December 1, 20178 yr On 2/6/2017 at 4:02 AM, sniper said: I 'think' the 4 is the plug coming the newer ones are coming with (maybe UK?), at least that is what Nick said on Saturday! I asked specifically because i had to run a slightly hotter plug in my evo. How do you like yours? My (just purchased last week) Brand New 17 Ice Hell 300 plug also sooted up and stopped the bike from running today after only around 6 hours on a New bike! Lewisport said to change the plug to a 4 plug. Pulled the existing plug, a 6. Black and sooted big time. So perhaps they'll swap to a 4 on the 18s? BTW - Lewisport recommends 130:1. I am running 93 Octane ethanol free fuel. Hmmmm.....
December 1, 20178 yr You need to adjust the air bleed screw. I'm going to bet your idle is pretty low, and you'll find if you get the bike in sixth gear and give it a handful it'll bog and or stall entirely. You need to back the air bleed screw out until the idle comes up. You'll know when it's right because it'll pull sixth gear cleanly.
December 7, 20178 yr I had mine back to vertigo as I couldnt get the tick over as I liked it one minute it was ok the next it was racing, they found that my airscrew wasnt where it should have been. but I'd never messed with it I only alter the tick over by the throttle stop on the kick start side so i dont know if they can work loose
December 8, 20178 yr One point not mentioned in the previous oil discussion, is flashpoint of the oil. Yes the oil, however much or little is mixed with the fuel is headed somewhere. Most likely out the exhaust. High flashpoint oils seem better for and recommended for high rpm, higher output engines. Lower flashpoint oils tend to burn cleaner, and are oftened recommended to run a lower premix ratio, the higher the intended rpm. Oils that do burn, may produce carbon over time, while high flashpoint oils tend to remain wet. Synthetics of high flashpoints tend to leave a strong but easily cleaned oil layer, while castor oils tend to gum up unless run hot and often. With current technolgy, coatings, and exotic materials, plus some very high quality oils, the time may be near for mix ratios even higher tha 200:1. Sometimes though, our comfort level and instilled experienceholds us back. Admitting, I even consider oil inexpensive vs engine repairs, provided the engine performs correctly. Not debating anything, just sharing info.
November 10, 20206 yr Hi all, I have recently rebuilt my '18. Long story short, i got it running and idling nice last week, still bedding in a new piston and newly plated barrel so was just running it on the stand for 5 minutes or so at a time to go through heat cycles. Anyway, it has now started running really lean and is not wanting to run right at all. I'm thinking that the injector may have oiled up a bit? is that possible? I dont want to have to take the engine out again so any ideas? Have been running 50ml to every 5ltr. Think i'll reduce that having read all the comments above. Cheers
November 11, 20206 yr 8 hours ago, GazTemple said: Hi all, I have recently rebuilt my '18. Long story short, i got it running and idling nice last week, still bedding in a new piston and newly plated barrel so was just running it on the stand for 5 minutes or so at a time to go through heat cycles. Anyway, it has now started running really lean and is not wanting to run right at all. I'm thinking that the injector may have oiled up a bit? is that possible? I dont want to have to take the engine out again so any ideas? Have been running 50ml to every 5ltr. Think i'll reduce that having read all the comments above. Cheers Hey Gaz, 130:1 is the ratio. You were running a bit more oil than that... Put in a new spark plug (BPMR6A NGK). Then, run the bike at idle for a minute or so, but get on it and ride gently to warm it up. When the fan comes on, then get into 3rd or 4th gear, and open it up a bit... Idling doesn’t generate much heat/pressure in the cylinder... makes the oil kind of bog up the works... The real trick for longevity is to keep idle time to a minimum....
November 11, 20206 yr 15 hours ago, richtr300i said: Hey Gaz, 130:1 is the ratio. You were running a bit more oil than that... Put in a new spark plug (BPMR6A NGK). Then, run the bike at idle for a minute or so, but get on it and ride gently to warm it up. When the fan comes on, then get into 3rd or 4th gear, and open it up a bit... Idling doesn’t generate much heat/pressure in the cylinder... makes the oil kind of bog up the works... The real trick for longevity is to keep idle time to a minimum.... cheers for the reply. will give it a go
November 28, 20205 yr On 2/4/2017 at 4:46 PM, evo boy said: This is what I got with my Vertigo. I thought the same thats not alot of oil just wanted to make sure... that is the ammount in a deposit.....2,3l of capacity 25ml in a deposit, but 37,78ml in 5 L.
December 29, 20205 yr On 11/11/2020 at 12:10 AM, richtr300i said: Hey Gaz, 130:1 is the ratio. You were running a bit more oil than that... Put in a new spark plug (BPMR6A NGK). Then, run the bike at idle for a minute or so, but get on it and ride gently to warm it up. When the fan comes on, then get into 3rd or 4th gear, and open it up a bit... Idling doesn’t generate much heat/pressure in the cylinder... makes the oil kind of bog up the works... The real trick for longevity is to keep idle time to a minimum.... Well, I finally got the bike running OK. Had to fit a new injector which seems to have cured the problem and all is ok again. Big thanks to Nick at Vertigo UK for all the help.
December 29, 20205 yr On 11/28/2020 at 5:46 PM, bombero34 said: that is the ammount in a deposit.....2,3l of capacity 25ml in a deposit, but 37,78ml in 5 L.
