- Past hour
eddie70 joined the community
- Today
kwackerzak started following Scott trial - Rucksack or bum bag
So I’ve signed up for the Scott trial this year, and can’t decide whether to use my camelback rucksack or purchase a bum bag. All I plan on carrying is a drink, energy gels, tyre plugs & tool, few bolts, couple of Allen keys, phone. What are people’s thoughts on comfort/practicality between the 2? Edit - I’ve looked at fender bags, but they don’t offer a way of carrying a drink.
tommybuildsbikes joined the community
Hey man this looks great i’m about to start a project of my own, do you happen to have a photo of the exhaust and airbox as i don’t have one and can’t find any online so hoping to source one similar
honda65 started following 300 One R Intake spacer and cylinder head insert
Hi, I was poking around through the parts manuals and noticed that the 2021 300 One R uses an intake spacer between the reed cage and case. None of the newer 300s of any configuration runs one. It does seem that the 2021 250 and 280 run it as well. I know that use\d to be a trick back in the day to get more bottom end but why remove it? And on the same topic, I also noticed the the head insert for the 21 (&22) One R model is different than the newer ones. However the insert for the 21 & 22 One R is the same for the One RR. The newer One R inserts have new part number and are called low compression So my question is this: has anyone messed around with the reed insert, mainly removing it? And does anyone know if the 21 & 22 insert the same comp as the S3 hi comp one? S3 lists the same hi comp insert for all the 300s except the Gold Did any of that make sense?
Greenland motocross had one and i got the front disc from italy
This link shows the many Lifan engines produced: https://gzbawo.en.made-in-china.com/product-group/lqKanTtOOzcr/LIFAN-engine-1.html Search in your own country, but this is an example from the USA: https://www.amazon.com/CUBELLIN-200CC-250CC-Motor-Engine/dp/B0D81ZTJDH
Hi i dont really know the lifan motor. And the previous owners say its was 200cc. And i hav thinking just get another engine from gasgas 250ccm. If i fine it somewhere 🥴
You are probably not going to find much information about that enduro bike (?) on a trials forum. It appears to currently have a Lifan motor (which is a Chinese copy of the Honda XR100). Lifan built them in a variety of sizes up to about 200cc. You can measure the bore and stroke to determine its displacement. Have you considered that it will cost more to repair that bike than it will be worth?
Unfortunately, it likely seized. Start by draining the coolant and removing the head to inspect the cylinder wall. It's possible to remove the cylinder and piston as a unit without removing the engine from the chassis. Of course, you must first remove the piston pin.
- 1 reply
- 1
Glatisant started following 2016 Explorer starting problems after fuel shortage and Fiat Ducato with bike holder
A converted bike holder (brand Eufab) sitting on the car coupling. Total cost: ~40,- Euro
Hi Folks! My Explorer ran out of fuel on a 10mile road trip at about 45mph. After hearing a strange sound I immediately pulled the clutch and the engine stopped. After refueling I noticed that compression is lower than it was before but still present. I am worried that the piston seized as the engine doesn't start any more. Any ideas what I can look at before I start dismantling the whole engine? Thanks! Felix
Oset 16 36V - In series 18v Batteries or other options
konrad replied to skippydave's topic in OSET Electric Trials Bikes
It's certainly possible, but will require technical knowledge. The best place to learn about building small lithium-ion batteries is a forum devoted to electric bicycles. Lead-acid batteries have an energy density of 30-50 Wh/kg and specific energy of 20-50 Wh/L. Compare this to lithium-ion batteries, which presently have an energy density of 150-200 Wh/kg and specific energy of 250-670 Wh/L. The improvement will be dramatic! -
Talon was super-expensive plus 8 weeks delivery! In the end I found Adam Hodson (oneoffsprox@gmail.com) who made me one for a reasonable price and about 1 week delivery. I rode the bike for about an hour and very pleased with the change; it's taken the fire out of the blue map and made it much more usable (for me!) yet the green map doesn't feel noticeably more sluggish.
Trials is a niche sport so it's unrealistic to think that dealers can hold a stock of everything. Especially something like clothing with the vast number of permutations of style, colour and size. If they can get something in and then dispatch it to you in a few days, I think that's generally fair enough.
skippydave started following Oset 16 36V - In series 18v Batteries or other options
Hi All, Im looking for help for Oset 16 Lithium battery options. In Australia I am having a very difficult time getting my hands on a lithium battery for the Oset16. I have spoken to the Oset importer (under triumph now) and they had no idea what I was talking about which is a little concerning. But I have seen several posts of people wiring 18v drill batteries in series and having great success. I thought I would reach out to this forum and see if anyone can give advice about this being successful or not and what sort of range to expect. I can get more lead acid batteries but I was hoping to get something lithium for extended range so he can at least ride a full trial. Thanks in advance Dave
oddvar started following Gasgas help
oddvar joined the community
Hi im going to rebuild this. Can any won help me to identify what kind this one is? Year? Engine size?
Wully joined the community
Looking for a ty 80 tank if any one can help
Hola Sherpa71, espero que disfrutes y recibas muchos buenos consejos de los demás miembros del foro. ¿Estás cerca de la Vuelta a España? Me da mucha envidia si estás. ¡Bienvenido!
All back together . Will put back in frame and hope for a start .
I'm in the almost same situation .Gentleman working overseas left bike PB9101480 dormant . I've offered to get the engine started . Tomorrow we will see. I've been told there's a registered private plate .can anyone find it . Love the bike . Let's see tomorrow.
fiddler2 started following Barn find Sherpa, what is it?
DrGonzo21 joined the community
MCHardman joined the community
It's a pleasure to be part of the group. Greetings from Andalusia, Spain. Hola a todos, un placer formar parte del grupo. Saludos desde Andalucía España.
Sherpa71 joined the community
After a bit of the missus whining at IP they have now added bike hire to the event so you can still take part if (like me) you have an ICE bike or if you don't want to drag your bike all the way there.
2022 jbr 300. Would anyone please have the workshop manual. Thank you in advance Gary garydwall@gmail.com
