azaz Posted May 27, 2016 Report Share Posted May 27, 2016 Thinking about buying either a new gasgas factory 300 or a sherco factory 300, anybody had experience of both? which would you recommend? Reliability,performance, maintenance ect... cheers! Link to comment Share on other sites More sharing options...
jonnyc21 Posted May 27, 2016 Report Share Posted May 27, 2016 Haven't been on a 300 but between the Gas Gas's I have been on (125,250,280) and the Shecro I took a spin on (250). I like the transmission on the Shecro better. Even owning the Gas Gas 125 (wife's bike) I have just never been fond of the 4th gear to 5th gear shift on the Gas gas. That being said, if you can take a ride on both or at least something close in year and size (250 or bigger) I would think that would tell you miles more than my opinion. Best of luck! Link to comment Share on other sites More sharing options...
heffergm Posted May 27, 2016 Report Share Posted May 27, 2016 (edited) Unless you're talking about a leftover 2015 GasGas factory that you found, there is no new GG factory at the moment. GG has been busy going out of business, coming back to life, and skipping a model year in the process. I assume at some point they'll release a 2017 factory model, but probably late this year (complete guess on my part). As for Sherco vs GG: - the sherco is blue and yellow. You may find this horrendous or the best thing since sliced bread, so let your aesthetic preference be your guide (I mention it because I think it's hideous) - as the above poster mentions, the GG transmission is great from 1-4, but 4-5 is like shifting a two speed differential... be careful or it feels like it might explode. I suspect it's more durable than it sounds, but it's not a pleasant mechanical feeling. - I think the GG has the best clutch by a long shot. This makes up for the transmission to an extent. - I think the GG engine is better engineered, which is to say, they didn't do something stupid like use a ridiculously small bolt for the oil drain plug that blind threads into the case (sorry, I'm still bitter). Anyway, ride them both and decide for yourself. Everyone's experience is different. I do find for myself though that I just feel a lot more comfortable on the GG than I ever did on the Sherco. If GG would put a nice 5 speed in it, and maybe beef up the steering stem it would be perfect... oh, wait, that's a TRS... Edited May 27, 2016 by heffergm Link to comment Share on other sites More sharing options...
smarty156 Posted May 27, 2016 Report Share Posted May 27, 2016 I don't like 5 speed gearboxes and I just feel comfortable on a GasGas so that's what I have. 1st to 4th are all very close together on the GasGas so you're unlikely to ever be in the wrong gear in any section. Tried a Sherco and it was actually pretty similar to the GasGas. You need to try them. 1 Link to comment Share on other sites More sharing options...
heffergm Posted May 27, 2016 Report Share Posted May 27, 2016 1st to 4th are all very close together on the GasGas so you're unlikely to ever be in the wrong gear in any section. This is certainly true... I made the mistake of starting a section (twice!) in 4th gear. It started with a pretty technical hill climb in the dry (i.e. normal first gear stuff). I got away with it the first time, and only dabbed once the second time. My 250 is also pretty ballsy, which helped. Although all this could have been alleviated by my not being an idiot... Link to comment Share on other sites More sharing options...
wmc37 Posted May 27, 2016 Report Share Posted May 27, 2016 The Scorpa factory is very nice Link to comment Share on other sites More sharing options...
heffergm Posted May 27, 2016 Report Share Posted May 27, 2016 If it comes to Scorpa vs Sherco, I'd definitely go Scorpa. Link to comment Share on other sites More sharing options...
dadof2 Posted May 27, 2016 Report Share Posted May 27, 2016 http://www.ebay.co.uk/itm/ALL-NEW-2017-GAS-GAS-TXT-300-RACING-ORDERS-TAKEN-HERE-NOW-/231856960842?hash=item35fbc0754a:g:OOAAAOSwl-FXNaAx Link to comment Share on other sites More sharing options...
smarty156 Posted May 27, 2016 Report Share Posted May 27, 2016 http://www.ebay.co.uk/itm/ALL-NEW-2017-GAS-GAS-TXT-300-RACING-ORDERS-TAKEN-HERE-NOW-/231856960842?hash=item35fbc0754a:g:OOAAAOSwl-FXNaAx That's just the standard Racing, not the Factory rep. Not heard anything about a Factory GasGas yet. Link to comment Share on other sites More sharing options...
mirko91 Posted May 29, 2016 Report Share Posted May 29, 2016 There's no GG factory, just racing. The la St Factory Replica is the 2014, but the last model is the same as 2014 factory just with the Reiger 2 way instead of 3. I will go 100% Gas Gas? Link to comment Share on other sites More sharing options...
crazybond700 Posted May 30, 2016 Report Share Posted May 30, 2016 This is certainly true... I made the mistake of starting a section (twice!) in 4th gear. It started with a pretty technical hill climb in the dry (i.e. normal first gear stuff). I got away with it the first time, and only dabbed once the second time. My 250 is also pretty ballsy, which helped. Although all this could have been alleviated by my not being an idiot... I (almost) never use first. Link to comment Share on other sites More sharing options...
nigel dabster Posted May 30, 2016 Report Share Posted May 30, 2016 Thinking about buying either a new gasgas factory 300 or a sherco factory 300, anybody had experience of both? which would you recommend? Reliability,performance, maintenance ect... cheers! Give A G Bikes a call he has shercos and gassers in stock. Link to comment Share on other sites More sharing options...
stpauls Posted May 31, 2016 Report Share Posted May 31, 2016 If it comes to Scorpa vs Sherco, I'd definitely go Scorpa. Same engines. Link to comment Share on other sites More sharing options...
heffergm Posted May 31, 2016 Report Share Posted May 31, 2016 Yeah, but one is gross blue and yellow and the other one isn't... 2 Link to comment Share on other sites More sharing options...
steve_earle Posted June 1, 2016 Report Share Posted June 1, 2016 If you have to ask the question, your looking for the wrong type of bike. You need to be a very competent rider for these models especially the sherco factory as it's an animal with a unique long stroke engine from the std models. 1 Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
