kingfisher Posted January 25, 2008 Share Posted January 25, 2008 Can anyone help i am going to but a set of Boyesen Reeds in; but have looked up the Boyesen Web site and no Sherco listed, i was told by a mate that the reeds that fit a KTM65 will fit is this true, or can anyone tell me what the part number for Sherco one's Quote Link to comment Share on other sites More sharing options...
copemech Posted January 25, 2008 Share Posted January 25, 2008 (edited) Or #665? Yea, thats it! Edited January 25, 2008 by copemech Quote Link to comment Share on other sites More sharing options...
mcman56 Posted January 25, 2008 Share Posted January 25, 2008 Yes..#665 and they do fit the KTM 65. Quote Link to comment Share on other sites More sharing options...
ham2 Posted January 26, 2008 Share Posted January 26, 2008 Or #665?Yea, thats it! Gospel.... Quote Link to comment Share on other sites More sharing options...
baldilocks Posted January 26, 2008 Share Posted January 26, 2008 You can get them off motomerlin on ebay, thats where I got mine, they arrived within two days so I recommend them as a supplier. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted February 12, 2008 Share Posted February 12, 2008 Does adding boyesen reeds to a sherco actually make any difference ? Quote Link to comment Share on other sites More sharing options...
copemech Posted February 13, 2008 Share Posted February 13, 2008 (edited) It smoothes the power a bit by lowering the pressure in your wallet! They are very gentle (on the wallet) off the bottom and still have a good bit of hit in the mid while sharpening up the top end!(which I seldom use!) Edited February 13, 2008 by copemech Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted February 13, 2008 Share Posted February 13, 2008 Does adding boyesen reeds to a sherco actually make any difference ? They do make a difference Quote Link to comment Share on other sites More sharing options...
neo Posted February 13, 2008 Share Posted February 13, 2008 Has anyone checked out this company? http://www.carbontech.com/motor/ktm.html You might note that they have a reed specific to "Low to Midrange" ...the 113LT And the wallet stuff might be better too Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
ham2 Posted February 13, 2008 Share Posted February 13, 2008 Does adding boyesen reeds to a sherco actually make any difference ? Yes,even I can notice a difference.....smoothes the bottom end out but (novices like me, beware)revs out freely at the top-end! Quote Link to comment Share on other sites More sharing options...
copemech Posted February 14, 2008 Share Posted February 14, 2008 It seems carbon reeds are a bit stiffer than fiberglass like the Boyesens, much as the factory reeds. This makes them a bit more "rippy" off the bottom, and may be touted as increasing low end power. As everything is a trade off in two stroke tuning, the ones like the Boyesens which are capable of giving more on top, actually seem to have a bit of the opposite effect on the lower revs which gives a smoothing effect, at least up to a point! Seems quite a few have come to appreciate this when trying to tame a 2.9 for the average clubman. I ran them in my "05 2.5 as well and it was really sweet! The hot setup! Quote Link to comment Share on other sites More sharing options...
hrc1 Posted February 14, 2008 Share Posted February 14, 2008 I've tried em all - stifffest were some Jordi Clerch reeds. Tried in a beta 250. Flattened power so much it was like a weedy 200! Boyesens are the only dual stage reed, so good at low rvs & high revs too. Quote Link to comment Share on other sites More sharing options...
neo Posted February 14, 2008 Share Posted February 14, 2008 Boyesens are the only dual stage reed, so good at low rvs & high revs too. Thanks hrc1, You've just highlighted something I been overlooking Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
borus Posted February 14, 2008 Share Posted February 14, 2008 Thanks hrc1,You've just highlighted something I been overlooking Best of balance. Neo hi, been lurking for a while, has anyone tried the "pro series" boyesen reed, the part number is #pro112 which is the equivilant to the power reed #665. It a bit more money... I copied below the comparison from the boyesen web page: Q: What advantage do Pro Series Reeds have over Power Reeds? A: Pro Series dual-stage reeds combine a carbon-fiber top reed with a fiberglass bottom reed for unrivaled performance. The Pro Series Reeds are more responsive than our traditional Power Reeds. The carbon-fiber top reed has excellent response characteristics that provide even quicker acceleration, stronger throttle response, and more over-rev than our standard Power Reeds. The fiberglass bottom reed provides stability and longer reed life. PERFORMANCE Pro Series Reeds are designed with the racer and avid enthusiast in mind. They offer you the latest in carbon reed technology with all the advantages of Boyesen Quote Link to comment Share on other sites More sharing options...
