This stream auto-updates
  1. Past hour
  2. So the valves were slightly tight, the cam chain and tensioner all seem good. Can't see anything broken with the valve springs but a bit hard to see into the rocker space. Interestingly the cam was one tooth out on the chain but setting that right has made no difference to the tick. Carb through the ultrasonic cleaner and it startes first time and goes to a nice tickover after a bit of tuning the mixture screw. Pulls great, revs hard and ticks over well. Sometimes gives a cough if you give it a load of throttle at tick over but only 1 in 10 times. Lifts it's front wheel with just throttle quite happily and feels like it has good compression with the kickstart and doesn't smell at all of oil or burning. Ticking is still there, changed the oil and it was old. Had a silvery shimmer to it with some bits. Passing a magnet through the oil and nothing picked up, silver bits and clutch material are all 1 to 2mm bits. But probably hasn't had new oil in ages. Ticking is hard to place, using a stethescope it sounds clear all around the crank cases. Seems a bit louder at the front top of the engine but I am struggling to place it. At first I thought rings or small end but it isn't any louder noise listening directly to the barrel. It doesn't change at all with clutch in or out, or in gear. Ticking is heard clearest with my head above the tank, not to the side of the engine, although you can hear it is ticking as soon as it starts from anywhere near the bike.
  3. Testing with the ohms resistance at 200 I'm getting 34 ohms.
  4. First start! This bike had been on standby for a while. Coolant, a bleed, a few connections, fuel system finishing, and it was good to go. Started perfectly, protecting the beautiful new kickstarter from contact with the footrest. The engine sounds great. It's truly satisfying. All that's left is to bleed the front brake.
  5. Thanks again, how can I determine if my coils faulty? I've a digital multimeter but have limited knowledge in it's use. I can check for resistance, ohms and voltages. Do you know of any readings between the spade connectors themselves and either spade connector and the ht lead? I get a reading of 049 when I probe the spade connectors and the meter makes a noise.
  6. OMG people his tube type steel rim isn't even a safety rim, you know those tools called a bead break? <- he does not need one because the tire will never bead. You know the big Bang that a tire makes at the tire shop when the tire mounts the bead <- his tube tire on plain ol steel rim will never make that noise unless he has a blowout, because there is no bead to seat ๐Ÿ˜ stop making it more complicated, the Only way that tire won't slide right into place Dry is if he pinches the tube between the tire and rim when he is mounting it.
  7. Today
  8. The end float on the gear shaft won't affect the plunger as that acts on the selector drum, but too much end float on the gear shaft means the selector fork is not in contact with the selector drum when the shaft moves too far to the left. Inside the clutch case there are two washers on the gear shaft, normal and wave washer, located by a circlip. These restrict the shaft end float, if they aren't there the shaft will continue to work its way outwards, disengaging with the drum, nothing that a kick with your heel won't solve to push it back in though
  9. I use hand sanitizer to put handlebar grips on lol maybe that will work for whatever the heck it is you are trying to make slippery.
  10. Thanks Woody, you got me thinking, and I realised the gear change lever shaft had far too much end float so the plunger was not engaging with the selector drum detent. All sorted now , I just can't get it to spark!
  11. other options include WD40 and dishwashing liquid solution
  12. Screw adjuster valve clearance tightens with wear as the valve wears into the valve seat. Valves do travel at half speed of the crank, is the ticking in time with the crank or valve train, that can help to narrow it down some times. Your bikes parts manual shows only one spring on each valve, most have 2 springs wound in opposite direction to each other (stops the valve from rotating), I'd be looking for a damaged valve spring if it turns out to be a valve noise.
  13. Yesterday
  14. @halfway www.birkettmotorsport.com - scorpa - parts books - halfway down the page. SY/TY 125F info.
  15. If the engine is in the bike, put it in 1st and try just tapping the gear lever into neutral with your heel whilst rocking the bike. If the shimming is making the gear selection a bit stiff it could cause the selector to go straight past neutral to 2nd and vice-versa. Tapping it with your heel should move it just enough for neutral. It's how I get neutral on my 250 as the gear selection is a bit stiff, my 350 gets neutral a lot easier
  16. TT-R125 manuals are available online. Valve clearance (cold) IN: 0.08 ~ 0.12 mm (0.0031 ~ 0.0047 in) EX: 0.10 ~ 0.14 mm (0.0039 ~ 0.0055 in) Check the cam chain tensioner too.
  17. Valve clearance and cam chain were going to be my first checks in a couple of days, hopefully just the valves not adjusted to spec. Any ideas what spec should be?
  18. https://www.redlinestands.com/catalog/shop-equipment-c-327/tire-change-equipment-c-327_331/tire-changers-c-327_331_248/discontinued-coats-220-manual-tire-changer-p-1865 I had this manual changer for over thirty years. Lubed every tire I ever installed. All trials tires I could usually mount just by hand. Street tires were just as easy. Some of those rock hard knobbies were still the worse. Wish I still had it, but I quit working on bikes for the most part. Just my own. With all my grand kids growing up, it's still would of been usefull! .
  19. Regarding ticking, have you checked the valve clearance? Regarding low-rpm hesitation...
  20. lemur
    Oils for a 315r?
    Dog bone linkage bearings need to be serviced lots to keep water out, if the part becomes deformed from impacts it is near impossible to keep the needle bearings good. Many parts are unchanged in the 4RT I just used hydraulic oil in the transmission and change it often, I think the clutch is also unchanged on the 4RT, 2 paper and 3 cork fibre plates in the clutch, nothing special.
  21. Manual sent, hope you find it useful. ๐Ÿ™‚
  22. Thanks again Woody for getting touch. Engine is in the bike , I'll take it off the bike lift and try it. Yes the plunger is fitted. I'll let you know how I get on. Best regards, Colin.
  23. Itโ€™s a radial tire. I did mount it on the rim, went on a lot harder than a regular rim. I had a heck of a time seating the bead. Tire looks normal on the rim. I donโ€™t think itโ€™s going to move!
  24. I have an owners manual that I can send you a copy of if you would like to PM me your direct e mail address.
  25. Looking to service a 315r which runs great, anything I should be looking out for or giving special attention? And how do you figure out what year they are? Any manuals for the bike would be useful. Any pointers for coolant, gearbox oil and brake/clutch fluid (dot 4?). How often should the steering head and suspension pivots be stripped and regreased?
  26. Hi, got an unknown age 125 4 stroke with a yamaha engine, monoshock. Trying to find out some servicing info or links to manuals for these, engine oil, brake fluid, carb settings etc. It does have quite a loud ticking from the top end, which comes and goes a bit but is there right through the rev range. It runs ok except a bit hesitant at low rpm. Any obvious problems with these engines that would give the ticking?
  27. Itโ€™s a Aprilia Climber 280R trials bike. The model Climber was made from 1989 to 1994. I had a 1992 in the 90s, was the first trials bike I competed on.
  1. Load more activity
ร—
