Remembered mine was connected to fuel line from tank to carb, explains simultaneous use from both tanks. Sorry for confusion. Have you removed the check valve from the bikes petrol tank breather?
Pipe that reaches to the bottom of the auxiliary tank connects to main tank breather. The petrol is drawn from both tanks at the same time, when your auxiliary tank has lost a litre so will the main tank.
I've used Dampire silica bags for years, others available and I think the horsey people use similar for their boots. Leave them in you boots over the week, then hang them out to dry in the airing cupboard when going to a trial. Boots don't dry completely in a week but are still plyable enough to put on.
Turn off petrol and drain carburettor or run the engine till it uses up the petrol in the carburettor. It may lose oil from the gearbox breather too depending on which bike. Try leaving it on its side in the garage a few hours and see what comes out.
North East England seems to get an increase in rider entries in winter over similar courses in the summer. I guess people have less to do or go to in winter.
Regarding the sticking clutch. After riding my bike it was parked in the garage and the clutch lever tied back onto the bars with a rubber band (slice of old inner tube). No more sticking.
Compare it with the other new seals and swap into one of the other cylinders to see if the problem moves to that one. Do the seals have a tapered cross section, if so, is it fitted correctly. Is the piston correct. On assembly use brake fluid or specific rubber grease as lubrication. The above presumes the caliper is disconnected from the system, if not, open the bleed valve or remove the reservoir cap to allow fluid to return/escape, otherwise you'll be fighting back pressure.
Any suspicion of a defect and the gearbox needs inspection via engine removal/stripdown. They are a bit fragile, but ignore warning signs at your expense.
I'd be happy if they'd kicked those rocks away before my turn.
At one of the world rounds held near Penrith a few years back, same thing was going on, dry rocks and riders/helpers were pouring water on. How does it help?
Here's a quick thought without any depth. A front wheel rotation sensor, similar to ABS, connected to a transponder, signals the observer with flashing lights and sirens.
Busto and Fajardo to Gas Gas
in World Championship Chat
I've been tempted by an offer of a meal deal at Greggs
