shercoman2k8 Posted February 23, 2009 Share Posted February 23, 2009 Well, as the title really, I've been wondering about workshop necessities... What do I need? Fed up of borrowing the old mans tools... what do I need in the way of tools, oils, lubricants, nuts, bolts, washers and anything else? I know the important stuff but I'm interested to what you all reccomend? Please give a quality make/brand but good value, dont want them breaking or not doing there job properly, so yeah, shoot away people... Cheers in advance, Jamie Quote Link to comment Share on other sites More sharing options...
copemech Posted February 23, 2009 Share Posted February 23, 2009 Do they sell Sears/ Craftsman tools there? Quote Link to comment Share on other sites More sharing options...
nzralphy Posted February 23, 2009 Share Posted February 23, 2009 You'll need a calender with bikes or girls on it. Quote Link to comment Share on other sites More sharing options...
scorpa4banger Posted February 23, 2009 Share Posted February 23, 2009 (edited) Thats easy 1 Bench 1 Vice ( Record ) 1 set of shelves with sign " No Bloody Gardening Equipment " 1 Fridge with beer inside 1 radio 1 fan or heater depending where you live 1 calendar 1 12 " shifter 1 8 " shifter 1 set of spanners 1 set of allen keys 1 pair of pliers 1 set of circlip pliers 1 pair of needle nose pliers 1 wire brush 1 pair of multi grips 2 sizes of vice grips 1 rubber mallet 1 set of screwdrivers 1 1/2 " socket set with plug sockets 1 set of watch maker screw drivers 1 roll of fine emery tape 10 sheets of 1000 grit wet n dry 1 oil pan 1 20 ltr container with lid to put excess oil into ( Take it to tip to recycle when full ) make a list of the bolts your most likely to take out on your bike and get a box and fill it with a few of each 1 tube of waterproof grease 1 tube of nickel anti seize 1 tube of copper grease 1 tube of rubber grease 1 tube of thread locker 10 cans of wd 40 10 cans of degreaser 10 ltrs of kerosene 10 ltrs of white spirit 5 cans of disc break cleaner ( nulon or motul one is okay depending on your budget ) 2 cans of plastic protector and some smelly stuff to make your bike smell nice 20kg pack of rags and a mans size bin 1 fixed bike stand some good lights in your garage industrial pack of ear plugs so you cant hear your misses telling you to come inside think that just about covers it ! Edited February 23, 2009 by Scorpa4banger Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted February 23, 2009 Author Share Posted February 23, 2009 Very similar to my thoughts....... Better get saving then Anybody got anything to add? Quote Link to comment Share on other sites More sharing options...
scorpa4banger Posted February 23, 2009 Share Posted February 23, 2009 just remember you don't need the best quality tools all the time if you get a good socket set and some good spanners that wont rust with a couple of good shifters you cant go wrong you can also save a lot of trouble just by washing your bike with the proper bike wash and blow it off with a compressor I guess the more you do to keep it out of the garage the less money you need to spend on tools to fix it .. Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted February 23, 2009 Share Posted February 23, 2009 Excellent list there Scorpa4, the piece of equipment that I find the most handy is a small compressor with a tyre inflator, an impact gun and a trigger nozzle. It's also suprising how often I use my small mig welder and an angle grinder. Not really for repairing the bike, but for making or adapting tools or jigs. Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 23, 2009 Share Posted February 23, 2009 (edited) Drill Bits Mains Drill Defiantly a compressor (Machine mart) Taps & dies No 2 Thor hammer (leather & copper ends) Copper slip Edited February 23, 2009 by B40RT Quote Link to comment Share on other sites More sharing options...
the_e1_bandit Posted February 23, 2009 Share Posted February 23, 2009 Can anyone recommend a small compressor? How much do you need to spend to get one that is suitable? I dont want to get one then realise its not up to the job. Thanks Tom PS Im in the UK Quote Link to comment Share on other sites More sharing options...
dan williams Posted February 23, 2009 Share Posted February 23, 2009 Dremel tool. Indispensable Big fire extinguisher. You won't need it until you NEED it. Set of combination wrenches. i.e. box on one side open end on other. Add extras of the most used like 10mm, 13mm, and 17mm Set of T-handle allen wrenches. Set of angle allen keys Set of 3/8 in sockets. Add deep sockets for most used sizes. Two 3/8 inch fine tooth ratchets. 1/2 inch ratchet. Set of 3/8 inch ratchet extensions. Phillips head socket. Annoying but useful. Angle/swivel socket thingy. Can't remember what it's called. Screwdriver set. Hammer. Tire plug kit. 3/8 and 1/2 inch breaker bar. 1/2 inch sockets for big nuts on bike. Axle, steering stem... Did I mention fire extinguisher? Quote Link to comment Share on other sites More sharing options...
johnnyboxer Posted February 23, 2009 Share Posted February 23, 2009 Can anyone recommend a small compressor? How much do you need to spend to get one that is suitable? I dont want to get one then realise its not up to the job.Thanks Tom PS Im in the UK Just bought a good little unit from Aldi Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted February 23, 2009 Author Share Posted February 23, 2009 Ive got a wolf-air compressor, really good quality and will last for ages if you bleed the tank of moisture every week or two! Had my own for about 5 years and never had problems... Cant find the same model now but if you search around you should be able to find one, aim for a max pressure of around 130-150 psi, plenty enough for the bikes! Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 23, 2009 Share Posted February 23, 2009 Can anyone recommend a small compressor? How much do you need to spend to get one that is suitable? I dont want to get one then realise its not up to the job.Thanks Tom PS Im in the UK 8cfm 25litre tank, approx Quote Link to comment Share on other sites More sharing options...
mcman56 Posted February 23, 2009 Share Posted February 23, 2009 Interesting post but can some translate "shifter" into American? Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 23, 2009 Share Posted February 23, 2009 (edited) Interesting post but can some translate "shifter" into American? Adjustable spanner. http://www.machinemart.co.uk/shop/search/f...spanners/page/1 Edited February 23, 2009 by B40RT Quote Link to comment Share on other sites More sharing options...
