tirolean Posted July 9, 2014 Report Share Posted July 9, 2014 hi! Tomorrow i´m going to see this Beta Evo, the owner claims it to be a 2009 Evo Factory 290, but i doubt that, in my opinion it´s about ~2011 can anyone tell me which year this bike is made? maaybe it´s just a painted frame how do i see it from the frame number? since when do betas have 300 instead of 290cc? are there any other tips about what i have to look for at an evo? http://www.willhaben.at/iad/gebrauchtwagen/motorrad/beta-evo-factory-89178179/?adId=89178179 it´s this bike greets Dani Link to comment Share on other sites More sharing options...
mokwepa Posted July 9, 2014 Report Share Posted July 9, 2014 Hi. Sorry I cant help with the year but should it indeed be a 2009, check the frame around the fuel tap for leaks. Mate of mine had fuel leaking out of a crack by the fuel petcock. It was a known issue by beta and beta replaced his frame with a new one free of charge. Link to comment Share on other sites More sharing options...
lestergg2005 Posted July 9, 2014 Report Share Posted July 9, 2014 Hi it's unlikely to be an 09 as that model had the rad filler cap coming out of the left side of the frame behind the rad. 2010 onwards the rad filler is at the front. Check the bike starts easily when hot, stop n start it a few times and ensure the electric fan cuts in and out. Get the bike on a stand or box and take hold of the rear wheel and check for up and down movement on the rear suspension linkage. Hope that helps. Link to comment Share on other sites More sharing options...
tirolean Posted July 9, 2014 Author Report Share Posted July 9, 2014 thanks´, helps a lot! so if the rad cap isn´t in the middle of the rad it´s a 09? i hoped to get a cheap shot on that one, but if it is indeed a 2009 it´s not that cheap i´m thankful for any other tips! any weaknesses of this model? Link to comment Share on other sites More sharing options...
nelly1 Posted July 9, 2014 Report Share Posted July 9, 2014 best i can do is not 09 too also fuel filler neck is off centre on the 09 but pic not clear Link to comment Share on other sites More sharing options...
eddie_lejeune Posted July 9, 2014 Report Share Posted July 9, 2014 id say its 2010- they definetly look like the 2010 tank panels Link to comment Share on other sites More sharing options...
ducati996 Posted July 10, 2014 Report Share Posted July 10, 2014 Later model 09 evos had the 2010 radiators "filler cap in middle of rad" also check swingarm they were also known to crack on 09s. Link to comment Share on other sites More sharing options...
p@ul250 Posted July 10, 2014 Report Share Posted July 10, 2014 It's before 2011. I.E 09 or 10 as it has only the one fixing bolt for the rear frame arms (under seat area, to support air box) 2011 on have two bolts per side. Also 2011 was the first year that Beta did a 300 as a "factory" special and from 2012 both the standard and "factory" special where 300 cc. Link to comment Share on other sites More sharing options...
tirolean Posted July 10, 2014 Author Report Share Posted July 10, 2014 (edited) thanks again for such fast and helpful answers! as far as i know from ´11 on they had black frames, so this one might be painted or a newer frame, how do i check this? black colour works great to hide cracks i think... are there any engine noises which aren´t good or which are normal? regarding the frame number: on which position is the year it´s made? Edited July 10, 2014 by tirolean Link to comment Share on other sites More sharing options...
dan williams Posted July 10, 2014 Report Share Posted July 10, 2014 I remember the Top Team bikes were black framed. Maybe that is the seller's definition of "factory". You should be able to get frame numbers off the headstock which should give year infomation. I know in the US the importer had to cut the head off of any 09 that had the frame replaced to make sure the old frame couldn't be reused. I think that effectively retired the original VIN. Link to comment Share on other sites More sharing options...
jer Posted July 10, 2014 Report Share Posted July 10, 2014 Another clue might be in the wheel bearings, if can make out the numbers. Different years used different bearings. Read this: http://www.sxsuk.com/WheelBearings.aspx Link to comment Share on other sites More sharing options...
dan williams Posted July 10, 2014 Report Share Posted July 10, 2014 As far as looking for cracks it's easy to mistake cracks in the anodizing surface treatment for cracks in the aluminum. A fact shown to me by Ron Commo Sr. when I asked him about what looked like fractures on a Techno frame. He grabbed a piece of steel wool and ground down that section of frame to bare aluminum. Pointed to the now unblemished bare metal and said, "See, no problem" Not one to waste time that man. Link to comment Share on other sites More sharing options...
vonhazza Posted July 14, 2014 Report Share Posted July 14, 2014 I have an 09 Beta and I think it's a 2010 model, red tank side covers look 2010, just with a paint job on the frame and some nice looking anodised triple clamps, no problems I know of with that model, and any 09's with the fuel cap not off set should be ok also. Steve, Link to comment Share on other sites More sharing options...
tirolean Posted July 15, 2014 Author Report Share Posted July 15, 2014 bought the bike, it was in a dream condition! it´s a special model from a local dealer who equipped her with new rims, tripple clamps, factory exhaust, overworked engine and suspension. it still has the original tires on it, which are nearly new 1 Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
