- Past hour
I believe they’re in the UK. Their website only states where the copyright originated. “registered at Companies House in England and Wales. Registered at CPM House, 10 Works Road, Letchworth Garden City, Hertfordshire, SG6 1LB, UK”
- Today
Ron, Thank you for the information on this paint supplier. Are they in the UK or somewhere else? Also, a US Bultaco parts supplier, Hugh's Bultaco in New York state, thinks the correct paint color is what he calls "Hugger Orange." I believe I will order the smallest quantity of the Bootlace Yellow and see what it looks like sprayed out.
Yes completely suitable for an adult to ride, the difference between the Majesty and Mini-Majesty is a slightly longer top tube with a slight rearward bend to the two downtubes in front of the cylinder. You might choose to lower the footrests as like most bikes from that time they are too high. Good luck they are a good bike.
Thanks for the responses and the reassurance. I may well be the owner of one of these shortly.
leemccourt started following x2 Fantic 125s for sale , Pete kirby clutch , Beta Sincro Can't find insurance and 3 others
It is a pwk 28
Pauls320 thank you so much for your comment. If I did not inspect head grooves I would of slammed it back with a new o-rings and afterwards would be like🤔 I was suspicious though, because when disassembling I figured by the head bolts that the head was done before, and when I inspected o-rings they were flexible an in like new condition. Previous owner must of bin frustrated for not fixing it and sold it
found it when googled in Spanish, I thought it was discontinued or something🙄
What carb is on the bike? Should be a pwk, but old enough it could be anything.
This bike is based on a 125 frame , the 125 was a very popular TY version in France as it was a road going Trial motorcycle , the frame had a lot of extra weight because it carried lots of extra lugs and brackets to take all the street bike rubbish like indicators , ignition switches ,battery etc unlike the much lighter competition version that the TY175 was/is . Here is some inspiration if you want to take ownership further. https://youtu.be/b2fMtHB2bv0?si=EsqKQCv7u5ZNV
I highly recommend the Trial Solutions levers and they do fit Beta. You’ll love them!
It’s called Bultaco Bootlace Yellow and you can order it from here: https://www.rsbikepaint.com/oem-matched-motorcycle-paint-colour.php?locale=en-US&rs_colour_order_ref=37337
Yes, it would! It’s standard size just a smaller engine.
OK, I found one more next to it and next to a muffler mount (photo1),it was almost invisible util I started digging into it.... next one in line further away from muffler mount (photo2).
New throttle put on, cable oiled and free as a daisy
Could the cable be the colprit
https://www.yamahaty.com/english/ty125en/technique125en.html This site may help :
Any one have a head to sell?🤕
The moment I read your comment my friend I had that feelung, flashing images in my mind that I could not see anything wrong on old o rings. So after ansvering first I imediatly took my magnifying lens. And voila...😢
Great point! Thank you for advice. I will inspect. I was just checking if the head is flat, while waiting on o ring shipment. Managed to take a head off no problem. Accept Ossa manual says that the bolts are T20 and they are T25. Also wanted to comment about a muffler. I mean, even though I really respect Ossa's designe team work in many ways, making muffler into a prying tool for an engine head is such a bad idea. I am seriously considering doing some mod to dissconect muffler fron an engine.
mcman56 started following Holding revs really bad beta 250
Does anyone have any info on the dimensions of the TY125 majesty. Would one of these be useable by an adult.
redandwhitebrit started following Bultaco Alpina 138 paint code/color
I am nearing completion on the restoration of an Alpina model 138 and am looking for the paint code, or the name of the orange/yellow paint on the side covers, and the swoosh on the tank. Any assistance or insight is appreciated.
Deant23 started following Holding revs really bad beta 250
Good afternoon, I have a 2011 beta evo 250 2t. Had it for a couple of years now. Having s issue where when I rev it, it can take ages to come back down. I have tried messing with mixture screw and doesnt seem to make any difference if 2 out or 3/4 out. I have had the card apart and clean all indivicdual components with carb clean. Again no difference. I have tried to spray brake clean at intake system to see if it revs it doesnt change. Am I right in thinking this could be the crank seal? Or am i barking up the wrong tree? Also its does idle fine. TIA
Deant23 joined the community
doghead joined the community
I have most of a 1968 B44. The main thing I don't have is an engine, and these engines seem hard to find. Would a Triumph unit twin fit into that frame without too much trouble?
I would have thought that 28 was a bit big, but give it a try it will probably close as is.
Youtube video is live if anyone cares to watch! Figured this may be better since I'm out of photo uploads. Part two coming soon.
