Venhill Cables
Not sure about that John. Think side pull throttles came in a bit earlier than that. I've had this problem with venhill cables a few times as far back as the 80s.
  • Replies 30
  • Views 11.6k
Most Popular Posts
  • Should have gone to Martin.
  • Mmmh ... the throttle, is it a Domino trials throttle? and have you still  a Dell'Orto carb fitted?   Then the gas cable should fit very well? At least it does to my SWM 320?   To the brake cables
  • They do two types, one for front brake/ clutch, plus a thinner one for throttle, valve lifter or advance/ retard. I try to keep them in stock all the time,you can make the cables to the exact length y
Venhill will make cables to your pattern, if required. Last week I sent them a clutch cable, and a throttle cable- admittedly it consisted of two parts because I use a device part way along to alter the ratio, but I was a bit surprised to get a call asking for a payment of £116. Think I will stick to making my own.
How much ?that's ridiculous . I can't understand why they make cables too short. Surely the inner is cheaper than the outer? If you always had too much slack I could understand and it would be easier to fix.
116£ wow there must be something special with the cable.
I paid less for one brake line with banjos and 6 cables for various SWM and Aprilia trials Bikes two month ago. I ordered for some friends of mine in Germany and myself to split the shipping costs...)
  • 8 months later...
If you aren't running Domino levers and perches and throttle assembly the cables will not fit. Domino were standard fit back in the day.
...been there, got the T short and cap;)
Edited by iconic558
I don't were the £116 came from?
I just spoke with Venhill and have been quoted £42 inc VAT for a custom cable.
One cable for £42 is pretty similar to 2 and a half for £116 is it not ?
(Tricky said  one cable consisted of 2 parts to accommodate a device)
My bad:)
1 hour ago, jon v8 said:
Yep, they are bloody good - I make all my cables from these,get them from BVM.
On that approval Jon, I think I'll treat myself to a kit.B)
They do two types, one for front brake/ clutch, plus a thinner one for throttle, valve lifter or advance/ retard. I try to keep them in stock all the time,you can make the cables to the exact length you want to follow whatever route you want.They work well.I also use a mini blow torch to solder the ends on as I can see when the solder has flowed properly through the nipple.I know most folk use a solder pot,and recommend it,but the torch works for me.
Edited by jon v8
  • 1 month later...
Ordered cable for my Beamish Suzuki.
The front brake cable is about 6in to long and all the adjustment just about already used up.
I gave them the measurements of my old cable and their new one and they said, theirs is correct.
Won't be buying direct from them anymore.
Wow 6in!
6 inches = 6 Zoll = 6 x 2.54 = 15.20 cm
That is very much too much and you and Venhill where talking about the same model?
