Past hour
2022 gas gas txt 300 jetting
If you are talking to me, I've been searching for a bit crisper response plus a cure to the erratic starting issues. At the moment I am running a 42 pilot, stock needle and clip position and a 122 main. And as it has always been, regardless of jetting, sometimes it fires right up, then its 6-8 kicks. Hot or cold. Actually seems to start OK more often when cold
Sorry for the late repsonse, haven't been on. When I was in the process of buying the bike, and was shopping for the best deeal, I talked with Mike, the owner of Trials Superstore. His shop is one of if not THE largest Gas Gas trials dealer in the states. He does not sell any other types of Gas Gas bikes. Anyway, in one of our talks he mentioned that the 23 - 24 model year bikes were blowing up trannys. I think he mentioned this happened more with expert/pro riders but warned me none the less. Said he had ZERO issues with the 25s. So I looked in the online parts fiches, found the parts that were different and ordered accordingly. I believe one of the shafts, main shaft I believe, plus a couple of gears. I haven't had any issues so far other the all of the metal shavings but I wanted to get the parts while still available, in case there is any issue in the near future
Yesterday
old but new
I have ordered some parts from Hughes Bultaco and they may have one, But I also found that a 6A10 silicone diode will also work and are robust. When I get done I hope make a colored wiring diagram that shows these items better. Thanks Hal #116 000706
old but new
Thanks for the reply. I had looked up the diode and couldn't find any. After searching for "lucas power diode 49934A" it comes back as obsolete, but did give me some modern equivalents. I had been looking up (lucase diode 49934A) putting the word (power) gave the information about modern power diodes Thanks for the feedback. I really appreciate it Thanks Hal PS. I'd still like to see a picture of the wiring in a Lucas headlight if ANYONE HAS ONE.
old but new
Use an oscilloscope to test the power being supplied to it, that will give you a hint as to the components purpose. If it is a diode that's a bonus, easy to replace on spec. That would make it a power diode as it is designed to sink heat and the main purpose would be to roughly regulate voltage output to match the lighting requirements. If a VOM test fails in both directions the component must be cooked.
Pistol joined the community
260 vs 301 for novice.
Hi. So did you go for the 260 or 301?
Last week
Look what i found under the stair
Thanks new pegs on the way. And am now off to investigate the big bore kit thread.
old but new
Thank you all for your replies. the picture of the headlight shows the electrical item circled in red. It has lucas and #49993A and looks to be a Diode. I have checked it with a DVOM and it it doesnt read for a diode or a resistor. If anyone who has a mid 70s Bultaco with a Lucas headlight please take a picture and share it. I have the 5 speed Bultaco manual and it has 2 wiring diagrams. Which isn't really clear on the headlight wiring and I don't seem to see the lucas 499934A item in it. the lucas 49934A was bolted to the headlight shell right above the hole in the headlight for wiring pass through. Thanks Hal
https://www.trialscentral.com/forums/topic/51772-tlm-50-big-bore-kit/ lot of info here especially at the end.
Would highly recommend you upgrade the pegs with nice wide modern pegs.
All-Good joined the community
Thanks for that, am 16 stone so am considdering the mbx barrel and piston 70cc big bore kit but I think the port timing is for higher rpm. It will be a fun experiment. There may also need to be a bit of clearancing
Returning to trials will the hips hold up
Well I’ve bitten the bullet and bought a Montesa 4RT. I’m 62 and going to break myself ( in gently) I’m in the North Lincs area and would like to find midweek locations, so I’m not locked into weekends if possible. Looking forward to getting back into it Picture attached in its temp location till I moved my other ) road) bikes around to fit it in.
Brynylans started following Returning to trials will the hips hold up
They have full sized wheels but a competition rear trials tyre is a very tight fit in the swingarm. They are quite small which can be a limitation depending on rider size. The motor is willing but can be a limitation for trials depending on rider weight. Some people enlarge the motor. Yes, made in Japan. Mid 1980s.
Brynylans joined the community
Hot start issue
Adjust the valve clearance., it needs to be spot on and you just described the first symptom.
Aprilia Climber 280 1993
Titanium parts : triple clamps, suspension linkage and more (-270grs) Scorpa easy 1996 brand new rear disc Beautiful Régina lighter chain
2006 gas gas txt 200cc
There is'nt much interest in trials bikes at the present time , Superb condition like new £1,500.00 , Scruffy £800.00 or less Or ask as much as you like and then realise this is not the time to ask for stupid prices. The futures not bright , the future is orange.
Future
Check out these prices. You can get a Racing for $4k and a GP for $5k. I’m not so sure that the prices have anything to do with the trouble Gasgas has been in though because I bought my 23 Racing for $5k in 23. I think it has more to do with dealers just getting rid of too much stock because that’s what they told me when I bought it. https://motohunt.com/motorcycles-for-sale?q=Gasgas+txt&sort=a
hollywoodcrash started following Changing Fork Seals
Considering switching from 2T to 4T
Due to more old man issues, I have added the electric start kit to the 300RR. With the battery, I can get the idle down to a little below 1600 before it will get hard to start. The high idle is still annoying and requires more clutch work. The 4rt is basically a sharper tool. If you like a quick sharp tool with very sharp response, it would be good for you. If you like a soft forgiving tool, the Beta 4t is a better choice. I greatly prefer the Beta but am locked in to the estart.
Hot start issue
I've just bought a 2022 301RR. Previous owner did nothing with the bike, it's literally new. Bike starts ok cold, runs fine, idles, fan cuts in, but will not start when hot. I'm new to 4-strokes. I've filled it with fresh fuel, cleaned the air filter and replaced the spark plug, but get the same same issue. Can't find any loose plugs. Tried the ECU reset holding throttle open. Checked for throttle cable free play. Where should I start looking? Thanks
Montesa 4RT idle speed is high because fuel injection works on electricity and with no battery you can not operate the fuel pump in a discharge state.
TBH joined the community
- Future
I recently bought a 300 Beta 4 stroke, here are my impression on 4 stroke bike. I'm in my 70's and I wanted something different from my sherco ST 250, I ride ( not competition ) with a friend that is the proud owner of a 300 repsol 2023 ( or 4 ) and he was kind enough to let me ride it for half an hour. The Honda Montesa as a realy great suspension, start easily when you know how to push not yank the crank, is realy well built and seem's to be very reliable, on the down side the 300 is very quick on the power when you crack the throttle, the response is brutal. I felt like I had to always use the clutch in tight situation, I only had a go on a 260 for about 5 minutes, but I had the same feeling on throttle opening. The Beta I got is a 300 ( I wish it was a 250 ) but after installing a slow throttle ( Amal ) and replacing the 11t front sprocket for a 10t is a little more '' gentle '', I'm quite happy with the ride, the power is predictable and no oil mixing. A 4 stroke is a very different beast, yes a bit heavier than a 2 stroke but fun to ride. I don't ( yet ) regret my purchase, I hope I won't regret it in the future. Guy
I'm not a road rider, I just mess around on a trials bikes so my experience is limited, but as the question was asked by the OP & I thought I'd share my experience and thoughts.. I will never notice the difference between a carb and FI in terms of performance and I would respectfully suggest nor would most other clubman rider...FI is brilliant when it works and I'm sure somewhere in that black box its been programmed to give the best performance.. It appears many manufactures are now going to FI, but I suspect that's more to meet emission regs rather solely to provide the best performance for the club rider. In my experience, when it starts to play up its a pain to diagnose the issue without a second bike to swop parts and if your unfortunate to have an issue its not going to be a cheap fix. When trying to sort mine, most of the loom was corroded, Black wire corrosion all through the earths, most of the loom was replaced. When the ecu was opened up just before launching it into the nearest bin there wasn't any visible issues with it. I agree there are a number of elements within the carb that could effect its operation, but other than a blocked jet due to stale fuel or a bit of debris they rarely go wrong, just like a the FI system in 99%of bikes, but carbs can be easily stripped and cleaned ready to go again whereas a FI system can't...The other issue we found is the idle speed on the Montesa.. its around 1800rpm, any less and the bike wont start, whereas the beta is around 900rpm and it drops lower and still pulls whereas the Montesa will stall and we found we had to use much more clutch which was also relatively switch-like compared to the beta...just my thoughts and experience...
- Future
Hi all. Im looking at selling my 2006 gas gas txt 200. Just wondering if there is much interest in the 200's and what sort of money they are worth? I know there is not many of them about and they have a niche fan base. Its in decent nick and needs nothing. Any info would be much apprieciated. Cheers
