Txt 270 Or 280?
  • Replies 64
  • Views 16.8k
Most Popular Posts
  • I am beginning to think that myself. The 280 is only 3 miles away and the 270, 40 miles, but both will go in the back of the Discovery. Would the 280 not  have been sorted in its 13 years history by n
  • crazybond700
    crazybond700
    Some older engines dont have the filler hole for some reason.   http://thumbs1.ebaystatic.com/d/l250/m/mgrNcO9iQBiPujA1kmDWg8Q.jpg   Yours has so just smile and fill her up!
  • crazybond700
    crazybond700
    Yes its the one behind the kickstarter
Well I have bitten the bullet and bought it. Here's a couple of pictures. Now I better try and work out how to change the gearbox oil. Lol. Always change fluids on new vehicles I reckon.
There is a alen screw on  the left side of the bike. First warm it up a bit and remove the bold and let it dripple out. Than clean the bold put it back and fill her up again.
+- 650cc of 5w30
Ok. I shall check tonight and maybe send a photo if i am unclear There is an allen bolt at the top on the right and i think a hex bolt with viewing glass.
Ok the pictures. The allen bolt  to fill. Is it s view hole below. Drain. Not sure!
I have seen some people say ATF. Are you saying mineral oil ( not synthetic)? A pity I can't find any sort of workshop manual.
See how there is a hole in the bashplate inboard of the gearlever, chances are that is for access to the drain bolt which looks like it would be a grubscrew to keep it flush with the cases
The last picture shows the drain :) From underneath the bashplate.
There is a lot of information, you need to search a bit for it though. But just ask, thats why we are here :)
5w30 is recommended, I dont have bad results with 10w40 (which I also use in my other non-trial bikes). For the Pro's I always use putoline light gearbox oil 75w.
Edited by crazybond700
Thanks chaps. I am trying to find a manual for my bike so I can have a read for basic stuff. So the 5/30 mineral oil seems to be recommended, although as with many things there seems an array of opinions.
Started it for the first time since I had it last night, once I found the choke. Sweet engine!! Revs really nicely. I might have to ride around my partners garden and up and down her landscaping. Lol
Thanks chaps. I had found them already. The clutch does drag so I think I will be changing the gearbox oil at the weekend. I will go for the 5w/30 as recommended. Just to confirm. Non synthetic?
Sean, Have at the present time a 2001 TXT 280  ( 10 years) same engine as yours,great reliability,
was a little to quick for me , went to a 10 tooth sprocket which made it better.
I hope your oil is not milky (coolant) which is not conducive to good clutch operation.
Does the bike jump when cold and gears are engaged?
Larry
To be honest I have not had much chance to try it out since I got it last week. I will change the oil first and adjust the clutch lever and see how that goes before worrying unduly.
Just to confirm.. I do not use synthetic as this swells the clutch plates?
