I'll be even more convinced if someone can give me a reasonable explanation of the current path...
Current path being to the ground via your thumb and feet which i imagine were on the ground when you were stopped. Soaked clothing and boots i imagine would greatly reduce this paths resistance. Where does the lcd negative line go or is it earthed to the bars?
I'm guessing ankle injuries are probably fairly common? Are ACL injuries common? Shoulders? Clavicle? Shoulder AC joints? Facial injuries?
I don't think any of the above occur more frequently than in any other sport tbh. Theres a few pros who ride with knee braces (ferrer, farre etc) Theres also wrist injuries, specifically the scaphoid. Some american and Japanese riders ride with full face motocross helmets, but in my area ive only known one person to fall and lose a tooth in 20 years riding
probably on the minimal side regarding mtb knee pads but they fit no problem underneath. All depends whether you go down the tight fit route or the slacker fit.
I know the tighter fitting mots trousers have knee pad inserts that fit into a pocket inside their trousers,
Todays trials trousers seem to offer virtually no knee protection and rely on separate knee padding. Im the same as brucey and wear MTB knee pads underneath my trousers
The only differences between the 2 are the keihin vs dellorto carb, marzocchi vs tech front suspension and the sachs vs ohlins rear suspension.. Engine and frame are indentical performance wise, minus the keihin providing a little better carburettion. Up to you, but anyone but an expert rider will not notice the differences of the suspension.
It is 100% not 2017. The tank, forks and swingarm are definitely 2011. For that age id price it around 2k, but lately with covid, bikes are getting silly money
Thanks for the response. Regarding the clutch, would that be a case of worn clutch plates?
GG clutches have a tendency to swell over time, so if not in spec they are more than likely draggy. A clutch that slips would be an indicator of worn plates.
Although a relatively easy fix, check that the clutch doesn't excessively drag or slip. And if it has mag cases check they aren't cracked at the bottom engine mounting. Maybe a test ride and make sure it gets all the gears but don't be alarmed with a clunk between 4th and 5th. Also check the petrol tank isn't leaking where the tap is fitted. After that, just the usual stuff. From 2011 till now you won't find much difference between how they ride. The techs are a slight improvement over the marzocchis, not much, although the early tech gold coating wore very quickly and looks a little unsightly
Ever since they went to the plastic end cap the exhaust has been a PITA to pack since the split is halfway down the silencer. Personally i prefer the stuff that comes in the mat (i use stuff that is a looser mat than the oem stuff), but good post nonetheless 👍 ill have to try mine without the wrapped mesh next time
Just a heads up for anyone needing to modify their clutch pack. 9.75-9.85 is quoted so often i recently modded my 2018 clutch to around 9.80 then found this information the next day.
which says that 9.8 would be beneath spec for the newest bikes. I didnt think the clutch changed so much over the years. Take what you want from it, but just a word of warning that the often quoted 9.8 may be going too far especially if you decide to sand down your fibres.
Still don't know why they don't make 1.9, 1.8 1.7 mm thick plates
I don't think you can blame the pandemic on a lack of news reporting. When the world champion breaks his leg and it isn't reported here, i think the OP has a valid point.
Whatever the reason, id say 80% of the time i come here for the forums anyway, but it is nice to read the odd recent news article as well.
Facebook is where its at unfortunately, easier access, but then its also easier to access some bloke wanting to advertise his second hand set of golf clubs on the groups FB page. There never seems to be a successful FB group page for trials that has functioned like a forum. Ive yet to find it anyway
Does Honda Montesa make parts anymore? Dealer has had my bike for 8 months, waiting tappet
in General Trials Talk
Can you not source a second hand part?
