Robert n Posted March 7, 2020 Share Posted March 7, 2020 Is it a easy job to check them or best done at dealers Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted March 7, 2020 Share Posted March 7, 2020 A bit fiddly but patience does it. If there was such a thing as a ninety degree feeler gauge it would be easier. Access to the valve covers is fairly straightforward. There is a special tool to turn the adjuster but it can be done with an open ended spanner of the right size. 2 Quote Link to comment Share on other sites More sharing options...
misscrabstick Posted March 7, 2020 Share Posted March 7, 2020 34 minutes ago, 2stroke4stroke said: A bit fiddly but patience does it. If there was such a thing as a ninety degree feeler gauge it would be easier. Access to the valve covers is fairly straightforward. There is a special tool to turn the adjuster but it can be done with an open ended spanner of the right size. There is, just not widely available, Snap on make them, I had a set once. You can bend a normal one. 2 Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted March 7, 2020 Share Posted March 7, 2020 3 hours ago, misscrabstick said: There is, just not widely available, Snap on make them, I had a set once. You can bend a normal one. 90 degrees seemed a bit far to bend. I cut the end off a gauge, drilled it and put a screw through it but there was not really enough working space. An engineer pal sets Honda gaps by opening so much from no gap based on thread pitch, hence travel of adjuster, and has had no problems over many years. Can't recall what the pitch is. 1 Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted March 7, 2020 Share Posted March 7, 2020 Actually I've just had a thought. Something along the lines of the wire type spark plug gauge would be ideal as it would fit easily. Is it possible to get bendable wire of some sort that is made in an acccurate enough diameter? Quote Link to comment Share on other sites More sharing options...
jrsunt Posted March 8, 2020 Share Posted March 8, 2020 It's an easy enough job with normal gauges. You'll find that the timing mark on the generator cover doesn't line up 100% with the mark on the flywheel. When they are aligned you will still have tension on the rocker arms. 2 Quote Link to comment Share on other sites More sharing options...
markparrish Posted March 8, 2020 Share Posted March 8, 2020 17 hours ago, 2stroke4stroke said: Actually I've just had a thought. Something along the lines of the wire type spark plug gauge would be ideal as it would fit easily. Is it possible to get bendable wire of some sort that is made in an acccurate enough diameter? I don't know what gap size you are aiming for but maybe guitar strings could help?https://music.stackexchange.com/questions/33257/standard-guitar-string-gauge there are lots of sets available (different gauges). Most seem to be quoted in imperial sizes. The three thinest strings in any set are plain wire - the thicker three are usually a wound wire and wouldn't be suitable. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 8, 2020 Share Posted March 8, 2020 (edited) Just bend the ends of a normal set of feeler gauges . if your posh you can keep this a special set or if your tight you just bend back after doing the job. i think you only need 3 or 4 sizes to give you the variation you need on several monts I have found very little change in valve change in clearance even after several years use. Edited March 9, 2020 by jimmyl 2 Quote Link to comment Share on other sites More sharing options...
monteeman Posted March 10, 2020 Share Posted March 10, 2020 I would trust feeler guage more than guitar strings. they are cheap to buy so just bend the one you need...simple.... 1 Quote Link to comment Share on other sites More sharing options...
sportsawyer Posted March 11, 2020 Share Posted March 11, 2020 14 hours ago, monteeman said: I would trust feeler guage more than guitar strings. they are cheap to buy so just bend the one you need...simple.... There's also the feel of pulling the gauge that I like. The manual calls it "slight drag." Don't think you could get that with wire. For the intakes, Motion Pro makes a "tappet feeler gauge" (do a search) with 0.004" and 0.005". Works great. I also have the 0.006" and 0.008" and set intakes tight on the 0.006" so they're at the big end of the range. They don't make one in 0.012" for the exhaust. I've done as others mentioned and bent a 0.012" gauge leaf. I usually see more change in the intakes. And it's small. Usually only tighten about 0.001" every year or two. But I don't do the wide-open point-and-shoot thing much either. The more high RPM, the more you'll need to check valve clearance. 1 Quote Link to comment Share on other sites More sharing options...
section swept Posted March 19, 2020 Share Posted March 19, 2020 If you have one and can mount it in the right way you can use a DTI dial or depth test indicator. With the dti resting on the rocker..engine on compression you can rock the rocker and get a reading. Space is minimal and it is fiddly. The most important thing is to re check the clearance after tightening the locking nut. Bending a normal feeler gauge is the easy way to go. Quote Link to comment Share on other sites More sharing options...
oz thumper Posted March 28, 2020 Share Posted March 28, 2020 On 3/19/2020 at 11:55 PM, section swept said: If you have one and can mount it in the right way you can use a DTI dial or depth test indicator. With the dti resting on the rocker..engine on compression you can rock the rocker and get a reading. Space is minimal and it is fiddly. The most important thing is to re check the clearance after tightening the locking nut. Bending a normal feeler gauge is the easy way to go. How can this work when both valves are opened by one rocker arm? Surely all you will measure is the tightest clearance? The other valve could be an excess clearance and you would not measure with a dial gauge? 1 Quote Link to comment Share on other sites More sharing options...
section swept Posted March 31, 2020 Share Posted March 31, 2020 On 3/28/2020 at 11:33 PM, oz thumper said: How can this work when both valves are opened by one rocker arm? Surely all you will measure is the tightest clearance? The other valve could be an excess clearance and you would not measure with a dial gauge? I did say at the end of my post ‘bending a normal feeler gauge is the easy way to go’. ? Quote Link to comment Share on other sites More sharing options...
