From my limited experience the trick is to keep it rolling where possible (so not shut off so much as a 2T) in muddy sections and keep it smooth.
Definitely on earlier models. Practiced a tight downhill turn across a camber and back up again with a friend on a beta - he could almost stop then rev and go after the camber - 300rr would just break traction doing it this way. If I kept it rolling - maybe accelerating before I got to the camber rather than on it or after it I could clean it equally as well.
doing same section on 301 I find I can get a lot closer to the 2t technique and a combination of the old 4rt technique and the 2t technique seems to make it easier to clean than either a 4rt or a 2t
4rts are certainly an acquired taste and grip on certain terrain can be a challenge but then on rocks and streams etc they are well planted and can flatter abilities. What you ride and what you like all come into the equation. Honda build quality are a bonus but as they say you pays your money ??
Along with the piston / ring set changing in 2017, the cylinder and left center case also changed. I don't know exactly why each changed. But I'd want to find out what was changed in the cylinder before using a 2017 piston / ring set in a 2016 cylinder. It could be related to side cutouts on the bottom of cylinder, and the oil ring being lower on the 3-ring piston. And if the new cylinder is needed for the new piston, is the new left center case needed for the new cylinder?
Part Numbers 2016 --> 2017 --> 2018
Piston: 13101-NN4-L60 --> 13101-NN4-M60 --> Same
Ring Set: 13011-NN4-L60 --> 13011-NN4-M60 --> 13011-NN4-N60
Cylinder: 12100-NN4-L60 --> 12100-NN4-M60 --> Same
Left Center Case: 11200-NN4-L60 --> 11200-NN4-M60 --> Same
didn't realise rings change 2017 to 2018 - interesting
301 is softer and smoother at the bottom end . The reduced engine braking makes front feel lighter and push out less on turns - I think.
think a bit more poke mid range but nothing scary .
i have started using the soft map rather than big map I used on 300. It’s been muddy and felt the rear braking traction more on the big map but may just be conditions or x11 tyre not my normal x light.
On a long rocky stream the reduced engine braking seem to help the bike float over the rocks better and was able to clean one of my harder practice sections 2nd go on the 301. I can try the same on the 300 and not clean from one practice visit to the next
The swap from 260 to 300 was noticeable. Swap from 300 to 301 is less it just feels smoother and better - defiantly enough to warrant the upgrade.
Everything just works very well as a package - only had 4 rides on it but loving it
2016 fuel pump change onwards I think was more a standardisation with maybe non montesa models - up to 15 is the same pump as on your earlier bikes.
260 less braking than the 250 and is noticeable , 301 is even less and think same mon the 2020 260’s but not ridden one.
i had a std 260 2015 and put an ohlins on the back and s3 pipe and was top bike - and still cheaper than a repsol. Would put the s3 pipe on repsol either way.
Put the bike to std to sell and sold bits for what I paid so win/ win/winner ???
think western centre ACU will be your area if you google that they have web site.
also go on ACU web site as all trials Uk trials are listed.
if you don’t mind travelling and want some good value coaching then google trials training Wales - Think western centre have tracing but maybe only kids?
Has anyone tried stainless steel bearings? The 6004 rubber seal bearing is very cheap (I can see them online for less than £2) and the stainless is not too bad (£7.50)
We sell trailer wheel bearings and for boat trailers they only last a year or so as they are routinely dipped in seawater. The stainless versions last a fair bit longer as they don't have the same corrosion issues. As jimmyl says it is not a big job to do so really a non issue, but I am lazy - if the stainless lasted twice as long that means only half the faffing about.
PS I can see the ceramic for a bit more (£12) - might be a better option still?
If a cheap one last 6 months at £2 then a ceramic would have to last 3 years to break even
Think ill stick with the cheap and cheerful approach -my wheels are out every weekend so no hardship to swap bearing at the same time.
I do have 3 set of wheels and bearing swap intervals probably is not the same for each set - My best wheels - bearing always nearly new and would swap with slight play appearing , Normal competition wheels -used for local trials so would allow a bit of play before deciding to change, practice wheels - when the tires rub on the swinging arm or fork leg then will change ?? well maybe not that bad
Buy in bulk for a few pounds each - always keep a 2 or 3 sets of new ones at all times and when they feel too rough or I have some bigger events coming up I swap them out.
10 min job - less than a tenner - no stress on the grey matter ??
Have a search though past posts as there have been lots of good advice posted.
Ie
Lay bike on its side to do filter after draining oil
The oil filter will come out despite what you think, the new one fits easy -put some grease on the spring. - Makes sure the oil filter retaining spigot is seated 100% square or flywheel cover wont go back on the dowels.
grease the gasket and will last numerous changes without needing to be replaced
Put the oil back in before putting casing back on.
Valve clearances hardly ever need adjusting.
Clean Throttle body every 12 months - remove and wipe and clean out idle drilling.
Found IRC gripped well when you got them spinning but find the xlite very consistent on all conditions on the 4rt on steady sections and a good degree of throttle control.
x lite my choice of tyre having ridden. Itc an std mich
yes 1 min 30 seconds but setion length at btc less than wtc. again i hope that someone can take an overview and look at time factor vs, section length and severity and make sure it works as it should.
FYI- Brian Higgins is the series coordinator and visited all the rounds this year prior to the events and was very much hands on and helped on the weekend of the event. As I believe he will be doing the same in 2020 and working with clubs and C of C to get consistency of severity and length of section correct. I'm thinking the idea is to keep the more flowing no stop style sections but take away the debate of did they pause for a micro second or not. It will be more are you out in time and did you put a foot down of fall off. Riders will have to re learn the skill of balancing and maybe saving a one and then rushing the section or maybe gamble a dab and makes sure of the rest of the sections. Maybe the 90 seconds allows too much static time and the trial becomes a bit to much stop start.
I guess time will tell but but at least it will be different.
There are some very good deals on std 260 4rts . The bike is basically the same from 16 on. You get Honda build quality and the option to upgrade some parts later on if you feel the need - rear shock and an s3 front pipe are good additions - the pipe more than shocker for the more clubman rider .
all 4rts ride similar - the 300rr better and 301 better again but you pay for the improvement
if you ride a more traditional style then 4rt suits - if you are a rev and dump the clutch then maybe not so.
either way the smile factor of a 4rt on a bit of a blast is unique??
Gearing down I think spoils the 4rt best points in that it’s gear are long- first gear is amazing on std gearing- you can clean things in first that beta fixers are doing in 3rd.
i think the trick on a 4rt is to use the higher tick over to your advantage. Maybe on a t2 you blip throttle and slip clutch against each other - modulatting both On the mont you set the throttle steady and modulate the clutch against it . This seems to help smooth out the torque spikes and minimise engine braking .
if you blip the throttle you get a kind of learner driver kangaroo juice effect in miniature
I think the Montesa has 2 quirks - they like to ridden quiet forcefully - also they do not respond to the 2 stroke rev/dump the clutch and burn technique.
If you ride maybe a lower gear quite forcefully with weight maybe slight rearwards compared to a 2t the bike will reward you , Once hooked up and in a straight line or before a step/bank you need to get the revs on the ride on the over run - ala Toni Bou.
The bike also has lots of low down torque which will allow you to get grip on tick over in low gears - but you have to believe and hang on with good throttle control - I think beginners/lesser riders maybe less fit riders can struggle with this concept and hence why people think they don' grip.
Also they grip in higher gears in deep mud but the revs need to be built up steadily with a constant slip of the clutch and then once gripping the throttle can be buried and get ready for orbit
Why don't they JUST grip?
in Montesa
