August 13, 20188 yr Going along with the theory that there's no such thing as a silly question, what is the bolt behind the seat loop on the Sherpa? Is it to secure some sort of a rear light?
August 13, 20188 yr Might be the military version Sherpa T with a gun-rack (joke) They did make a Sherpa T model that had a dual (long) seat. What was your frame number prefix again? I think the dual seat Sherpa T model was prefix 221 and it would have had a seat like a model 212/213 Alpina
August 13, 20188 yr my 76 159 has it (just looked!) but no bolt, think my earlier bikes had it too, something to do with manufacturing?
August 13, 20188 yr Author 11 hours ago, feetupfun said: What was your frame number prefix again? Mine is M158. I just checked my photo album, my old M159 had one too. Edited August 13, 20188 yr by cornishflyer
August 14, 20188 yr Definitely standard on some models, often thought it may have been for the enduro/trail bike larger seat?
August 14, 20188 yr My mod. 159 has it - I think it's a standard fitting for a longer seat. My mod. 85 and 92 both have a hole in the underside of the loop (lower side of the tube only) - any thoughts on that, anyone ? (The 85 also has a vertical hole through the centre of the loop but I suspect that's non-standard) Seems if the o.p. asked a silly question, there are plenty of people silly enough to answer it ..............!
August 14, 20188 yr lorenzo I just checked a couple of M85s for the hole in the underside of the rear loop and they both had the hole you described. My thought is that hole in the M85 frame rear loop is for ventilation to avoid problems with internal pressure during the welding process. It looks similar to the holes required for tubular structures to be safely hot-dip galvanised.
August 14, 20188 yr Here's another ventilation hole I found in a M85 frame. The wasp thought it was just perfect Edited August 14, 20188 yr by feetupfun
