May 24, 20179 yr no one should, you could, but i wouldn't want to depends on how you might intend on fixing it, with say a car tyre and a car puncture repair, you drill out the puncture and then plug. This and/or the original puncture undermine (critically) the structural make up of the tyre. in trials use at low PSI this may not lead to catastrophic tyre failure like in a car being used on the road, but does low pressure trial work lead to more stress - beyond my knowledge check out the national tyre dealers association 3 page pdf on puncture repairs - http://www.btmauk.com/wp-content/uploads/2014/12/Minor-repairs-to-passenger-car-and-light-van-tyres.pdf Edited May 24, 20179 yr by rabie reference
May 24, 20179 yr Plug it, use multiple strips (dog turds) to plug larger holes. May leak a little or completely fix it.
May 24, 20179 yr Cabby my wee Scorpas run with the old dog turd strip in it for months right on the outer edge of the sidewall too.
May 24, 20179 yr Author Somebody punctured illegally riding up glenshee at the weekend breagh, if I catch them I'll have their guts for garters
May 24, 20179 yr Done it a couple of times, no problems. No reason why you shouldn't if your not using it on the road.
May 24, 20179 yr I practice on tyres with cracked sidewalls, using an inner tube. No issues with loss of integrity of the sidewall or from the tyre collapsing, so go for it if you can effect an airtight seal (or use a tube). Would be a shame to bin a near-new tyre. Edited May 24, 20179 yr by cleanorbust
May 24, 20179 yr Author My tyre man refused to do it due to being a sidewall but allowed me to fit it while he just removed and fitted tyre....top man, sorted. Edited May 24, 20179 yr by cabby
May 24, 20179 yr In my experience with an off-road tire as long as its the tubeless option it isn't a problem to patch a side wall. However because of the way the forces are applied just don't expect it to hold as long as a center puncture patch might. On that note, a trials bike and riding stile should give you the best chance to ride much longer than the average endure or MX bike might. Hope it holds well for you.
May 25, 20179 yr 8 hours ago, cabby said: Somebody punctured illegally riding up glenshee at the weekend breagh, if I catch them I'll have their guts for garters Quite right it's a national disgrace and while I'm on have you ever seen a hill walker smile? Here's another one have you noticed that ever acre of sloping wood land now has a makeshift downhill MTB track on it.This envolves moving tons of soil cutting down trees and geneally depositing a wide selection of litter througout, Can hardly get the Ossa down some of them.
May 25, 20179 yr 9 hours ago, cabby said: Somebody punctured illegally riding up glenshee at the weekend breagh, if I catch them I'll have their guts for garters Thought you preferred Skye
May 25, 20179 yr Author 13 hours ago, johnnyboxer said: Thought you preferred Skye What are you talking about man
