This stream auto-updates
  1. Today
  2. So I looked at your pictures. Show us how the pin sits in the crank from a side view. Most rods only needed 18 thousands clearance. Granted I have luckily not done a bul.
  3. Yesterday
  4. The service manual mentions 250cc - 360cc rod side clearance should be .022 - .024-inch (.55 - .60mm). Section 6 (16 pages) in the service manual is on rebuilding and alignment of the crankshaft.
  5. Whenever I split a crank I always measure the width of the wheels so that I can be sure that the tolerance is the same when it goes back in, I have never seen that much clearance and would presume it needs pressing up a bit more. As Konrad observed he doesn't fiddle with antiques which is understandable as they often have unique measurements and need fiddling to get right. Good luck
  6. I think this relates to your prior post about huge side-clearance on connecting rod. I have read about the washers on the piston pin, but have never seen a motor that used the technique. What struck me as odd, is that the big-end bearing itself seems to have a lot of clearance to the crank wheels and could walk from one side to the other. So, even though that motor may use washers on the piston pin for rod centering, it may still be that the crank wheels are too far apart. But this is all speculation on my part. I don't work on "antique" motors.
  7. 199A Rebuild progressed smoothly....until, the slightest tightening of the engine bolts and the ignition side crank flywheel is binding on the LH Crankcase. Main bearings are where they should be and the crank belongs to this motor. Any thoughts/suggestions please? Also the crank pin isn't flush with the crank halves, on the LH side which is fouling, it is recessed, on the other half it is very slightly proud. Should it not be flush on both sides?
  8. sorry I wrote Bafang on the battery but instead it is a Talaria or Surron almost identical
  9. Last week
  10. Ciao, 1. the original controller crash itself ...i don't know the engeneerig install a 48 volt Kelly controller on 58.8 battery volttage when the max voltage of the controller is 60 volt! I substitude the original Kelly controller with similar KEB72801X at least 72 volt......$ 350 from company in Cina 2. the controller's fan run when you turn the main switch on ( no noise at hall ..very small use of energy ...inaff wind for cool down the aluminum plates 3.the performance improve is fantastic KLS7260RM ( racing sinusoidal ) see on Kelly Spec,,,,KLS-RM is a variant of standard KLS controllers. KLS-RM has greatly enhanced its peak current, which is suitable for motor application scenarios that require high starting current, which is suitable for motor application scenarios that require high starting acceleration, such as racing electric motorcycles. I will att.a PDF. 4. the project take only a day...you need to increase the lenght of the 3 phase motor wire, cut a small part of the support of rear fender,(i install the controller above the chassy see the above pictures) small mod on the plastic...a couple of hours...I keep the original cable controller and use the old female connector and solder the wires on it.(See next pictures) i follow the schematic on the new KLS and compare with the old KEB ( see on PDF schematic diagram) of course i spend at least 4 hours to change the parameter by the Bluetoot adapter for my ride attitude ( I was a Italian Champion on motorally in the old 1992 )so i like Power.....42 Kw peak for 1 minute.. 5.Total cost is the price of the New Kelly KLS7260RM plus DHL transportation and ItalianTax around 600 US $ 6.the seat is KTM freeride 7. of course i upgrade the battery also, the old battery was almost new compare with the age but to complicate to upgrade i installed a SURRON 67,2 Volt Battery with the BMS remuve and add an extra 67,2 volt 20 amp litium battery in parallel. 8. a clutch lever is for regenerative brake and also i use the beginner part of trottle (5%) for regenerative brake too 9. all the parameter are so easy to manipulate with the AC aduser app on cell phones... 10. I can't upload my PDF...see the Kelly manufactors for descriptions ..Ciao from Italy
  11. Step 1 : Wash it !
  12. Ciao! I think you should start a new thread describing technical details of your installation. Many of us would find it interesting. I would be curious to know: Had the old controller failed? How often does the controller's fan run? How did the performance improve? How long did the project take? Total cost? What seat is that? Did you upgrade the battery also? I see a clutch lever. How does that work?
  13. The piston probably must be replaced, unless the seizure was very light. In which case, it's sometimes possible to sand the damaged area smooth again. But this is generally not advisable. If the cylinder damage is just aluminum transfer, it's possible to remove the aluminum with hydrochloric acid. But if any peeling of the plating has occurred, the cylinder must be re-plated. Note that the plating is very hard and a diamond hone must be used. A standard cylinder hone for iron won't work. It probably not possible to determine the extent of the damage from photographs. A local specialist should be consulted. But finding OSSA parts is not easy either. ☹️
  14. b40rt
    Talking down
    I agree with you 100%, and incidentally, it's spelt sproCket. 😎
  15. faussy
    Talking down
    Ive been here a while, and also frequent a lot of other forums and I think it's fair to say people here are a lot more patient and helpful than on other forums. If someone has been talked down on its most likely because they've ignored some previous advice and are adamant they are right. Not saying it doesn't exist, and while the sites only real moderator doesn't seem to frequent the site very much if at all these days, IMO it is rare and certainly not something "a lot" of us are guilty of. Care to share specifically where you've seen this talking down?
  16. In case cylinder is seized what measure would be more feasable and /or economic: Replacing cylinder and piston or overhaul cylinder?
  17. Hello all, I've just bought a 2024 nitro 300. What spark plug should I run as I was told in my 2018 vertigo to run the hotter BPMR4A rather than the BPMR6A. Do you still need to do this on the newer bikes? Many thanks
  18. That is fine. The spacers on the gudgeon pin keep the conrod in the middle.
  19. Just looking at a 199A Crank. No up and down movement in the big end but a lot of clearance side to side. Does this look normal?
  20. ukbta
    Shed & Buried Beta
    I have just picked up a shed Beta Rev 3 in need of some love - but is 'running' - though missing parts like levers, kill switch, and rear brake seems empty of inop. Brave? Mad? Maybe... All I can guarantee is - I may well be asking, many, many questions!😁
  21. Time Left: 25 days and 14 minutes
    • FOR SALE
    • USED
    I have for sale a Montesa Cota 248 trials bike - probably December 1971. Has been dry stored since 1998. Well patinated through use.
    895.00 GBP
  22. sproket
    Talking down
    A lot of you are dickheads, stop talking down to people, if someone posts, stop treating them like a ****
  23. Ciao on 9/1/2025 I installed a Kelly KLS7260RM on Electric Motion 5.7 .....
  24. Time Left: 24 days and 5 hours
    • FOR SALE
    • USED
    My Sprite 197cc 9e Villiers Classic Trials bike is for sale. Has had a new rod kit, balanced, new piston, rebore, new bushes, bearings, selector, chain, sprockets, selector. 4 Speed. Renthals, Akronts, Did Chain, Electrex World ignition, Mk1 Concentric etc. British Hubs. I bought it a couple of years ago as a replacement for my beloved C15, which is too heavy for me now, as at 82 am 'past it'. Not being a fan of two strokes, as I have now found out...... have hung up my crash hat and boots and retired from Pre 65 ACU competition. The Sprite does have a V5c in my name. If you need any further information on my Sprite, please email me. I definitely won't be competing any more, which is reason for this advert. The Sprite must be ridden first, then you are able to see if it's the right machine for you. It was imported back to the UK in 2010, where it received the age related number plate. Originally when new in 1965 it was exported to Europe in kit form. A genuine Pre65 Classic Sprite English manufactured trials bike. My Sprite was featured in the August edition of the Old Bike Mart.
    2,500.00 GBP
  25. Cheers John…..Answer your insta massage 😄
  26. I used a bum bag for a couple of years but found they wriggle around too much. Last year I used a fender bag and it was nice to have the bike carry tools instead of me. They are a bit limited for room so you’ve got to be ruthless with what you put in them I don’t carry a drink for me but 250ml for the bike instead. The rucksack allows plenty of room for everything you need but it’s easy to go overboard and end up carrying too much weight, Make sure tools are wrapped in a cloth or something and don’t move, otherwise they’ll rub a hole in your back
  27. So I’ve signed up for the Scott trial this year, and can’t decide whether to use my camelback rucksack or purchase a bum bag. All I plan on carrying is a drink, energy gels, tyre plugs & tool, few bolts, couple of Allen keys, phone. What are people’s thoughts on comfort/practicality between the 2? Edit - I’ve looked at fender bags, but they don’t offer a way of carrying a drink.
  1. Load more activity
