This stream auto-updates
  1. Past hour
  2. Today
  3. Pre 1999 Montesa Cota 315R came fitted with Paioli forks and the service manual covers their service in great detail 👍
  4. Hepcats , Sinners , Brats , Sunshine. This is a resurrection for you. Resurrection Joe. Luckily Ryan Young lives on. https://shercousa.onshark.com/docs/ You better look at it quick before Drumpf has it deleted.
  5. I would still like a copy of the 2003/2004 manual for anything else. I can only find later models.
  6. Thank you for your quick response, The website is full of valuable info, a lot of it goes beyond my current knowledge of the argument. I was hoping to find pouch cell with equivalent features of the original, and have some technician swap the cells and keep all the rest as original. Yet It sounds like this is difficult to achieve and may even be better to find a new BMS and new battery cells . Il would be great to hear of someone has successfully done it, and with which specific BMS/cells. I will contact Enepaq and see if they can provide suitable cells, their BMS seems a lot better than the original one
  7. Close; it's because the light weight, right-handed, senior citizen type rider tried using their left leg to start the silly backwards bike and found they simply could not start it.
  8. Yesterday
  9. I don't get why so many people advocate using the right leg for a left-hand kickstart. Is it that right-handed people think the left side of their body doesn't work? How do you think left-handed people get on with right-hand kickstarts. Unless you have a particular injury or disability, use the leg the bike was designed for.
  10. £1500 should do it, though the bike will be quite old so you check it out very thoroughly. Normally I would say £2k will get you something trouble-free and ready-to-ride.
  11. Glad to hear you found something useful on the website, Fabio. My understanding is that the 2019 5.7 was EM's first use of the siliXcon controller. I assume the controller is password protected, like all later EMs. But if that's not the case, the 2019 would be quite valuable. The battery is always a source of concern. However, the 5.7's pouch cells do seem to be more “reliable” than cylindrical Li-Ion cells that are now being used. I have heard of several 5.7 batteries being rebuilt using cylindrical cells. Of course the BMS also would need to be replaced. Battery technology improves quickly, and it would be likely you could now achieve 2x the energy density of the original 5.7 battery. I have begun researching BMSs for such conversions: https://www.electricmotiontech.com/home/ev-tech-101/ant-bms
  12. It’s better to stand to the side and use your right foot—it’s more comfortable and helps you maintain your balance.
  13. I read with interest this topics and what a great amount of info you shared on your website! Thanks Konrad! I am deciding if to purchase or not a Motion Escape from 2019, the bike comes at a good price but i am worried that the battery will not last long or that will lose efficiency very quickly.... Kokam it out of business...so i started looking online for Pouch 3.7v 25Ah lithium ion batteries to regenerate the battery without having to change or reprogram the BMS .... Do you know any specific brand/models that could be good for the job, just swapping the cells and be good? Thanks Fabio
  14. Rear shocks to suit a TY175 would be suitable for the Cota 247. Forks are rebuildable, you just need to get some high pressure rotary seals of matching dimensions from your local supplier.
  15. I'd be checking your countershaft sprocket before pulling anything apart, if its worn it might be catching the chain. Next thing would be as JRSUNT has said and take the chain off and run it in gear and see if noise is affected by the clutch, which means you will have to dig further.
  16. Last week
  17. Only in that the owner in New England passed away, and the son sent them to Mike to sell them.
  18. Thanks now I have 5W oil so will start with 300 and then measure.
  19. It is unusual for the pump to fail, particularly the older style, they were pretty reliable. Yeah that pump should do the job
  20. thanks bud much appreciated, yeah im capable of stripping it etc just more on the lines of cba lol looks like a strip down it is 🤦🏻‍♂️ thanks again
  21. Practical approach Measure the original spacer from the TLR250 F (if you still have the old one) and make an exact copy,If you don’t have it, use a vernier caliper to measure the distance between the inner bearings in the rear fork. You can then calculate the length of the spacer:
  22. Sewing machine could be a good description of the soft powerband. That can be an advantage for novices or those of us with low skill sets. Has anyone ever tried a non vacuum carb on one? I had a Tiger 800 that actually sounded like a sewing machine at highway speeds
  23. I am also older than you and started later..... As to bike; the trouble with old cheap bikes is they have had a hard life and (usually) some suspect maintainance. Older models like the Rev 3 are worth a look and ride OK. I have noticed that bikes are often cheaper in Scotland so you might well be lucky. The Beta bikes also tend to be more robust and represent good value for money. We started with a Rev 3 but I soon moved on and spent rather a lot more 😁 I love all motorcycles and need very little excuse to overspend on them. The missus had an 2014 250 Evo for a couple of years and it was very good. We paid 2300 for it. It is still going strong with the new owner (brother of a friend) and will - I am sure - give many more years good service. She had trouble starting it so she went electric but otherwise we would have kept the bike a lot longer. We sold it for near enough what we paid for it. I had fitted a new brake rotor and m/c (the OE front brakes are not that great IMHO). Other than that a chain and sprocket (cheap) and a throttle cable. Good luck finding a fun machine and all the best with riding it.
  24. It will be difficult to pin point the noise without a bit of investigation. If you don’t mind a bit of spanner work there’s a few things you can try. Get a workshop manual if you don’t already have one, they are very useful. Firstly, take the chain off to see if taking load off the gearbox sprocket makes any difference. If not, put chain back on, you’ll need it on later. Drain the Gear oil and coolant Now you need to take the full right side canckcase cover off by removing the brake pedal and kickstart. The kickstart can be very tight on the shaft and can take some prying off. The bolts for the cover are various lengths so make a note or plan of what goes where. Be careful when lifting the case off, use the pry tabs. There is a shim/washer on the water pump shaft and kickstart shaft that like to disappear. They usually stick to the cover. Take the clutch apart and basket off, ideally you need clutch holder and impact gun to get the 36mm nut off the basket. (it can be done without with some improvisation) If the sound is still there when spinning the rear wheel it will likely be gearbox related and possibly an engine split. If the sound has stopped, it’s in something you’ve taken off. Good luck
  25. Yeah that’s what I thought strange as it’s coming from flywheel side, I’m not sure on the output shaft or gearbox sprocket, only happens when in gear, moving, no noise when in neutral or clutch is pulled in, I’ve had it a less than a year
  26. Drain the gearbox oil and check for metal. The flywheel is on the left side. It would be unusual to have clutch related noise there. Could it be output shaft, gearbox sprocket or chain related? Does it only happen when the bike is moving in gear or does it also happen when moving but in neutral? Does the sound not happen at all when stationary? Is the bike new to you or have you owned it a while? Just looking for a bit more information
  27. @FHG speak with Glen at Rockshox, he will give you all the advice you could ever need about shocks gary@rockshocks.co.uk
  1. Load more activity
