Piston slap confirmation
I have my own story of small end failure.
I was swapping the piston port top end on my CZ to a reed valve converted top end & got greeted by all this when I pulled the pin out, who knows how much longer it would have run before making a big mess. What probably saved me from a big blow up is the washers that centre the rod inside the piston kept the bits of collapsed bearing cage contained
Sometimes we get lucky & avoid the big mess
  • Replies 36
  • Views 11.9k
Most Popular Posts
  • If the key isn't a good fit in the slot, it can easily ride up the back of the slot when fitting the flywheel and this isn't always apparent when assembling, meaning that the flywheel isn't fully home
  • section swept
    section swept
    Your cranks big end might have ‘felt’ alright on the bench but there are a few ways that the bearings can wear from barrelling to tapering depending on main bearings wear to! There was no detectable p
  • Big end can feel fine while being bad. This pin & bearing came out of a crank I didn't know the history of but felt good, would have failed fairly quickly if I has run the motor without fitting ne
Well I tracked the source of the noise, but I still don't really know what the cause is.
The tensioner bush is quite warn but the inner surface is pretty smooth. The rubber wheel is well aligned to the chain and round. The rubber is quite hard but I suppose it they are supposed to be? I don't think it's the additional tension putting pressure on the clutch bearing, all of the bearings in the engine are new, as are the seals. I'm pretty certain I've put the clutch and flywheel on correctly. I'm running 300ml of ATF, but that doesn't dull the noise.
Has anyone seen this before? I could run it with the tensioner I guess, or just ignore it.
Edited by cornishflyer
If there is looseness in the fit of the tensioner wheel then it might be precessing (not sure of this is the right word). What I mean is that the tensioner wheel could be wobbling. If it is, then it will wear the bushing rapidly and fail. I would suggest either leaving the tensioner off or buying a new one. I run a M49 without a tensioner since I rebuilt the motor about 4 years ago and have not had a problem. The tensioner probably helps the chain and sprocket teeth last longer than without having one, but there is always the risk of the tensioner failing and causing damage to the casing and clutch. Judging by the number of internally damaged Bultaco clutch casings I have in my collection, having things come apart inside that casing is not uncommon.
Your video reminded me of  a Bultaco M99 (325cc Alpina) I had when I was a kid. The chain was so worn on it that when the motor idled, the tensioner arm would tap against the inside of the casing.
BSA's run a metal slipper tensioner, no spring, just adjust and once set seems to last forever, as does the primary chain. (also running in auto tran fluid) Maybe yours could be modified to suit ?
My 74 pursang has no tensioner from the factory and I have been racing it since 98 with only one new primary chain in that time with no troubles.I had a 77 pursang that had a tensioner  and even after fitting a new one still made noise.I talked to Hughs Bultaco about it and he said that year pursang always did have noise from the primary so I just ran it.My 199a has one but is quiet so I don,t know.I think I would take feetups  advice and just run it with no tensioner.
He are pics of my then new piston after it ingested the small end bearing.I keep it on the shelf as a reminder.
Edited by scot taco
Just put a new tensioner in there. In Motion have them and they are not expensive. Any high revving Bultaco engine it is best to not use a tensioner as they have a tendency to self destruct. On the slower revving bikes they smooth the switch from no revs to some revs quite a bit. Just makes them smoother.
That tensioner helps keep the primary chain in its ‘torque arc’ the centrifugal effect that makes the chain try to arc upwards as if following the crank sprocket but the clutch drum sprocket pulls it down. As you say smoothing the on off throttle but also helping to slow the wear on sprocket teeth and chain. That whirring sound is the engine humming to itself.....it’s the chain under tension and is normal on nearly all Bultaco with single row chain, the twin row or duplex primary chain is less noise prone.
Edited by section swept
