February 9, 20206 yr I’ve just purchased a gas gas. It’s 1999 model? My question is what model is it? The plastics say it’s a 280 but I’ve got the v5 T Reg but it says it’s a 258cc on the v5 znd help would be great full and then I can try and find a manual do I know what oil amounts and so on thanks for any help and advice
February 9, 20206 yr All Gasgas manuals are available on their website, though I think the older ones are only in Spanish.
February 9, 20206 yr I doubt you will find a manual for your exact year. Follow https://gasgas.com/en/manuals?c=trial&y=2002 for a 2002 manual. Should be the same and will have the oil quantities that you want. Your model is a TXT, not a TXT pro, a TXT. Edited February 9, 20206 yr by faussy
February 9, 20206 yr Author Thanks for you’re help guys.. there’s a number on the frame? It’s a sticker but would give me the engine size? I’m thinking it’s a txt 270 but says 258cc on v5
February 9, 20206 yr Vin number should be stamped on headstock.and the 99 was a TXT Edited February 9, 20206 yr by Bilko
February 10, 20206 yr 13 hours ago, huski said: It is 258cc,it was called a 280 for some reason Same as a 290 Sherco was 272cc. Never understood why they didnt just call them a 270cc, I assume it is the mines bigger than yours thing.
February 10, 20206 yr Author Thankyou all for you’re replys? The manual is a greT help.. ive got the v5c/2 part of the v5, but I’m sure that this is his copy and not what I send in. I’m not to bothered, it just to get the full log book in my name. The vin tag on the headstock has a gouged out of it as the headlight bulb has rubbed on the plate. Edited February 10, 20206 yr by Teddydanson
February 10, 20206 yr I'm glad the manual link was useful. If you've bought the bike then the seller has to post off the main / front page of the V5, and you should just have the little green slip. If you got the whole V5 then just fill out the "inside cover" yourself and post it in without telling anyone Is it just a little bit of the vin rubbed off? Because if it's more than a little bit that could cause you problems - when riding green lanes it's not *that* unusual for police to check a bike is properly legal, and a fully / mostly scrubbed VIN number could be a problem.
February 10, 20206 yr The 1999 model 258cc was called a 270. It changed in 2000 where it was called 280. In 2002 the TXT pro was released alongside the old TXT which was now called the Edition. The pro had a different frame and engine. The main difference between the 99 TXT and 2000 TXT was that the 99 had a rear subframe and the 2000 did not. To fit this the rear mudguard/seat on the 2000 was in 2 pieces where as the 99 was one complete unit. Hope that helps
February 10, 20206 yr Author It’s just the last couple of digits or numbers... it’s got 90% I’ve git a picture but pointless sending. I thinks it just one letter or number... he’s sending me the v5 now as he told me that I send the little slip off? But I didn’t realise that we both have to sign it. And I keep the v5c/2 for temp proof. Ive put the reg in online and it’s coming up as it is ? Model, engine cc, and colour
February 10, 20206 yr Author Thanks bumpy. There’s one fixing screw where the seat is under the tank on the plastic. And the plastic is one unit It just says 280 txt on the graffix and the vin says gg27991 do I presume 270 Edited February 10, 20206 yr by Teddydanson
February 10, 20206 yr Author It’s a cracking bike, and I’m not using on the rd. it’s for my lad. Just wanted to register it just in case plus insure it but im now thinking if I register it? Will I need to tax it or sworn it? Edited February 10, 20206 yr by Teddydanson
February 10, 20206 yr It is already registered. If you don't tax it or SORN it then you are committting an offence - I assume the previous owner will now have given your name to DVLA ? Always best not to upset DVLA - you don't want a visit and have them find what else you may have in the garage. Edited February 10, 20206 yr by 2stroke4stroke
February 10, 20206 yr Author He’s sending me the full b5 tomorrow by post? I presume by the v5c/2 slip I have it’s gad 2 owners so registered. If I don’t get anything off the guy? Which I’m not holding a lot of hope? Be he seemed legit , and honest...
