the_k Posted September 6, 2010 Report Share Posted September 6, 2010 What length levers do people recommend using? Also what brand of levers do you like? For the short time I have had the trials bike I have found I am comfortable using mainly just one or two finger on the controls depending on what I'm doing. Link to comment Share on other sites More sharing options...
trialsrfun Posted September 6, 2010 Report Share Posted September 6, 2010 I have tried both short & long lever blades on my bikes, peresonally I prefer the longer type. Link to comment Share on other sites More sharing options...
godzilla Posted September 6, 2010 Report Share Posted September 6, 2010 I like short forged ones. Link to comment Share on other sites More sharing options...
dabtastic Posted September 6, 2010 Report Share Posted September 6, 2010 I like the Apico forged ones because the bend instead of snapping, so you can justst put then in a vice and bend them back. Link to comment Share on other sites More sharing options...
the_k Posted September 6, 2010 Author Report Share Posted September 6, 2010 I have tried both short & long lever blades on my bikes, peresonally I prefer the longer type. Using the longer ones where do you have the end of the lever in relation to the end of the bar and how may fingers do you normally use on the levers? Link to comment Share on other sites More sharing options...
bowellsyboy Posted September 6, 2010 Report Share Posted September 6, 2010 Just put some new S3 red ones on my gasser, very pleased with them. Personally i like short levers, you only use one or two fingers so why have long levers? Thats my logic anyway Link to comment Share on other sites More sharing options...
richt Posted September 6, 2010 Report Share Posted September 6, 2010 Been using Apico 3 finger for ages and not managed to break one yet, I keep trying to. I put a couple of wraps of PTFE tape round the handlebars under the lever clamps so they rotate during a crash. Forged levers are very tough and cast levers are brittle. Link to comment Share on other sites More sharing options...
the_k Posted September 6, 2010 Author Report Share Posted September 6, 2010 Just put some new S3 red ones on my gasser, very pleased with them. Personally i like short levers, you only use one or two fingers so why have long levers? Thats my logic anyway Exactly, that is why I asked the position of the longer levers? Link to comment Share on other sites More sharing options...
the_k Posted September 8, 2010 Author Report Share Posted September 8, 2010 Any more opinions? Link to comment Share on other sites More sharing options...
houseape1000 Posted September 8, 2010 Report Share Posted September 8, 2010 (edited) Just push the lever clamps further in towards the centre of the bars, that way it kinda shortens the lever, but as its longer there's more leverage, so easy to pull. Just try it.......it's all down to personal preference. I have mine set in so that I can pull the lever to the bars and it misses my little finger and the one next to it..... Although, I ride with just one finger on each lever, when I pull them in, it hits my middle finger......I know that doesn't seem to make sense, but I LIKE IT !!! Edited September 8, 2010 by houseape1000 Link to comment Share on other sites More sharing options...
the_k Posted September 10, 2010 Author Report Share Posted September 10, 2010 Just push the lever clamps further in towards the centre of the bars, that way it kinda shortens the lever, but as its longer there's more leverage, so easy to pull.Just try it.......it's all down to personal preference. I have mine set in so that I can pull the lever to the bars and it misses my little finger and the one next to it..... Although, I ride with just one finger on each lever, when I pull them in, it hits my middle finger......I know that doesn't seem to make sense, but I LIKE IT !!! Your set up makes sense to me. Well I have short levers on at the moment but wanted to get some spare levers and maybe put the new ones if they where different, hence unsure what to go for. On the mountain bikes I run my levers so the reach adjust is fairly close to the bar and the tip can clears my outer 2 fingers and use one or 2 fingers depending on how much force is required. On the road motorbike I've long levers but cannot put them any further inwards without changing the bars. So, I think I shall give it a go. Link to comment Share on other sites More sharing options...
baldilocks Posted September 10, 2010 Report Share Posted September 10, 2010 The mid length levers as fitted to the shercos give a slightly lighter action than the full length lever as the adjuster bolt is located in a slightly different place in relation to the fixing bolt. this may give you best of both worlds, more leverage and less likely to damage. Link to comment Share on other sites More sharing options...
monkeyboy Posted September 12, 2010 Report Share Posted September 12, 2010 I use my middle finger for front brake and index finger for clutch. standard levers (i think) on 08 Scorpa with the clamps run down the bars a bit to make more leverage and lighter action. Do most of you run with one finger covering the front brake and clutch at all times or just reach for it when you need it ? Link to comment Share on other sites More sharing options...
tony27 Posted September 12, 2010 Report Share Posted September 12, 2010 The mid length levers as fitted to the shercos give a slightly lighter action than the full length lever as the adjuster bolt is located in a slightly different place in relation to the fixing bolt. this may give you best of both worlds, more leverage and less likely to damage. Next step on from them is a set of the folding levers from ARc or AJP, I've had a set of the ARC levers for a few years & their length is almost exactly the same as the mid length sherco ones Link to comment Share on other sites More sharing options...
b101uk Posted September 12, 2010 Report Share Posted September 12, 2010 I cannot get my clutch MC down the bars far enough without it restricting how far I can twist the clutch MC down due to the MC pipe fitting hitting the lower part of the handlebar bend, if I twist clutch MC down to the angle I want the lever there is to much lever length over the hand grip for my liking or the handlebar is rolled to far forward with the right lever length and I am using a short clutch lever. They are Renthal 660 Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
