Weight of fly wheel different manufactures.
  • Replies 43
  • Views 10.1k
Most Popular Posts
  • That is why they came out with a 300 instead of a 250. Do you really think a 300 4 stroke makes as much power as even a 250 two stroke? No , not even close.
  • section swept
    section swept
    £Mean effective gas pressure acting through the con rod on the crankshaft big end journal (crank pin/ big end) when the crank gets to 90 degrees passed TDC the effective gas pressure disipates rapidly
  • You are more correct in that than most people would like to admit. I had a cota 200 stuck in the corner of my garage for 17 years until I was old enough to ride vintage events. It was like cheating as
Ross is correct, it's not just weight.
Actually, it's not just diameter either, it's actually 'moment of inertia' that matters, see here clicky thing
How do you imagine this influences how you keep your feet up?
It doesn’t.  But it’s know that more torque will come from more inertia. So, whichever bike can generate such with have a bigger punch correct? When you go for a splatter and accelerate the fly wheel clutch fully Off and then pop it, more inertia = more launch! Correct?
Sort of, but in addition to my Mont 4RT, I have 2 x Matchless rigid trials bikes, both have the same bore and stroke and similar frame dimensions, the 1941 bike has much lighter flywheels than the 1952 bike and is the one I prefer for modern 'pre65' trials, it revs quicker and feels 'punchier'. the later bike with the heavy flywheels is really, really great for hill climbs though.
I guess you must be riding different types of sections to us if it matter so much
So the stock 300rr  has less punch than an amateur rider needs then?  sounds preposterous to me.
Edited by oni nou
Yes of course I am aware of the disparity between the 2T power unit and the 4T power unit as is shown in the junior champs where kids  can ride the 4rt against 125 2t's  but really I mean seriously he does not need  more punch as an amateur and this could be easily proven if we got Toni Bou to come and ride his standard 300rr bike in the expert class in a USA national against Pat Smage on a 300 2t Sherco .......my moneys on Bou winning on his gutless 300rr.
Edited by oni nou
43 minutes ago, oni nou said:
I did not realise that the 300rr was that gutless that an amateur rider would need to to tune it up.........are we talking about the same bike as this one  https://youtu.be/Jr3w9J_qRGU
That’s what I think!! In the USA everyone seems to believe that this bike has no guts. I think it has much more than my previous bike: a 2018 300sherco factory.
