This stream auto-updates
  1. Past hour
  2. About 4 rides I think. i haven't ridden them in wet conditions yet so that is still a question mark.
  3. Yesterday
  4. Hi, old thread I know but does anyone have the file to 3d print this box ? TIA
  5. I take it you don't trust their claims. Not really surprising I suppose in a world of lies/liars. Its made in the usa by an american company so its got be your first choice really. Regards Alan
  6. Last week
  7. Wanted to revive an old thread. The biggest benefit I see to Evans is the fact that it's waterless and should help resist corrosion for those of us with magnesium engine cases. However, once you factor in the Prep Fluid you're spending about $70 for the Evans Package. I also don't love the super high boiling point. I'm also considering Maxima Coolanol. They claim to use deionized water and that it's safe for magnesium cases. It's also less than $20! What are the thoughts from the group?
  8. If I was using a wasted spark ignition (ignition pick-up located on the crankshaft and not on the valve drive which rotates at half crank speed) and needed to apply a fuel injection cycle only on the intake stroke 🤔 I think I would make the fuel circuit dependent on high vacuum pressure being present at the throttle body. Poor starting was always the result of improper valve clearance on all five of the 4RT's I owned.
  9. Cookiemonster, all sorted with Hastings now but thanks for the reply
  10. I’m with TDA used to be called BE MOTO have you tried them?
  11. Hi honda_freak and greetings from downunder. Thank you for taking an interest, and for your excellent measurements. Your findings are certainly contrary to what I found. Two possibilities come to mind... 1. Maybe the early models did indeed use wasted spark ignition. But then what about the fuel injection? or 2. Maybe all of them start with wasted spark but then change to only sparking on compression after the engine is running (and it somehow figures what stroke it's on). That sounds pretty bizarre too but you've inspired me to find out. Furthermore, does it inject fuel each revolution as well. I still have all my test leads and the setup is stored in my scope. What I propose is to run a much expanded timebase (say covering 20 to 30 seconds) and then kick starting the engine and triggering the scope on the very first spark. My scope should have enough memory depth to be able to examine the first few cycles looking for a trace like yours and then search for a time were it changes to non-wasted spark. It will be an interesting exercise but I probably won't get around to it for a month or two because gets to 40°C in my shed right now. I'll definitely do more testing and report back. As a side issue, I've occasionally had the situation where the bike won't start from a hot start no matter how many times I kick it. Following advice from this forum, I open the throttle full and give one kick (to supposedly reset the ECU) and sure enough the bike starts on the very next kick. I never really believed the reset ECU story but now I'm wondering... Could the main capacitor be keeping the ECU running long enough to maintain a non-wasted spark condition but have ended up on the wrong stroke because of poor kicking or a spit back. A reset might get it back into wasted spark condition so it can start again. It would be interesting to get to the bottom of that. If testing were to show the bike runs wasted spark initially from cold before changing over, it would be interesting to turn off the bike and immediately restart it and run the same test over to see what those first few cycles look like. I don't know - it could be a load of rubbish but we'll see. Thank you again for your input. Chris. ps. I'm keen to know about your cylinder pressure measurement/transducer.
  12. Hi aussiechris Interesting topic regarding wasted spark ignition on Honda Montesa 4RT. A few years ago I recorded some oscilloscope captures of the secondary ignition system versus compression pressure on a Honda Montesa 4RT model year 2007. It should be said that these captures were taken during kick start of the engine, which is in contrast to your measurements. But looking at this oscilloscope capture where I measure the secondary voltage on the spark plug wire versus compression pressure over two revolutions of the engine - it is clear to see the extra ignition event characterizing a wasted spark system. This was my small contribution to the discussion about wasted spark systems.
  13. New Ollé shock save 570grs New Ti exhaust save 260grs New dry weight: 70.7 kg
  14. I got an update. I set the pilot jet on spec and also I ordered a new jet block gasket with JJH needle. I could not define the current one, it was kind of dirty and the number was not visible anymore. So I chose it with factory specifications. I also found a reason why dirt and glue appeared in the carb. It was a cracked air box glued with a decent amount of baking soda. I also ordered a new box and rubber tube on carb. Squish is already set on 1.2 mm. So now I'm waiting for a JJH needle and jet block gasket. I will upload the PDF I'm using for keihin carb settings, if it works.
  15. Trials Superstore in AZ might have some parts too
  16. nice project, looking good keep the pics coming!
  17. Just done a quick online quote and Hastings can't find the reg number and doesn't list EM as a manufacturer. Oh well - back to the drawing board 😁
  18. Yeah, one of the electric insurers listed the e-pure but not the newer model. I will try again when I renew this year as they have had a year to get their sh!t together. The other thing for me was MSM didn't want to add my road bikes so I needed to start over with the no claims discount. Glad to hear you got sorted out mate - nightmare if you needed this for the Scottish six day or anything with a road section. I might try Hastings as well as Carole Nash - mine due next month.
  19. Patiently awaiting my order from The Tryals Shop in New York.... once these two guards are on I'll consider the project more or less done. So grateful people out there are still stocking parts for these old machines!!
  20. Front fender got melted on the exhaust at some point... smoothed it out with a grinder and got it installed back on the bike.
  21. At some point someone put a different silencer on the bike... made a crude retrofit bracket out of flat steel stock to hold it away from the rear tire.
  22. Local guy had an OEM rear brake rotor guard in his garage.... lucky find.
  23. Thought the brake pads were shot, gave them a quick 'resurfacing' on the concrete of my driveway!! Before and after pics.
  24. Local welder saved the day by extracting the broken off bleeder screw on the front caliper... The caliper threads were pretty bad. Chased them with an M10-1.00 tap and ended up just using it as a plug. Jitsie banjo bolt with integrated bleeder to the rescue!!
  25. The entire kickstand assembly was missing when I got the bike. So happy to find a kickstand from a local.... these are nearly unobtainable, the bracket at least. Believe anything 1994-2012 is all the same.
  26. Carb clean... just a simple clogged pilot jet. She's a runner!!
  27. Picked this up last weekend as a non-running project for $750. Been working on it for the last week and she's running good now. Below is what I've had to do to it so far, it's almost done and ready to ride. I'll be doing a full youtube video on the process when I'm done - channel name is 'MrTwoSmoke'.
  1. Load more activity
