guys Posted July 12, 2016 Share Posted July 12, 2016 Ok for a straight road, to much leverage for sudden manoeuvres. Believe me, it doesn't move an inch. Quote Link to comment Share on other sites More sharing options...
iconic558 Posted November 9, 2016 Share Posted November 9, 2016 (edited) Bit late to the party but these bike chocks are brilliant, fantastic, excellent et al.Originally bought for my road bikes for track days as strapping down and securing sports bikes with fairings is a real chore to avoid damage. It really is one of those items I wish I'd bought years ago.They start at £30 ish but heavy duty ones are £45 as used for my GSX-R750, Firestorm etc and bolt onto the floor. In fact they work so well it only requires two small straps just for piece of mind. Picture below is similar but mine has two securing mounts up front but you get the idea http://www.ebay.co.uk/itm/301071174223 Edited November 9, 2016 by iconic558 1 Quote Link to comment Share on other sites More sharing options...
guys Posted November 12, 2016 Share Posted November 12, 2016 I'm currently trying this system out. Makes it able to put the bike very close to the side, so there's more room for other stuff. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 12, 2016 Share Posted November 12, 2016 Probably the quickest and easiest system i ever came across was Munch's one (the late departed M Sport motesa guru) which attached a small bracket to the wheel arch similar position of bike to the old Bulto above. The bracket was a couple of inches below normal footrest height so the bike was compressed on suspension to fit under then a captive bolt was dropped down through footrest hole. excellent system so simple. 1 Quote Link to comment Share on other sites More sharing options...
tugg Posted November 14, 2016 Share Posted November 14, 2016 Although new to trials I'm not so new to strapping bikes in back of vans, personally I don't like compressing the forks for long periods, I've seen a few premature seal failiures myself. if on a trailor I would use something similar to Michael t's solution,acerbis actually marketed something like this about 2o years ago. If in a van I would just simply stand bike beside the inside of the van and point front wheel towards the side its leaning ,I would use one strap from a secure point on the van side above handle bar height to the outside grip and back to another point on side of van. trick is to wrap the excess from the strap around the front brake lever aswell ,I used to load 2 bikes like this and would only take seconds and never budge Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted November 15, 2016 Share Posted November 15, 2016 I find it hard to believe that compressing the forks sufficiently to secure a bike generates enough pressure to cause seal failure. The rear suspension on my mountainbike (essentially the same setup as a front fork in terms of seals etc) runs at 180 psi, before any compression. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted November 15, 2016 Share Posted November 15, 2016 When I have seen for seals leak from compression is only when already near failure or dirty. I am not saying you should or shouldn't compress them, I like the idea of having some way to hall a bike and not have to worry about that. Just haven't ever seen issues if the seals are good to begin with. Quote Link to comment Share on other sites More sharing options...
tugg Posted November 15, 2016 Share Posted November 15, 2016 maybe its more of a problem with usd forks than conventional forks , but yes if the seals and bushes are not in good condition you will find out sooner than later strapping a bike down. Quote Link to comment Share on other sites More sharing options...
johnnyboxer Posted November 16, 2016 Share Posted November 16, 2016 If you use those front wheel chocks/stands previously mentioned then you only need to barely strap the forks at all, just a token effort The Stands are similar to the price of a set of fork seals Plus you can use them in the garage,box trailer or van Just saying 1 Quote Link to comment Share on other sites More sharing options...
