- Past hour
Gsinky started following 51 year old newbie
Hi, I’m keen to get started on some gentle trials. I’m in Aberdeenshire and have always fancied it, and realise it’s now or never as I get older. I’m budgeting on circa £1k for a used Beta or Gas Gas. Any buying advice appreciated and any more general advice also welcomed. Hope I’m not too old. I had a Fantic when I was 19 and have been a MTBer over the years, so like to think I’ll at least have some sense of balance and technique, but mainly I just want to have some fun and give it a go. Also any advice on basic kit welcomed. Graham
Gsinky joined the community
- Today
I used the Vauxhall equivalent (same body) to transport my trials bike. Carried it in the centre with front wheel between front seats. Just cinched down front forks to give height clearance.
Yes I did. Are you familiar with the bike.
Glad you're liking trials, it's addictive. Did you buy it through the Tryals Shop?
PAULIE started following Spring Tune up 2018 300 Factory
Got some maintenance and mods done today. Looking forward to seeing how it responds! C-F reeds Head insert from a 300ss to lower the CR from 10.6 to 9.6 Jet block gasket New fuel line, remote air screw knob and swapped out the 10t sprocket for an 11 (hoping gearing up will actually make it less jumpy) and a long S3 head pipe
Joe85 started following New to trials here, Foley Alabama
Hi, I'm a new trials rider. 47 years old. Recently purchased a 2020 vertigo r2 250. Been riding bikes on and off for 35 years. I've been riding it everyday for three weeks now and really loving it.
Joe85 joined the community
12345 joined the community
Is anyone using a Peugeot Bipper to transport a bike? Are they big enough? I'm only transporting one bike.
jurassicjon joined the community
i need to know how to mix fuel screw because i clean carborator and now i cant fix that and motor dont work good ?
Ressurrecting this post. Still need to find the rear brake pedal for this bike. The one I got was incorrect. If anyone has anything, please DM me.
TogM joined the community
Recently acquired a 1963 Cub converted to a TR20 replica complete with 3TA forks. I am a relatively light rider (65kg) and find the suspension very hard and also noisy with the rebound 'slam'. I am toying with the idea of fitting progressive springs (and possibly rebound springs) ?? The legs have casting numbers H1119 and H1120 (possibly suggests sidecar origins ??) with what I believe are a red/white marked 464mm long springs. The units themselves feel smooth and tight so I'm disinclined to dismantle them further. Any experience, advice or suggestions for suitable solutions would be very much appreciated.
mcman56 started following beta evo 300 4t 2009
You can start by cleaning the carburetor and making sure it is seated in the manifold properly. If a 2009 has the hot start button, check for leaks.
- Earlier
Possibly air got into the clutch hydraulics while it was lying down. Alternatively, if you pulled the clutch or pressure plate off, you may have let the clutch pushrod ball fall out and not notice it. I doubt the shift shaft has anything to do with it.
Metchosinjoe started following 06 beta rev 3
Hey first post looking for some guidance on my recently acquired 06 rev 3 had some wiring issues which lead to a not running issue which lead to me kick starting it with a couple loose bolts and cracking the inner clutch cover. replaced the cover got it all together and now have no clutch disengagement. when I pulled the inner cover I pulled the shift shaft out a bit before I noticed. i pushed it back in and seemed fine. Im very mechanically inclined just new to trials bikes does the shift shaft go into the slave and did I make a boo boo and pop the slave out?
Metchosinjoe joined the community
Hi again, just had a look for a few pics to jog my memory (Google, not pics of mine I don’t seem to have any 🤷♂️). Clearly my memories are clouded as all the pics of the MH version show a red frame, and I must be getting single down tube frame mixed up with something else, maybe mates cota 250. Also with the tank, I thought I remembered a slightly textured finish plastic tank on the MH but again all pics show otherwise, a very shiny red tank which could be fibreglass, mine definitely was fibreglass but white. On the slightly older models, the rear lower edges of the tank unit below the seat, had a ‘flaired’ shape over/around the rear shock top bolt ( presumably for comfort against the leg/boot) but the later ones seem to be trimmed along as a straight edge. In my own experience those ‘flairs’ cracked & crumbled so ended up being trimmed off & I expect many others were too. Any way good luck with your project, I hope you find the detailed information you’re looking for, and that my vague & sometimes inaccurate memory helped in some small way. I always thought it was a great little bike, despite its utterly rubbish brakes in water🤣. It didn’t seem to matter what cables or shoes or mods thereto, as soon as they got near water they were useless for the rest of the trial. Wheels out first job after every wet event ! Oh great days eh!
lil started following beta evo 300 4t 2009
I have a problem with the carburetor on my beta evo 300 4t 2009 mikuini bsr se 33-79 I can't combine the gasoline and air The engine stalls at low speed Can you tell me how to fix it
New seals and bushing, disassembling the lower fork legs, sand blasting casted parts, new stickers ... New bearings, polishing the hub, new spokes & nuts. Ultrasonic cleaning disc and screws. Coming soon : new steering bearings.
thanks for your reply, a picture is now emerging as apart from the rivetted plate headed as montesa/honda mh200 and also the stamped numbers on headstock bearing the same montesa/honda numbering starting with MH200 its looking like the bike is a mh200, my bike has gold akront rims and with half width hubs and when i purchased the bike it had a black frame which i assumed was incorrectly painted by some previous owner, i have since painted it red but didnt find any evidence of it having previously been red unless it was blasted or dipped however as the rivetted plate shows no signs of being disturbed this is unlikely, i have stripped the tank to the gelcoat and its never been red so looks like i have a mh200 with a cota 200 tank, as my engine has same last three digits as the frame number i assume its got its original engine,
Scrub that, I just found some on FleaBay 🙂
GavinH started following 2013 Beta EVO rear caliper seals
I got the bike out yesterday after not using it at all last year and it was generally fine but the rear brake was binding a bit so I decided to overhaul it and replace the seals. It appears that Beta only do a kit which includes new pistons, which I don't need - has anyone found an aftermarket supplier for the seals only?
Apologies once more looking at the schematic I've figured it out
My apologies Yamaha ty175
Hello there, have you also considered the possibility of model ref Cota 200 ‘C’. Back in ‘85 I bought an (alleged) ‘83 model which carried the 200C decals on the white tank unit just under the seat area. It wasn’t road reg’d but I think I had a dealer sales receipt from a previous owner listing it as 1983 200C. That was around the transition time from montesa to Honda. Unfortunately it was stolen a year or two later & I didn’t have any record of numbers but 29M sounds familiar (and isn’t far from 29H when reading through layers of paint). Mine had white fibreglass tank (I believe the MH models all had red plastic tanks with a large MH logo running along the side), red frame with single down tube to a curved split cradle under the engine with a pretty poor thin pressed bash plate. The rims were gold (akront branded ?) with black hubs and particularly notable was half width front hub where the earlier ones seemed to have smaller diameter full width hubs. If I remember rightly, when the MH models came out (84/85 ?) they were the same as the ‘C’ except for colour scheme & plastic tank, red tank, black frame. I don’t remember any riveted vin plate, steering lock was just a kind of tube welded to the headstock, holding the lock inside with a thin metal pivoting cover over it. Appreciate there’s nothing definitive in that just (pretty vague) memories but it might jog someone else’s memory. cheers
Andy, which bike are you asking about?
