Today
Which Tube For A Tube-Type IRC TR-011?
Man, what a difference this new (correct tube-type) rear tire makes. I can't conclusively say how it works in the wet, and I've only been able to ride on my small property which is mostly dry with grass. I have cones set up for figure 8 practice, and 2 trees on a hill for cambered figure 8 practice. It's a bit easier for these drills, and much easier to come to a stop and balance. Dead engine balance practice on the floor of my barn is much easier. I still have a few more "issues" to fix with the bike before I can take it to a local Trial, or even a play/practice ride. The old Dunlop I replaced was the "Trials Universal" model. I think Dunlop makes better trials tires than that model, but don't know if they still make tube-type? Anyway, it was SO STIFF, even with 5 lbs. of pressure, it didn't seem to flex much at all. Getting it off the rim seemed much harder than getting the IRC on. With the same 5 lbs. of pressure in the IRC, the IRC's sidewalls flex and spread out q good bit more. Jimmie
vabetadude201 joined the community
Yesterday
Fantic 200 Oil Leak
A Fantic 200 trials bike (with the FM-type engine / rear-kick engine) requires 500 cc (0.5 liters) of oil for the combined gearbox and wet clutch. (Note: Older Minarelli-based Fantic engines from the TX series use up to 1.35 liters, which often causes confusion online, but the Fantic 200 FM-series takes 500 cc).
Misty joined the community
Fantic 200 Oil Leak
Wrong information. If you use the weep hole then the capacity is around 1350ml . Fact.
Aprilia Climber 280 1993
I have a few parts... I chose a polished AJP hub, GasGas type (for the inner diameter of the sprocket). Other advantages compared to the red Montesa 311 AJP hub: - both bearings are 6004 2RS - the center spacer is aluminum. This is simpler and lighter. I stripped the spokes to repaint them with 1K satin gray epoxy. Great! Final result: A clean wheel, lighter than the original, and tubeless! Now I just need to finalize the assembly on the Aprilia. Outer spacers and hardware. I still have a few ideas to get even more enjoyment out of this motorcycle.
Beta Sincro Clutch spring settings...
Position # 111 on the smaller outer clutch ring has the softest clutch pull, and less front wheel blip and potentialy more clutch drag. Position # 1 has the hardest pull with more front wheel blip and less clutch drag. Position #11 is in between position #1 & #111. This conclusion after many weeks of testing on a 2026 Factory Beta Sincro 250cc
Last week
2022 gas gas txt 300 jetting
Thaks for the reply. I know having some shavings is normal and my bike is pretty new but to me it seems like a lot. I was warned that the 23-24 models had tranny issues. But whats weird is that as far as I can tell, the 19-24 trannys are the same and my old 2020 300 never had any problems. In fact the guy who bought it still rides the crap out of it. I did some research and the 2025 models have numerous new tranny parts in them so I went ahead and ordered those. As for the starting, I tried a low comp head on my 24 and it made no difference. And my 2020 never had any starting issues that I remember. And the guy who owns that one now doesn't have any starting issues either. I do remember putting a low comp head on that as well as a heavier flywheel but that was to simply tame down the power. That thing was a brute. I really like the way the 2024 runs. And handles. Sometimes its starts up super easy, then all of a sudden it doesn't. If your idle is hanging, that is a sign of it being too lean. Could be the pilot, or simply the idle adjustment is too high or the air screw too far out.
Are you talking about the transmission oil drain/fill? Yes, I did see some on both. Some fine stuff is normal I think for wet clutches that wear on friction disk/metal plate interface. I got the S3 low-compression head installed. Easier to kick and start, even in gear. I don't have to hunt for the just-past-TDC point anymore. Just get the pedal to the top at the hardest point and kick hard back and down. Before I would hurt my knee sometimes when it hung up at TDC. Another thing that helped with starting is new plug and especially a new iridium version. For jetting, I haven't changed anything, but I don't kick too many times with the choke on. Two max then turn it off. Usually fires up on the next kick or two. When hot I find that opening the throttle a bit during the kick helps a lot. I still have a bit of popping noise at low RPM that I think is normal. Also, the idle seems to hang and take a bit to come down after revving, but I am also thinking that is also normal for these bikes as compared to an enduro 2-stroke.
I have a 2024 TXT and have been chasing the starting/jetting issue since purchase about 3 months ago. I had a 2020 version and never had any issues with it. I have run stock jetting, leaner main, leaner pilot, up and down on the needle clip position. It has never run bad, always clean just not as crisp as I feel it should be. I have red where guys are running a richer slide. So with that in mind I have a 52 pilot (which I have tried briefly before), JJH in the #2 clip position, 125 main, stock 3.5 slide. Haven't ridden it yet but went out to start it and it was a pain. Actually started with the choke off but cleaned out really quick. The air screw actually made a difference turning it both ways. I'll ride it tomorrow and hope for the best. On a side note....anyone get a lot of metal shaving on both the drain and fill bolts?
2022 gas gas txt 300 front fender brace
Would that be your enduro bike fitted with USD forks? ... things are made out of aluminum on competition trials bikes because aluminum weighs 1/3rd. that of steel which also has a tendency to rust. Same as with your enduro bike the axle provides the majority of support required to keep the fork legs running as one. Everything is beefier on your enduro bike to the tune of almost 80 additional pounds. How easy is it to twist and or break a modern trials bike? It's not easy at all, I've launched my bikes off cliffs and experienced relatively little damage, but I do tend to buy other then Gasgas bikes which are not exactly the sturdiest in the market but generally are the cheapest to buy. Example your foot peg brackets are welded to the tube steel frame and not replaceable bolt on components attached to an aluminum casting. Tube frame cracks around the headstock have been reported by owners and many friends that do own current models tell me the rear fenders are very expensive when they needed replacement. Beta has an even more fragile front fender brace made out of plastic. Front fork stanchion tubes (also aluminum) are the most expensive part that can be easy damaged by just a small scratch, but you can buy sacrificial fork guards to help protect those.
Rev 3 250 head removal
Oddly I did just this on my 08 and turned a bit out of head on my lathe so was easier to kick over. Worked well.
Gotcha. Yes, I loosened everything, including the steering stem, and got it all lined up no problem. Still looking for input on how often this happens with trials bikes and whether I can ride without that brace/bracket in place. My enduro bike has no such thing and takes much harder hits, but the triples are beefier. Also, wondering if that brace is aluminum so that it is sacrificed instead of damaging the forks or whether I can replace it with a steel one.
Chitter joined the community
GASGAS 270 JTX 1997 Overhaul : Video !
KJC joined the community
- 2022 gas gas txt 300 front fender brace
That's what I meant by loosen everything.- New Member
Hi all, Michigan rider that has many years of offroad racing and recently started trials riding. Absolutely love it! Hope to learn as much as I can.Sarge184 started following New MemberSarge184 joined the community- Scorpa 125 with Yamaha engine questions
Had the same ticking on mine a while back and it was valve clearance, went away once they were shimmed properly. Worth checking first since it's the cheapest thing to rule out. The low rpm hesitation was a gummed up pilot jet on mine, sat for a while before I got it. For parts I've used Iron Offroad, they carry MX and enduro bits by bike and brand so it's easy to find what fits, though older Scorpa specific stuff is hit and miss. Yamaha engine manuals are usually findable separately since the motor isn't Scorpa's.BackRoadRider joined the community- 2022 gas gas txt 300 front fender brace
Triple clamps also hold the forks in place/alignment. The fender bracket is toast. It was pretty badly bent and it is brittle aluminum so couldn't really bend it back without it breaking.- 2022 gas gas txt 300 front fender brace
Loosen everything and bring it back into alignment then torque everything back down, odds are there is less damage then you think. Bracket is important in that, you only have a spring in one fork leg, so the only thing keeping the spring side and dampening side lower fork legs moving in unison is the strength of the axle and that fender brace. Align and tighten the fender brace last.- 2022 gas gas txt 300 front fender brace
I had a minor mishap and my 2022 gas gas txt 300 fell on its side. There seems to have been some torque between the wheel and bar as it tweaked the forks such that they were not perpendicular anymore. This also bent the front fender brace where it attaches to the forks. Is this pretty common or did I have something loose? Can I ride without that brace/bracket in place (no worries about no fender, thinking structurally)? Is that brace aluminum so that it is sacrificed instead of damaging the forks or can I replace it with a steel one?bw123 started following 2022 gas gas txt 300 front fender brace- Txt 280 1999 brake help
Air rises where I live, so first I push the brake pads all the way open forcing most of the fluid back up into the reservoir where I drain it off with a large syringe, then I push fresh DOT4 UP through the brake calliper bleed screw and into the reservoir, then I pump up the brakes to bring there pads back in contact with the disc and fill the reservoir to the prescribed level. Your old fluid will be discoloured compared to the fresh fluid. Same syringe process works for bleeding a hydraulic clutch.- Rev 3 250 head removal
Hi all does any one if you can take the head off a 08 rev 3 250 whilst the engine is still in the frame. Thanks- Txt 280 1999 brake help
Is this best done from the bottom nipple up or gravity down? I ment brake fluid not oil, but it was saying dot 3-4- Txt 280 1999 brake help
... water content in old brake fluid will boil when the brake becomes hot with use creating the worlds tinniest steam engine inside your hydraulics, it will work right up until the brakes gets hot enough to boil the water creating air bubbles in your brake system which is bad.- Txt 280 1999 brake help
That's easy; it doesn't take oil it uses brake fluid which absorbs water out of the atmosphere turning your brake fluid into something very toxic nasty. You need to do what is called a flush of the old brake fluid and replace it with fresh fluid without introducing any air into the hydraulic system. After that you will know if you require new rubber parts in the brake master cylinder or not.- Txt 280 1999 brake help
Got the old bird out the garage at the weekend, give her a wash, but noticed the day after, the front brake lever is not engaging sll the way out with the plunger, have to manually flick for brakes to unlock, I’ve checked the oil level, it’s half way up the site glass, looks a little dirty to be honest, question I’m asking is what oil does it use, I’m seeing dot3-4 And is it possible it could have got water in somehow? Was working fine when I got it out.Teddydanson started following Txt 280 1999 brake help- Beta techno 1994 rebuild: Video
