- Past hour
Thanks for that. Managed to split the lot and buy just the spacer. Cheers.
- Today
SamAs started following 2017 txt gearbox noise
Hi all, Ive recently got a 2017 txt racing 300 and it’s making a noise in the gearbox. There is a ticking noise that im assuming is the chain as it does this in time with the master link. But once I shift into 4th gear the box starts to whine like crazy. I know theyre straight cut gears but it sounds like a race car, it’s almost louder than the engine. I’ve been told that it’s a case of possibly bearings or something in the box but seen on an older post on here that the whine is “somewhat normal” im just trying to figure out if I need to take the engine out or not as I’ve never done it before and dont want to do it if I don’t have to. But I want to do as much as I can myself to save money as the bike cost me a lot. thanks in advance for any help, I might end up taking it out soon anyway it’s just a bit daunting
SamAs joined the community
Erm how somewhat normal is the whine in 4th? Because Ive got a 2017 txt 300 and when I go into 4th It sounds like the box is about to blow up
There is a spacer on ebay.co.uk now with a flywheel and weight £52.49. Did you try the importers they list as around $12.
I have a 2014 evo 300 and want to add a flywheel weight. I have a Hidria weight from a rev 3 but suspect I'd need a cover spacer, which I can't find. Does the S3 weight fit without the need for a spacer?
Time Left: 27 days and 57 minutes
- FOR SALE
- USED
SO, NOW THAT I HAVEN'T RENEWED MY 2025 COMP LICENCE, (AS PROMISED) IT'S NOW TIME FOR ME TO FIND A NEW HOME FOR MY 4RT. IT HAS BEEN FULLY SERVICED AND RIDDEN JUST ONCE SINCE THAT SERVICE. HAVING DONE A TOTAL OF 12 WOBBLER EVENTS IN ITS ENTIRE LIFE. IT WAS BOUGHT NEW FOR MY 71st BIRTHDAY....(YES I AM 82 NOW SO THAT IS THE REASON FOR MY RETIREMENT.) IT WAS BOUGHT NEW FROM MUNCH. HAS MICHELIN TYRES, A RADIATOR AND COIL SHIELD, A CASE CHAIN SHIELD. HAS 9/42T SPROCKETS. DOESN'T HAVE A V5C, DOES HAVE CERTIFICATE OF CONFORMITY THAT CAME WITH THE BIKE. NEEDS VIEWING AS IT STILL LOOKS AND GOES PRETTY GOOD FOR IT'S AGE. UNLIKE MYSELF!!! I ALSO HAVE MY SPRITE TRIALER LISTED WITH TRIALS CENTRAL.2,200.00 GBP
Winchboy joined the community
Often, when assembling Bultaco engines the crankshaft will bind on one crank case half after the case halves have been torqued to specification. Generally speaking the crank can be given a quick swat with a dead blow hammer to “center” it in the cases. It will spin freely once centered. Your crank does need to be repaired. The pin isn’t sitting flush on the one side and it isn’t pressed fully on the other. As well there does appear to be a crack in the one crank half. Good used cranks are easy to find and can be rebuilt with a new rod kit to bring back to oem standard. On the inside of all Bultaco crank wheels are balance factor numbers. Be sure you do not have more than a two number spread between the halves. You had also asked about the rod moving side to side excessively. In the mid 70’s Bultaco was having trouble with Sherpa cranks seizing. Most times this would occur during higher speed applications such as riding a road section for several miles. The crank thrust washers were seizing and causing catastrophic damage. The fix was to remove the washers and use small end spacers at the gudgeon pin between the rod and piston to align the rod on the crank pin. Your crank is this design. It’s normal and desirable. It still is pressed together using 22 thou clearance on the crank bearing, and gives a much more reliable running crank at higher rpm. Steve
I want my 2024 sport to sound like Toni's 4 stroke torquer since I've been inundated with his impossible antics on Instagram. I love the one finger diaphragm clutch but to really get the feel of motor /flywheel inertia, I want a low frequency pop instead of the 'zing' sound which is mainly due to gear train noise. So I took a cheap 12VDC car alarm out of the trash and tapped it across two random AC motor phase leads, just for giggles. And predictably, it first smoked a little, probably the 50+ volts into 12 V circuit thing, no surprise. But then it kept working and would produce an ugly growly sound proportional to RPM. I'm not an Electrical Engineer but no doubt someone with circuit design savvy could use this tiny phase lead signal to trigger a proper .WAV file of a single gas bike pop and make a scalable frequency output to a piezo or a speaker. Has anyone done this? I expect it could have its own little battery. Heh, maybe even BT into my hearing aids. Just dreaming but would love to hear if anyone has done anything along these lines?
Thanks for all your help guys. I think I will have the crank overhauled as a result of this discussion.
Can you feel anything with a sharp-tipped scribe? A crack could explain the problem you are having. Another thing to consider is the history of the crankshaft. After repeated pressings, the pin/crankwheel interference fit can become too loose. If you have a dial indicator and a means of supporting the crankshaft, measuring the runout could tell if the crank wheels have shifted position,
No, doesn't appear to be looking through a magnifier.
There you go, it is not pressed all the on the one side
bikeskint started following That nice green colour 🤔
Hi all I guess this has been asked before I love the green colour of my Tr77 however the side panels are in pretty poor condition so I was thinking about replacing with pattern part's any help on the nearest to factory green would be appreciated, I'm leaving the tank as it's got some nice age related marks And the plan is just to clean it And then clear coat.. Cheers
Not sure if you have sorted this out yet. It looks like a 1981/82 model to me. To be sure you could drop a line to In Motion Trials in the UK 01784 440033 and let them have the engine/frame number.
So I looked at your pictures. Show us how the pin sits in the crank from a side view. Most rods only needed 18 thousands clearance. Granted I have luckily not done a bul.
The service manual mentions 250cc - 360cc rod side clearance should be .022 - .024-inch (.55 - .60mm). Section 6 (16 pages) in the service manual is on rebuilding and alignment of the crankshaft.
Whenever I split a crank I always measure the width of the wheels so that I can be sure that the tolerance is the same when it goes back in, I have never seen that much clearance and would presume it needs pressing up a bit more. As Konrad observed he doesn't fiddle with antiques which is understandable as they often have unique measurements and need fiddling to get right. Good luck
I think this relates to your prior post about huge side-clearance on connecting rod. I have read about the washers on the piston pin, but have never seen a motor that used the technique. What struck me as odd, is that the big-end bearing itself seems to have a lot of clearance to the crank wheels and could walk from one side to the other. So, even though that motor may use washers on the piston pin for rod centering, it may still be that the crank wheels are too far apart. But this is all speculation on my part. I don't work on "antique" motors.
Slackdabber started following Crank Binding
199A Rebuild progressed smoothly....until, the slightest tightening of the engine bolts and the ignition side crank flywheel is binding on the LH Crankcase. Main bearings are where they should be and the crank belongs to this motor. Any thoughts/suggestions please? Also the crank pin isn't flush with the crank halves, on the LH side which is fouling, it is recessed, on the other half it is very slightly proud. Should it not be flush on both sides?
Technical Resources for Electric Motion Trials Bikes
gas2222 replied to konrad's topic in EM (Electric Motion)
battery pic. -
sorry I wrote Bafang on the battery but instead it is a Talaria or Surron almost identical -
Ciao, 1. the original controller crash itself ...i don't know the engeneerig install a 48 volt Kelly controller on 58.8 battery volttage when the max voltage of the controller is 60 volt! I substitude the original Kelly controller with similar KEB72801X at least 72 volt......$ 350 from company in Cina 2. the controller's fan run when you turn the main switch on ( no noise at hall ..very small use of energy ...inaff wind for cool down the aluminum plates 3.the performance improve is fantastic KLS7260RM ( racing sinusoidal ) see on Kelly Spec,,,,KLS-RM is a variant of standard KLS controllers. KLS-RM has greatly enhanced its peak current, which is suitable for motor application scenarios that require high starting current, which is suitable for motor application scenarios that require high starting acceleration, such as racing electric motorcycles. I will att.a PDF. 4. the project take only a day...you need to increase the lenght of the 3 phase motor wire, cut a small part of the support of rear fender,(i install the controller above the chassy see the above pictures) small mod on the plastic...a couple of hours...I keep the original cable controller and use the old female connector and solder the wires on it.(See next pictures) i follow the schematic on the new KLS and compare with the old KEB ( see on PDF schematic diagram) of course i spend at least 4 hours to change the parameter by the Bluetoot adapter for my ride attitude ( I was a Italian Champion on motorally in the old 1992 )so i like Power.....42 Kw peak for 1 minute.. 5.Total cost is the price of the New Kelly KLS7260RM plus DHL transportation and ItalianTax around 600 US $ 6.the seat is KTM freeride 7. of course i upgrade the battery also, the old battery was almost new compare with the age but to complicate to upgrade i installed a SURRON 67,2 Volt Battery with the BMS remuve and add an extra 67,2 volt 20 amp litium battery in parallel. 8. a clutch lever is for regenerative brake and also i use the beginner part of trottle (5%) for regenerative brake too 9. all the parameter are so easy to manipulate with the AC aduser app on cell phones... 10. I can't upload my PDF...see the Kelly manufactors for descriptions ..Ciao from Italy
By pre65wobbler
27 days and 57 minutes -
By pre65wobbler
22 days and 13 minutes
