Past hour
Little question about dimple plates
I received the apico dimple plates this week. I have rounded and polished the teeth a little bit. Just because I could. And today I have tried them for the first time. The improvement is huge. Really smooth operation, absolut better control on the clutch. Good update, all together The original plate as it came out Versus the sligthly polished Apico plate The apico teeth, before polishing, looked very similar to the original plates so there is some improvement. I don't know if it makes any difference in operation but it won't hurt either.
Today
smog joined the community
Aprilia Climber 280 1993
Titanium head bolt. (M14 x 1.50) Next titanium parts are coming ...
2015 TXT 300 Starting in reverse.
Have you tried shifting the pickup coil to retard the ignition? or are they set in position on a GasGas.
Yesterday
Seed joined the community
italjet 350t missing parts
Salve ho una italjet trial 350 cc326 del 1986 e cerco parafango anteriore e posteriore verde, mascherina e fanalino, sella nera. Sapete dove posso trovarli?
X-Trial Predictions Competition
The Mototrial X-Trial Predictions Competition will be kicking off very soon. The opening round will be in Madrid on 28 November and prediction entries will open on 7 November. All you have to do is predict the top 3 plus a wildcard. Get it right and you could be a winner. Join now and be ready to put in your entry. https://mototrial.co.uk/predictions/xtrial/
Newbie but old😊
Once you've got the bike built you'll find Gwent Classic Trials Club put on some good trials near you.
Hi, My 2015 Gas Gas TXT 300 recently started to misbehave. It sometimes starts in reverse. Cold or hot it doesn't matter. It started gradually, first once in awhile, than more often and now half of the kicks end up in revers starting. Beside this, when under load with low rpm, right before stalling, it reverses and sends me backwards downhill. The only reason I can think of is ignition timing, therefore I went straight to the woodroff key which is in perfect condition. Next I checked all the timing components, stator, flywheel, pickup coil, ground wires and grounding points, all good. With the stator removed, I performed an engine seal test, both negative and positive pressure, again all good, cleaned the carb, changed the spark plug with a new one, opened the engine to remove carbon deposits, put everything together but to no avail, it does the same thing. Did anyone ever encountered anything similar before? Can a partially faulty CDI do this? Any ideas? Thanks.
Loop started following 2015 TXT 300 Starting in reverse.
- Future
Loop joined the community
- Future
Future
AFAIK there's no news. If we hear some in the future, its probably more likely to be bad than good. As long as they keep making bikes and have spares available I dont really care if they dont run a team or develop the bike for the next 5 or so years
2022 gas gas txt 300 jetting
Why did you move down from the stock 48?
Im in the UK and run a 45 pilot
Last week
- Montesa Cota 200 (1980) restauration
I didn't keep check on the hours it took as it was done over a period of spare time I had, I painted the frame and tank/seat unit myself using 2 pack aerosol cans bought from my local bodyshop supplier, I used a plastic primer on the tank/seat unit the brand I used was pro xl- Considering switching from 2T to 4T
Working on excavators and farm tractors and operating them year round I noticed they are just huge heavy duty versions of a trials bike transmission. I run shorty levers so the clutch engagement changes just with that change, clutch progression is the result of hydraulics. I think ATF is perfect for automatic transmissions, my trials bikes all have one of the most simple standard transmissions and organic friction plate clutch systems ever produced. The ISO 46 works even in sub zero it is considered all-weather. Water swells clutch plates and lowers the burn point of the oil in the clutch. Burning the oil between the friction plates is what causes the carbon glaze that builds up on a cooked wet clutch and that comes from improper combined clutch & throttle control. The ISO or SAE or AGMA measure is the viscosity measure relative to temperature, the rest of what differs is what additives are in the oil to make them suit a particular task. If you had to do a 45 gallon oil change in an excavator or farm tractor at the cost of some small package oils being sold in bike shops, you would go broke real fast.- Considering switching from 2T to 4T
Did the ISO 46 change the clutch action? I started with the recommended oil but am now running Dexron VI. The Dexron changed the clutch action a bit and I had to adapt my clutch timing. It is difficult to tell but I think it engages later but quicker plus it removed a little drag. It must be a little thinner in the operating temperature range. A more progressive engagement would likely be better for me. I'm wondering if Dex/ Merc would be slightly thicker.- Future
- Mr
@rustyrider Wow man I'm really impressed by all the work you've done. You created a one in a world kind of Montesa, I Love it. How many hours did it take ? Did you brought the parts at a painter's to give them this color ? It's awesome If I had such a beautiful bike I wouldn't bring it into the mud for sure !- Considering switching from 2T to 4T
5 Montesa 4RT bikes over 20 years I only used ISO 46 hydraulic transmission oil in the transmission/clutch casing, never had a lick of transmission or clutch problems and the oil cost 7$ per oil change, change it frequently because there is no filtration on the transmission, the thing that destroys the oil is water from condensation or pressure washers. ... don't use pressure washers or swamp the bike and your oil will last longer 👍- Suzuki rl250 damper rod spinning
Thanks, already got the tools just lost the 8mm impact but got one in order.- Montesa Cota 200 (1980) restauration
The changes was I bought a later model Montesa 309 frame, swing arm and yokes, and converted it into a twinshock instead of an air cooled mono frame, I done this by welding the rear subframe to the main frame adding strengthen gussets where needed and top rear shock mounts on the frame and swingarm, the 200 engine fits straight into the engine mounts with no modifications, I used the original wheels and front suspension, the only modification was new front wheel spacers and I fabricated a new front mudguard bracket as the 309 yokes are wider than the 200. Once the bike was in this stage I then bought a Montesa 310 front exhaust pipe and modified it to connect to the original 200 silencer, I fitted a dellorto carburettor from a Montesa 315 and fabricated a alloy air filter box and used a Montesa 315 air filter, I made a alloy chainguard and bought a Montesa 307 seat/tank unit and welded bracket to the frame to mount it, the seat I made to.- Suzuki rl250 damper rod spinning
As @kurtas says , a battery powered impact gun or air type if you have a large air compressor in the garage. Spend money on tools for the job or struggle , its your choice .- Suzuki rl250 damper rod spinning
Push the fork into the ground to compress the spring a bit and use an impact driver.smeehee joined the community- Newbie but old😊
Welcome and good luck on the build from Portland, Oregon. Please post photos of your ride as it progresses.
