This stream auto-updates
  1. Today
  2. Hi, There is no adjustment on this model of Gas Gas.
  3. sectionone replied to guy53's topic in Gas Gas
    Torrot just went into bankruptcy and they are still 40% owners of Gas Gas. A US dealer is selling brand new bikes for $4000 out the door. Gas Gas has 2027 enduro models so maybe Bajaj will keep the enduro line and hopefully the trials line will return to Spain and be sold to Reiju.
  4. Yesterday
  5. I have made the decision to move from 2t to 4t and will be picking up a new 2025 301rr in a few weeks. I want to follow maintenance protocols closely and in line with that, I would like to mount an hour meter somewhere visible, but not in the way. Hoping for suggestions on which meter and some installation tips.
  6. Manyprojects joined the community
  7. Last week
  8. Hi all. Ok so I have taken the fork tubes apart and didn't take any photos of them. They were seized up so cleaned them up but, trying to put the lower piston back is proving difficult. The circlip needs to go back in to the bottom the stantion but i cant push the piston in far enough for it lock in place..have i got them the wrong way around???
  9. I received the apico dimple plates this week. I have rounded and polished the teeth a little bit. Just because I could. And today I have tried them for the first time. The improvement is huge. Really smooth operation, absolut better control on the clutch. Good update, all together The original plate as it came out Versus the sligthly polished Apico plate The apico teeth, before polishing, looked very similar to the original plates so there is some improvement. I don't know if it makes any difference in operation but it won't hurt either.
  10. smog joined the community
  11. Titanium head bolt. (M14 x 1.50) Next titanium parts are coming ...
  12. Have you tried shifting the pickup coil to retard the ignition? or are they set in position on a GasGas.
  13. Seed joined the community
  14. Salve ho una italjet trial 350 cc326 del 1986 e cerco parafango anteriore e posteriore verde, mascherina e fanalino, sella nera. Sapete dove posso trovarli?
  15. The Mototrial X-Trial Predictions Competition will be kicking off very soon. The opening round will be in Madrid on 28 November and prediction entries will open on 7 November. All you have to do is predict the top 3 plus a wildcard. Get it right and you could be a winner. Join now and be ready to put in your entry. https://mototrial.co.uk/predictions/xtrial/
  16. Once you've got the bike built you'll find Gwent Classic Trials Club put on some good trials near you.
  17. Hi, My 2015 Gas Gas TXT 300 recently started to misbehave. It sometimes starts in reverse. Cold or hot it doesn't matter. It started gradually, first once in awhile, than more often and now half of the kicks end up in revers starting. Beside this, when under load with low rpm, right before stalling, it reverses and sends me backwards downhill. The only reason I can think of is ignition timing, therefore I went straight to the woodroff key which is in perfect condition. Next I checked all the timing components, stator, flywheel, pickup coil, ground wires and grounding points, all good. With the stator removed, I performed an engine seal test, both negative and positive pressure, again all good, cleaned the carb, changed the spark plug with a new one, opened the engine to remove carbon deposits, put everything together but to no avail, it does the same thing. Did anyone ever encountered anything similar before? Can a partially faulty CDI do this? Any ideas? Thanks.
  18. ChrisCH replied to guy53's topic in Gas Gas
    Bajaj have over a billion in revenues. I would have thought they wish to keep the European brands, particularly the GasGas and KTM brands. Have I missed the rumour mill?
  19. Loop joined the community
  20. guy53 replied to guy53's topic in Gas Gas
    Unfortunately as you wrote, no news is is bad news, here in Quebec dealers are selling ay rediculus price. It does not smell good.
  21. faussy replied to guy53's topic in Gas Gas
    AFAIK there's no news. If we hear some in the future, its probably more likely to be bad than good. As long as they keep making bikes and have spares available I dont really care if they dont run a team or develop the bike for the next 5 or so years
  22. Why did you move down from the stock 48?
  23. Im in the UK and run a 45 pilot
  24. I didn't keep check on the hours it took as it was done over a period of spare time I had, I painted the frame and tank/seat unit myself using 2 pack aerosol cans bought from my local bodyshop supplier, I used a plastic primer on the tank/seat unit the brand I used was pro xl
  25. Working on excavators and farm tractors and operating them year round I noticed they are just huge heavy duty versions of a trials bike transmission. I run shorty levers so the clutch engagement changes just with that change, clutch progression is the result of hydraulics. I think ATF is perfect for automatic transmissions, my trials bikes all have one of the most simple standard transmissions and organic friction plate clutch systems ever produced. The ISO 46 works even in sub zero it is considered all-weather. Water swells clutch plates and lowers the burn point of the oil in the clutch. Burning the oil between the friction plates is what causes the carbon glaze that builds up on a cooked wet clutch and that comes from improper combined clutch & throttle control. The ISO or SAE or AGMA measure is the viscosity measure relative to temperature, the rest of what differs is what additives are in the oil to make them suit a particular task. If you had to do a 45 gallon oil change in an excavator or farm tractor at the cost of some small package oils being sold in bike shops, you would go broke real fast.
  26. Did the ISO 46 change the clutch action? I started with the recommended oil but am now running Dexron VI. The Dexron changed the clutch action a bit and I had to adapt my clutch timing. It is difficult to tell but I think it engages later but quicker plus it removed a little drag. It must be a little thinner in the operating temperature range. A more progressive engagement would likely be better for me. I'm wondering if Dex/ Merc would be slightly thicker.
  27. guy53 posted a topic in Gas Gas
    What are the latest news concerning the future of GG trials. Guy
  28. Mr
    lemur replied to JohnAaron's topic in Montesa
    The parts diagram for the 247 Cota shows the assembly order a little better and the forks appear to be similar in construction to the 200.
  29. @rustyrider Wow man I'm really impressed by all the work you've done. You created a one in a world kind of Montesa, I Love it. How many hours did it take ? Did you brought the parts at a painter's to give them this color ? It's awesome If I had such a beautiful bike I wouldn't bring it into the mud for sure !
  30. 5 Montesa 4RT bikes over 20 years I only used ISO 46 hydraulic transmission oil in the transmission/clutch casing, never had a lick of transmission or clutch problems and the oil cost 7$ per oil change, change it frequently because there is no filtration on the transmission, the thing that destroys the oil is water from condensation or pressure washers. ... don't use pressure washers or swamp the bike and your oil will last longer 👍
