September 6, 200719 yr Author Done plenty of tyres Cope, always use tyre soap and get it seated correct, two pops at 50-60 pound. Been a fair while since Ive had a leaky rim/spokes though, saying that it was very slight,had a few mins spare so tried the silicone whilst the tyre was off and its worked,but for how long is anyones quess.
September 6, 200719 yr Thats 10 pages but should we kill this one as none of us are sherco virgins........ ?
September 6, 200719 yr Author Baldilocks, I still count myself as a Sherco Virgin untill I buy another one, not lost me cherry on this one yet i recon so might be a few pages to go yet. Getting well used to the bike now and feel comfy on it like I did the Beta, know when shes going to grip or not and where the best power is to ride. Great day today with Dad, spent 42 hours on a small grassy bank ten foot square with a root on it Dad still managed to make the section 455 metres long though The Iridium plug made no real difference to the running of the bike but totally cured the hot starting problem?? not sure how but its gone now......................oh and the tyre stayed up all day Legend........................haha yer we do ,dont we Edited September 6, 200719 yr by The Addict
September 7, 200719 yr I have been a bit standoffish on the irridium plug as it is a resistor type, and stuck with the platinum. Did you run the preset gap at .027-.028?(0.7mm) Should give a bit fresher response off the bottom as well, barely detectable though. The prime benefit is the fact the electrodes are more open and exposed for better ignition and such. How the heck do you eat up that many rear brake pads? I have never replaced ANY! Of course I don't really use it much either. Current project on the list is the bronze oilite bearing to replace that little s-i-t-y roller thing on the rear pedal that makes it loose and corrodes badly. Will update on this later.
September 7, 200719 yr Author Ran the plug with standard gap Cope, might see what happens with your spec on it though be interested in your bearing mod as well when ready . Must be a Galfer fault with the rear brake? or I must be dragging the bugger whilst riding? cant understand why the pads wear out so quick????? along with grips/fuel/2 stroke oil/ATF/air filter oil and wages
September 7, 200719 yr I put new Goldfren pads in the sherco front and back before ssdt. Back ones got changed on the Saturday night at Reeth 3 day, front ones are still in. Suggest you are riding with it on or you have damaged the disc ? terrain makes a difference though its mainly rocky streams where I ride so dont use it much.
September 7, 200719 yr Author Lots of hills here Baldilocks and major use of the back brake most of the time, first set to be honest were ***** so didnt have them in long so its really only 2 sets in three months not the three. Forgot about the Goldfren pads you said a while back though, do they stop the squealing on the front brake? Im not too bothered but its getting on some of lads tits fairish, Edited September 7, 200719 yr by The Addict
September 7, 200719 yr They dont squeal too bad, I was out today and dont recall them squealing at all but maybe i've just learnt to blank it out !
September 8, 200719 yr its not the pad type you are useing its probably more to do with the 8 hour practice every thursday + numerous eves on the sleepers + all those sneaky practice sestions in the week with caber and the goat + the trial and a practice every sunday !!!!!!!!!!!
September 9, 200719 yr Plug was probably perset to that spec as the platinums are. The resistor adds another electrical obsticle to an already weak(at low revs) output system and that is why i have some reservations running that gap on it. If you have to go back to the .6mm gap to run reliably, you have lost some benifit of the application to begin with. Installed the bronze bearing for the rear pedal and works perfectly! Very tight, smooth pedal actuation now. Will try to get more ride time on it tomorrow!
September 10, 200718 yr Well, a bit of riding today with the new bronze bearing installed. All I can say a this point is that it seems to work REALLY well! If anything it may be TOO sensitive, as there is no longer lost motion in the wobbly pedal! Might take some getting used to after a number of years of the wobbler! May give it a bit more free play, yet there seems to be no more friction in the action than in the litle rollers. You could lock it down with one finger, just like the front! Edited September 11, 200718 yr by copemech
September 11, 200718 yr Even after polishing , you can still see the chitting marks where the little rollers on the standard bearing "dig in" to the bushing or "spacer" as it is called out in the parts book. This one is certainly reusable, it is relatively new, but I have seen a few that were much worse. The little rollers in the bearing itself simply do not have sufficient load bearing surface area to do the job without distorting the opposing surface.
