- Past hour
- Today
4RT has separate transmission oil from the engine oil which is great because you can put engine oil in your engine and transmission oil in the transmission and wet clutch👍 change the oil type and replace it frequently to keep water out of the oil because water makes the clutch plates swell. Occasionally remove and resurface the friction plates to inspect, dry out and remove high spots or irregularities in the friction plate material. Dump the old oil into a clear glass container to inspect for water or particulates. Inexpensive ISO 46 hydraulic excavator transmission oil purchased in quantity is what I use and replace frequently, because at half the cost of specialty motorcycle transmission oils it gets done twice as often and imo works way better. You should experience very little clutch drag even in sub zero weather using ISO 46 Another possible suspect is air bubbles or water in the clutch hydraulics.
sparkle21 joined the community
Can anybody tell how to stop my 4rt 260 clutch dragging
trevbul1 started following Beta Sincro Snatchy clutch...
Has anybody found a cure for the Sincro light-switch clutch yet? I've tried several things to fix it: 1. Changing the pre- installed settings 2. Changing the oil 3. Slipping the clutch in high gear to wear it down Despite this, it still snatches in slow turns, so I can't keep a line in a tight corner. Basically, I spent £7,000 on a bike which is not as good as my old one. Absolutely gutted.
Ergal axle 150grs less than steel one.
mr neutron started following TY250A Swing Arm Bushing Questions
It sounds to me you have a very firm grasp of what’s going on and how to repair and set the ignition on this bike. you’ve covered the basics well. New condenser is a great start. I’d be suspect that you needed to replace the ignition coil as the original femsa coils rarely if ever require replacement. However it’s a base covered so good on you for replacing. The timing issue as you mentioned…. The stator plate was fully retarded ( this would mean all the way counter clockwise). We see this sometimes with the points that are available on the market today. The rubbing blocks on the points are of inferior material and wear exceedingly quickly. Often times so much so that the points won’t open enough or at all. So look at your points carefully to see that the block has ample material on it. Make sure the points themselves are clean and free of any oil or dust or debris. Use a fine file or sandpaper to clean. And remember to remove any sanding debris. You’ve lapped the flywheel taper. When fitting the flywheel have the points cam lobe aways from the points as it will allow the flywheel to slip more easily into place. The end of the crankshaft should just protrude a little further or flush with the flywheel itself. Once in place set your point gap first. 16 thou is spec. Once set then adjust the timing by turning the stator plate advanced or retarded to get the correct timing. You’ll need a dial gauge in the bore for this step. Try not to make adjustments to the timing with the point gap. Verify too that your plug cap is in good working order. And obviously use a new plug. NGK BP5ES is the correct plug. However non resistor plugs are becoming harder and harder to find so you may have to settle for a BPR5ES. The points systems usually give good blueish yellow spark. This is plenty. If you’ve got spark move on to fuel. A clogged pilot jet or clogged enrichner tube on the bings and Amals can give problems with cold starts. And finally compression. Primary and secondary compression is important. Primary being engine case compression secondary being top end piston compression. These bike are notorious for needing regular crank seal replacement. Step by step keep up the process and I’m sure you’ll suss out the issue Steve
https://motorcyclesports.net/montesa-honda-resumes-production-just-days-after-major-factory-fire/
Initial assessments following the devastating fire that struck the Santa Perpètua de Mogoda facility last Friday reveal a far more serious situation than initially feared. The fire completely destroyed the company's logistics center, wiping out nearly 11,000 stored motorcycles and almost the entire stock of spare parts destined for the sales network. The damage will have significant consequences for the company's operations in the coming year. https://www.facebook.com/thehellteampage/photos/for-anyone-who-hasnt-seen-the-spanish-news-this-week-there-has-been-a-major-fire/1479928174151275/
Honda on fire Last week a serious fire broke out (it seems it started from the photovoltaic panels) at the Santa Perpètua de Mogoda facility near Barcelona: no injuries (around 150 employees evacuated without consequences), but there was considerable material damage and a massive rescue effort was required to bring the flames under control. A huge column of smoke was visible from kilometers away, as many as 28 fire engines arrived on the scene, and the situation further deteriorated when part of the building’s structure collapsed, forcing firefighters to change strategy. With entry into the complex becoming too dangerous, efforts had to be focused from the outside to contain the fire and prevent it from spreading to nearby commercial activities. The facility included Montesa Honda, the prestigious Honda Safety Institute, a recognized center for rider training and road safety, as well as various technical and logistical infrastructures tied to Honda’s sporting side, especially MotoGP team equipment, but no comments have been released on that to date. https://www.corsedimoto.com/en/stories/factory-up-in-smoke-results-in-free-fall-red-alert-for-honda-across-motogp-sbk-and-mxgp
TMofCumbria started following Flywheel fit and electrics
I bought a 199A. It would not start when I went to collect it but owner said he had had it started to check it was OK that morning. No spark, but when we removed the plug but it did look as if it had run. Got it home cleaned the points and checked gap whch as correct. There was now a spark but may be not as bright or as consistent as it should be. Still no start although I think it fired a few times. Tested the HT coil and secondary winding was open circuit so bought new coil from Inmotion. Slightly better spark but still no start. Had the condenser checked by an electrician. No Mf capacitance so ordered one from Inmotion which has just arrived. When removing the flywheel the nut was not very tight, only 30 to 40 ft lbs, it should be 75 ft lbs. However the flywheel was very difficult to pull off, I had to use an impact wrench on the puller bolt. When I got it off I found there were slivers of metal on the tapers and dents and areas galled out. The key and keyway are in good condition. Because of the lumps and dents the flywheel would not go back on properly, and could be rocked about. I removed most of the high spots with a die grinder and am now lapping the flywheel onto the taper, just about got it satisfactory. When the flywheel is fully seated how far should the threads on the crankshaft stick out beyond the flywheel? Obviously the flywheel not being seated as far back as it should be and possibly not concentric on the crankshaft, will have reduced the magnetic flux in the source coil so I am hoping properly seating flywheel along with new capacitor fixes the problem. Does anyone know what the resistance of the source coil should be and who can rewind them? (please dont suggest electronic ignition, I am wanting just to get the bike running and everything else checked before I spend a lot) The timing was 2.9 mm BTDC. However to achieve this the stator plate was in the fully retarded position, which seems unusal. I have had bultacos many years ago and think the stator was usually near middle position. Unfortunately I did not clock the flywheel before removing it and it may have been running out of round due to the shards of metal in the taper. If this was the case it would affect the timing. Where would anyone expect the stator position to be? Thanks Tony
mrt675 joined the community
Hi , my sons Oset 20 has Promax solve brakes and the rear brake lever (blade ) has snapped ! Has anyone changed the blade for a cheaper alternative ie Clarks blade £8 or can you only use the Promax £19 inc p&p , or any other brake blade . Thanks
I think just the set up of the bike back in the day of course it’s not like the modern nearly bantams but maybe a forerunner,I would just like to know who built it.
In your opinion which parts have "been done rather well"?
I need help with a project I have bought which I was going to use for spares but after giving it a look over I think it might have a bit of history to it.My thoughts are that it has been built rather well,its frame has been modified with twin rails under the motor (the frame number is d10***)and is clearly bantam and the rest of the bike has been built with a lot of thought,does this ring any bells with anybody.Thank you.
They were mainly scooters and small motorcycles. Not many trials bikes.
mr neutron started following Ty250A Footrest Kit
if one has 11000 not selling bikes in stock it is good idea to finally get the money from insurance then )
The losses are more than 11,000 motorcycles and all the spare parts on site have been destroyed . the only thing not destroyed is the production facilities and the admin departments . As there is no where to store anything that is produced / manufactured at this moment , everything is paused and admin staff are working from home until further notice.
https://www.gbnews.com/lifestyle/cars/spain-honda-motorcycle-factory-fire-evacuation
Twinshockwobbler started following SWM tl320 clutch upgrade update
Hi all, just a bit more info that might help you all out with dragging clutches. As you are aware if you read my other posts, I fitted an Aprilia TX311 clutch hub to my 83 TL320. That along with the 12mm ball bearing conversion did make a huge difference. However, I recently came across a new steel internal clutch arm (the one with the kit is cast aluminium and difficult to extend) which I extended by 10mm, this again made the clutch pull a tad lighter. when riding the bike in practice or events I noticed the clutch developed a bit of drag, not enough to stall the bike but enough to make finding neutral a pain while waiting in turn at a section. I initially thought this is the plates sticking because when roughed up it seems to cure it. I obtained some new steel plates from motoswm as Martin sells the type with dimples that retain the oil better and built the stack up to the correct Aprilia spec. When I put it all together something just didn’t seem right, I’d not changed anything other than the plates but it appeared that the stack was very snug in the basket depth wise, almost not enough room for the friction plates to move about. I tried the bike and it just stalled and even when I got it going the clutch just wouldn’t clear???? I pulled it apart again and got hold of the Aprilia basket I bought with the hub. I’d been using the SWM basket as they are identical or so I thought, I measured the depth of friction plates slots in both baskets, the SWM basket came up at 29mm and the Aprilia 31mm. I fitted the Aprilia basket and reduced the stack height to a fraction just under the spec buy fitting one or two of the older plates, put it all back together and tried it….no drag, no stall, ok let’s try it out in practice. Rode it for four hours in practice which is probably more than you would in an event as your not stopping so much and had no issues at all, was as easy to find neutral at the end as it was at the start. hopefully this is an end to the SWM clutch woes oh and I use 80w oil to. Not sure if this will help out but worth a look next time you’re in the motor. I’ve attached a couple of pics showing the difference in hubs.
Both air and water are necessary for iron to rust. Remove the O2 (Oxygen) and the H2O (Water) and you have no Iron oxidation. ... and for those who did not pay attention in high school, now you know how to prevent rust from happening 🤓
20000 sq. meters burned down according to the news. This is whole Spain Honda facility as per the map
