May 12, 201016 yr I've been reading through a lot of the posts in the Scorpa specific area, There seems to be a bit of difference in opinion about what mixture to run the bike on ! I would assume this would depend on what octane of fuel and type of 2 stroke oil used (full/semi synthetic) I tend to use 97/99 Ron fuel and mostly Ipone fully synthetic oil !! Bike is an 08 SY250 Can someone clear up how much oil i shoud be adding ( in ml ) to 5 litres of fuel ???? Thanks in advance
May 12, 201016 yr Old mixture post I provided a handy chart a few years back on the above link. Post No 8
May 12, 201016 yr I've had my SY250 five years from new and always used 80mls of synthetic oil to every five litres of fuel. It's worked ok so far.
May 12, 201016 yr I've always run my bike on 80 to 1, 5000ml of petrol divded by 80 = 62.5ml so 63ml for arguments sake. Some people run 100 to 1 or 70 to 1, 5000/100 = 50ml 5000/70 = 71ml I've run 80 to 1 with BP Ultimate 96 Ron or Shell Optimax 98 Ron.
May 12, 201016 yr When I got mine Munk the bloke told me 80 - 1 on fully, I've kept it at that Also check this topic out http://www.trialscentral.com/forums/index....showtopic=17883
May 13, 201016 yr Author don't suppose you want to sell it???? Yeah - send me a PM Spike - i'll email you some pics you can make me an offer !! I'm looking for an 09 4 banger or a 2010 smoker !!
May 13, 201016 yr Author When I got mine Munk the bloke told me 80 - 1 on fully, I've kept it at that Also check this topic out http://www.trialscentral.com/forums/index....showtopic=17883 80:1 means your adding 62.5 ml (or as near as) to 5 litres of fuel ?? According to bigfoots handy chart i'm running 60:1 adding 80ml per 5 litres .................
May 13, 201016 yr I always use 75ml of motul 710 to 5l, too much oil will clog up your exhaust, you could run less than 75ml too with no bad affects. I was told not to use Ipone in my SY by a respected french trials bike importer, I'm not sure why tho. Edited May 13, 201016 yr by godzilla
May 13, 201016 yr 80:1 means your adding 62.5 ml (or as near as) to 5 litres of fuel ?? yep, but I just go with 50ml oil to 4 litres, don't ask why, I just do probably easier to pour 50ml than 62.5
May 13, 201016 yr Ok guys.....once and for all.... in your opinion(s).... which is the best 2 stroke oil and whats the best mixture?????? For a 09 250 sy. Thanks.
