September 12, 200719 yr I'll send you one, but the post will exceed the 2 quid for the part with the new postal regs. PM me as I have 5 of them for r&d and feedback. Purely nonprofit!
September 12, 200719 yr Are we going for a World Record with this "Sherco Virgin" thread as it does appear to have gone down the path of covering every single thing there is to know about Sherco's? I need that much memory to store this thread that I will need a new computer shortly!
September 12, 200719 yr Author Ah bugger................your right..............sorry John, maybe it is time to end the World record attempt, that Xispa thread will take some beating anyway as ive run out of things to post on the Caby now and I'm only waffling and padding last few pages. Its been a great journey though,few problems to start with but all seems to be coming together nicely now, just think though............if I had bought a Gasser the thread might have been 30 pages or more. Thanks Mark, I'll pm you tonight about the bearing mate
September 16, 200719 yr Copemech / Addict I heard today that the Boyesens can break after a while , have you had any problems and how often do you change them ? to be fair this was from I guy that used to do moto cross and I think it was on a motocross bike not a trials bike.
September 16, 200719 yr Author Ahhhh!!!!! It still lives!!!! Not heard that Glen? had them in my Beta for ages with no probs and nothing wrong with the Caby either, if they did break after a while i think someone would have said by now, wait and see what cope says though
September 19, 200719 yr Just to keep us going Justin did you ever take the flywheel off your bike and see if the two map ignition can be retarded by moving the stator or is it fixed ? anybody know what the reference c4 means on the end of a bearing number, the sherco mains are c4s, i think C3 has more bearings which are smaller than standard but I dont know what C4 is ? cheers
September 19, 200719 yr Author Not had the flywheel off yet soz, but will have a look next week as i am definately noticing the caby abit of a handfull in the streams and rocks up north, if i can retard the timing ok I will give it a go and let you know. The 2 stage switch is nothing but a pain, had it taped up since i had the bike as it runs **** on map 2. Bike down here though power wise/grip is spot on but very noticable getting away from me in the streams which I mistook at first as the bars being in the wrong position Sorry John B, Cope and Baldilocks are padding now Edited September 19, 200719 yr by The Addict
September 19, 200719 yr Baldi, The C3, C4 refers to the manufactured clearances of the bearing. Things must be able to move you know, and carry a boundry layer of oil! If that switch is not worth it, I would be tempted to hardwire the thing and chunk the switch! Or maybe hide a micro switch under the tank! Edited September 19, 200719 yr by copemech
September 19, 200719 yr Yep, I am pretty sure the numbers will equate to .001 inch each, or in other words, a C3 will have .003 in. standard clearance when new. Seems I recall that the main bearings in the later model Sherco's are running some type of ceramic material or coating as well. If I were going to the trouble to replace them, I would stick with the factory parts rather than a generic match to save a few quid! Might be better off in the long run. There are just some things that I only want to do ONCE!
September 23, 200718 yr Just, John.B? That's not Bliss is it? Had a good outing today, working some setup for our regional event. Lots of big up's and down's on a dry sand and rock dusty loop with lots of rollers to throw you! Tough stuff where the rear is hard to control going downhill. All I can say is the darned thing works so well that once again, the lost motion issue and increased sensitivity may cause me to start hitting the rear disc with a bit of the overspray of the WD40 when cleaning the bike! Just very sensitive!
