneoffsprox@gmail.com) who made me one for a reasonable price and about 1 week delivery. I rode the bike for about an hour and very pleased with the change; it's taken the fire out of the blue map and made it much more usable (for me!) yet the green map doesn't feel noticeably more sluggish.
Trials is a niche sport so it's unrealistic to think that dealers can hold a stock of everything. Especially something like clothing with the vast number of permutations of style, colour and size. If they can get something in and then dispatch it to you in a few days, I think that's generally fair enough.
skippydave started following Oset 16 36V - In series 18v Batteries or other options
Hi All, Im looking for help for Oset 16 Lithium battery options. In Australia I am having a very difficult time getting my hands on a lithium battery for the Oset16. I have spoken to the Oset importer (under triumph now) and they had no idea what I was talking about which is a little concerning. But I have seen several posts of people wiring 18v drill batteries in series and having great success. I thought I would reach out to this forum and see if anyone can give advice about this being successful or not and what sort of range to expect. I can get more lead acid batteries but I was hoping to get something lithium for extended range so he can at least ride a full trial. Thanks in advance Dave
oddvar started following Gasgas help
oddvar joined the community
Hi im going to rebuild this. Can any won help me to identify what kind this one is? Year? Engine size?
Wully joined the community
Looking for a ty 80 tank if any one can help
