This stream auto-updates
  1. Today
  2. Colomer. Pronounced Colom air. I seem to remember Woody Hole starting this Colome rename for some reason known only to himself while doing the commentary for Bennett Trials Videos in the 1990s.
  3. Yesterday
  4. Not sure if this will help but having a slightly dirty potentiometer can act like that I would think. I've used both Magura and Domino on several bikes and I don't recall that either one uses a hall effect sensor. You can observe the "dirty" signal as an erratic ohm value when tested disconnected from bike. A 0-5k pot with three wires will read about 5k ohms between two wires regardless of twisting position. The third wire is the signal where you would observe the erratic resistance across it and either of the two other wires. Its a simple metal wiper (signal) that moves across a fixed wire wound 'fixed' resistor. But it could be a hall type non-contact also used a lot. I've seen quite a few 'dirty' reading throttle pots and they usually are near the lower throttle position, likely due to more wiping at low throttle.
  5. I talked to Dirt Riders and told him BS i got from seller(you have to let the clutch warm up before it will disengage) He had heard it before and told me 1. crankcase had been contaminated or mixed disk was not installed or installed wrong. Waiting on a clutch now
  6. Yep i knew it is 301 iv’e got the parts book just thought that number majesty gave me inthe link cross referenced, your right tony it doesn’t fit they’ve got back to me, i must be able to get one from somewhere last time i tried sherco themselves they didn’t even reply🥴 anyone else got any ideas?🤞
  7. Link to parts books from Splatshop SE 4.5i-F * 2006 Looks like you're after part number 0301 which is nothing like what is used on the trials bikes Stand Holder End 450 this should be the part
  8. Thanks majesty for the link, iv’e just messaged them to confirm it fits cheerz mdeerzp
  9. Last week
  10. Send a self addressed envelope to Vertigo?
  11. I have a Montesa Cota 248 trials bike, frame number 21M51469 and am trying to find the age of it. Does anyone know how to age this?
  12. I used to see Jon at trials in the Cotswolds (of course!) but I've not seen him for at least a year. Maybe he's retired from trials stuff.
  13. Hi, I’m looking to purchase an autograph of Marc Colome for my collection, does anybody know where I could get one. Thanks
  14. The few bikes I have had a go on with different engine modes didn't really ride a lot different just had the power come on stronger in a different location in the RPM range. Just for consideration. (never had a go on a Beta with an S3 Header and Arrow so can't speak to that exact setup though) Good luck. PS. Best trials bike modification I have ever had a go on was suspension setup for myself.
  15. https://sjtrials.com/products/scorpa-sherco-side-stand-mounting-bracket?variant=41853210919096&country=GB&currency=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&utm_campaign=gs-2021-11-04&utm_source=google&utm_medium=smart_campaign&gad_source=1&gad_campaignid=17518251023&gbraid=0AAAAAoPT6PwM-ICXcC_BptMHV5Lxxs_l2&gclid=EAIaIQobChMItOjUs-ubjwMVXpFQBh1LdwJYEAQYASABEgLA8fD_BwE
  16. There is an axiom from motorsports that success in auto racing is 75% car, 25% driver. In motorcycle racing, it's more like 25% bike, 75% rider. I would venture a guess that in trials it's 10% bike, 90% rider.
  17. Hi, I’m struggling to find the bracket for my sidestand it’s for a 2006 450i enduro any ideas please? Iv’e tried splat shop, malcom rathmells, ebay etc, hope iv’e posted in the right section cheers mdears
  18. Sbrown
    mr bill brown
  19. Anyone selling a Bosi Arrow exhaust system for a Beta factory 200 24 model, Chasing info if the aftermarket S3 header pipes make a difference to performance
  20. Hello , i am 62 and did championchip trial last year for West- Flanders in Belgium and ended secont nationals....!!!, but i ride almost all my live...
  21. ukbta
    Newbie
    Based in the West Midlands area. Will be doing a little poking around the area soon. Thanks, makes me feel better knowing I am not the only one that thinks growing up is optional, I was expecting many youngsters. I'm a little over 15st - or as I like to put it: 'I once had a six pack - now I'm older I can afford a barrel' I'm probably being harsh on myself, but was always fairly trim until I had the spinal injury which changed things being laid up so long. Came from a Speedway line from young, so bikes were in the blood. Still associate the smell of gunk with speedway bikes in my uncles garage.
  22. RonH
    Newbie
    Ukbta, welcome! I’m 64 and took up trials again three years ago after a 45 year gap. I’m not fat though but you make it sound like it’s fun. I may give it a try myself. Also, my friend from high school, just started up again too, and he is fat and is enjoying riding again immensely. We met up up in the Owyhee mountains in the Idaho desert just a month ago to relive old times. We had a great time! No, we’re not experts at all but it’s still a blast. Give it a go!
  23. Welcome ukbta. Where do you live? You may find there's someone on here that is close to you. It will also help us guide you on questions like dealers, practice areas, etc.
  24. Use a wall anchor and keep the bike as tight to the wall as possible. Keep the chain tight and as short as possible through a frame point and around the wall anchor. If you do it correctly, it should be as difficult to access as possible - even to lock and unlock. Keep an chains to ground anchors off the floor and tight, as that makes bolt croppers more difficult. A loose chain allows the cropper handles to be put on the floor and pressure applied to pop it, a tight chain means the croppers will need to be used with upper body strength alone, like an eighties Bullworker - star of many home video howlers. Good quality locks can be used to take the brunt of any attack. Abus do some good locks that are great for rear sprocket (discs not acccessible on most trials) - smart ones will notify you if they are activated, the Victory is just a PITA as it just spins - all of it, in all directions. All are grinder and impact resistant. A decent home chain is ideal, 16-22mm is best. Make sure it is hardened or tungsten carbide. Abus D Locks are tungsten carbide and both those and the victory/smart locks can be used with chains, making the chain alarmed. Kovix also do a similar set up with a cable designed as a 'quick' lock but will also work well with a smaller chain. The essential advice, is be creative - use as many locks as you can be bothered to unlock and DO NOT trust your garage doors - they are torn open in seconds! You can look into reinforcing up and overs, using frame dead bolts to prevent this, but there is olnly so much you can do. Asgard Security Sheds are getting pretty good now and as expandable, as we all knows bikes multiply in the night through no fault of our own.
  25. Just wanted to introduce myself. Looking at getting a trials bike. Probably too old, too fat (that could be a franchise film with 200 sequels I am sure) but need to get fit and wasn't allowed one when I was a kid (Junior Kickstart for those oldies out there, might remember). Got back on a bike a few years ago after a long time learning to walk again post accident. Thought, what the hell - do it before the joints completely give out. I remember a friend that did MX, and there was always the old fat bloke at the back that was 65 and they all respected him and gave him space as he was having his fun and riding his own race. That will be me, no doubt. Work wise, I work with a charity in the motorcycle industry, so if you have any theft related issues - feel free to give me a poke and I will help where I can. Not had much to do with 2 strokes or trials bikes, but build plenty of road bikes in the past. Be prepared for many, many, stupid questions and head slapping moments.😁
  26. Hello everyone, New EM owner here, picked up a used 22 epure race couple weeks ago. What a fun bike, been having a blast with it. Although I have one issue that I cant figure out, went through this forum and haven’t seen a similar issue. When riding the bike for a bit randomly it will start to hold revs sort of similar to if the TKO is turned on even tho it is not on. If I hold in the clutch and release the throttle the revs will very slowly come back down very similar to a lean condition on a ICE bike. But With no clutch engaged the bike does not pull or want to inch forward. It will do this in all 3 maps. Then after a little while of this if I pull the kill tether and reinstall it, the bike will just make the map switch tone over and over again non stop. I can change maps but the throttle will never come back to life. I can turn battery off and on and still the tone keeps going. I have to turn the battery off and let sit for 5-10 minutes and then it will start working normal again. I have done the recalibration deal of holding map switch for 10 seconds and the rear wheel spins 3 times but after its done the tone just keeps going. Im guessing it has to be a throttle issue? Its the domino throttle. The wires look fine, connection at the plug is good, wires dont pull tight when steering lock to lock, throttle housing isn't beat up and throttle tube turns nice and smooth and snaps back quickly. But im guessing it has to be something wrong with that throttle? Oh and bike is not equipped with the PRB lever. Just wanted to see if anyone has an opinion before I go spend $200 on a new throttle. Any help is much appreciated. Thanks
  27. Time Left: 24 days and 11 hours
    • FOR SALE
    • USED
    2024 Beta EVO 200 Road registered Forks and rear shock removed when new so unused 250 flywheel fitted - original also supplied Mature clubman owner Well maintained Steve 07414059900
    4,150.00 GBP
  28. @lemurIf the rims are anything like most TLR's i've seen the outside looks ok but the inside has become a sacrificial anode and just flakes away.
  1. Load more activity
