November 24, 201312 yr Fitted jitsie lanyard kill switch to my new Mont 260 and most times I use it, it doesn't stop the engine, sometimes it takes about 10 seconds and a few times, it's actually continued to run even though the lanyard has been removed. I've taken it apart (easy) to see if there are any obvious problems, but it's still happening. It's not an isolated case either, because my Bro's, which was bought at the same time is doing the same thing. The worrying thing is, we bought them, so as to have that instant "engine stop" when it was needed, but it fails to do this. On my previous 4rt, I had a Leonelli Branded lanyard and never had any problem. Has anyone else had any problem with there's? Edited November 24, 201312 yr by jj65
November 24, 201312 yr I also have a 2 Leonelli's that work perfect, but if you've got two Jitsie switches with the same problem, there's a fundamental problem with them, you should get new ones or your money back i.m.o. Edited November 24, 201312 yr by guys
November 24, 201312 yr I also have a 2 Leonelli's that work perfect, but if you've got two Jitsie switches with the same problem, there's a fundamental problem with them, you should get new ones or your money back i.m.o. same they have got to work
November 25, 201312 yr Author I would bet they are not wired in the right place and/or poorly grounded. Wired into original using torpedo connectors and same earth, but I'll have a look at that later.
November 25, 201312 yr You can buy a multi meter cheep today It will answer your questions like the internet never can
November 25, 201312 yr Hi, I've had a Jitsie lanyard switch for 10 months or so and it works every time,quick as. I'm afraid to say that I test it all to often. Cheers Taff.
November 25, 201312 yr Author BVM, "no worries, we'll send you some replacements" thanks Rick :0) By the way, the ones causing problems are the new type, with the flatter red cap. It maybe just be me, but the magnets don't appear to be as strong as the one I had before. Edited November 25, 201312 yr by jj65
January 10, 201412 yr The only problem I have with the Jitsie lanyard is it to stretchy and does often not come off when I fall off.
January 11, 201412 yr Mine is too stretchy now also now that its got old. I'm gonna have to buy a new lanyard bit without the switch. Maybe it can be shortened by tying some knots in it.
January 11, 201412 yr If you put it around your wrist twice it takes out the slack and also helps stop it catching in the stray twigs and bushes as you are riding.
January 18, 201412 yr I also had a problem with a Jitsie lanyard. Sometimes it would work and other times it wouldn't. After having it replaced I took it to bits. Inside there is a little rubber washer which had a little crease in it ( must have been assembled wrong ). I took it out and gave it time to unfold and once done re assembled the thing at it worked perfect every time. Worth a try if you can't find your receipt or retailer doesn't want it back.
