Reving When Running Our Of Gas
toshy
On a serious note though engines rev up when they are running out of fuel because they are running far to lean, letting them do this regularly, or in your case reving the knackers off it may nip it up if not seize it solid. As above, put fuel in it when needed, kill the motor if it is running out.
Well it sure ain't to funny half way up a committing rock section when it hits full rpm you got to toss it and won't shut down even when hitting the kill switch. I think I might have an air leak,
It also could be the `on` position runs out early. Ride with it on reserve all the time. Down side is you would be out of fuel. I did this on the Beta Techno`s because the CDI could break the plastic fuel tap in the on position on a hard drop off. I always ran it on reserve.
  • 1 month later...
