Fantic 301?
Hi,
I am looking at buying a Fantic 301 1988....is there anything I should look out for,problems etc....are they reasonably reliable?....best place to get parts..?.....thank you
Hi
Thank you,apparently its an 88?....if so its a 303?.....is there anyway of checking?...thank you......were they good bikes?
Any info....good or bad !..will be great..thank you
Hi Thank you...that's good of you.....any good?...….any problems?...thanks for your help
it's a 301 1985 1° serie
here some info: https://www.fanticmotor.asso.fr/r10q.htm
in my opinion a nice bike, some problems with the rear linkage, and the front brake too poor
about spare parts, i can suggest you many place here in Italy but i think you can find many parts also in Uk
I had one new back then,as above front brake weak by modern standards but far better than a drum brake.Linkage had bushes,not bearings which didn't last long.Good motor,steered well,air box let in too much dirt.Was soon outdated by the Beta tr34 and the modified mono shock Yamaha in my opinion
Hi,
Thank you very much for all the info.....tried the bike today and seemed very good.....but just trying to agree on a price!!…:-)
Couple more questions!...whats the largest size front sprocket you can get to fit the bike...also best oil to use in the pre mix..ratio 40-1?.....best gearbox oil..?.....thanks
4 hours ago, turbofurball said:
Looks like you can get a 13t front sprocket easily
sorry where from....?
