johnny_rotten_dab Posted December 14, 2006 Report Share Posted December 14, 2006 (edited) Edited December 16, 2020 by johnny_rotten_dab Link to comment Share on other sites More sharing options...
scorpa3 Posted December 14, 2006 Report Share Posted December 14, 2006 (edited) I must say it has become a habit to start the engine and push away beofre selecting gear. On every trials bike I've ever had there is a certain amount of initial clutch stick when cold. Edited December 15, 2006 by scorpa3 Link to comment Share on other sites More sharing options...
fantic156 Posted December 14, 2006 Report Share Posted December 14, 2006 (edited) Use the recommended Elf HTX740 it works! The clutch on our bikes releases straight away when cold, even the old Fantic. There was some going cheap on ebay, it's in the old style metal tins rather than the new smart plastic but it's is a lot cheaper than normal. Edited December 14, 2006 by fantic156 Link to comment Share on other sites More sharing options...
Guest DGShannon Posted December 14, 2006 Report Share Posted December 14, 2006 I must say it has become a habit to start the [bike] and push away before selecting gear. Funny you say that! I have owned 3 different Cota 315's, one which had a Sureflex clutch kit, and they would all stick when cold. Pushing off before selecting a gear became such a habit, I still tend to do it to this day, even though my Scorpa SY250F doesn't stick. Old habits die hard... Link to comment Share on other sites More sharing options...
neils on wheels Posted December 15, 2006 Report Share Posted December 15, 2006 When warming the engine try & get it into a high gear as soon as possible. You can either push off in neutral then quickly knock it up into 4th, or if you've got a stand to warm it up on you can get it in gear with the wheel spinning off the ground. I tend to find that again, by the time you've got up to 4th even with the wheel driving in mid air it will free the clutch up. I've adopted this practice on my current Sherco & my old Beta Techno & it seems to work, but I've never ridden often enough to always find a free clutch when I get on the bike. Link to comment Share on other sites More sharing options...
motojojo Posted December 15, 2006 Report Share Posted December 15, 2006 I don't know about the Montesa but I used ATF for years in the old GasGas bikes but you do need to change fluid more often, my Fantic 305 had to have a good 30 weight oil. If they recommend a certain type always use that first. Most bikes need to be warmed up put your hand on the exhaust and when it puts out warm air you can go play. Link to comment Share on other sites More sharing options...
sirhc Posted December 15, 2006 Report Share Posted December 15, 2006 fantic156 Posted Today, 02:06 PM Use the recommended Elf HTX740 it works! :agree: Just use the recommended oil Link to comment Share on other sites More sharing options...
john.b Posted December 15, 2006 Report Share Posted December 15, 2006 Before starting your bike put it into top gear, pull in the clutch and rock the bike backwards and forwards. Initially it will feel like it is stuck in gear however after a few rocks it will free itself and then freewheel. After this put the bike back in to neutral and then try starting it. Being doing this trick for years and usually works. If the bike has been stood in the garage for a few weeks I usually let the bike warm up as well before putting in to gear. Link to comment Share on other sites More sharing options...
gimpy Posted December 15, 2006 Report Share Posted December 15, 2006 Using Elf HTX 740 is the answer. On the Gasgas 250 Pro 03 I always put an 'O' ring on the clutch lever to keep the clutch disengaged when bike is not used for long periods. This works. But clutch on Monty always clears from cold with the Elf oil. Link to comment Share on other sites More sharing options...
mad4it Posted December 15, 2006 Report Share Posted December 15, 2006 Yes trick to free of clutch with bike in second or third pull in clutch and rock it backwards free's off stuck plates a treat! Link to comment Share on other sites More sharing options...
dixie Posted December 15, 2006 Report Share Posted December 15, 2006 never had a trialer that would fully dissengage the clutch when cold,no matter who made it. the only problem with some of the recomended oils is price,i know we should not gripe about a couple of quid ,but the recomended 4rt oil is well over twice the price of the oil i use.and this stuff aint cheap. just remember never to point you bike at anything when it first goes into gear, i put a big black wheelspin on a parquet floor in our dinning room a few years back,thought it would be funny to put a new trialer under the christmas tree,then when i had a few beers thought it would be even funnier to ride it in the house. bad move. and would you believe it the missus band me from indoor trials!!!!!!!!!! Link to comment Share on other sites More sharing options...
phb Posted December 15, 2006 Report Share Posted December 15, 2006 always had the same problem with my beta but now put a small strap around clutch lever and pull onto bar grip and leave like this while stored never had problem since Link to comment Share on other sites More sharing options...
goose Posted December 15, 2006 Report Share Posted December 15, 2006 rocking it in gear before you start is the trick. done it with all my bikes for years. just habit now. stops the risk of ripping off teeth in the gearbox. Link to comment Share on other sites More sharing options...
seandellear Posted December 15, 2006 Report Share Posted December 15, 2006 Cheers for the tip on the elf oil on ebay just bought a couple of tins will keep us goin for a while!lol Link to comment Share on other sites More sharing options...
leggins Posted December 15, 2006 Report Share Posted December 15, 2006 I have that clutch problem on my rev 3. A mate told me to start the bike and then tie the clutch lever in while i get my gear on , works everytime cheers leggins Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
