This stream auto-updates
  1. Past hour
  2. I suggest that if you fit a tubeless rear rim and it's a drum brake wheel, use the rim type that has a sealing band in the central well, rather than a flanged type tubeless rim. It will be a lot less work/cost to fit.
  3. They haven't been available in Australia for many years.
  4. Yesterday
  5. Sounds like good advice - I definitely have some imperfections in the grooves too. And was it those ebay seals you used successfully after your attention to the corrosion etc. on the caliper? Following some encouragement from Gemini (AI) I contacted a UK Bearings and Seals supplier - they can do the exact seal for me but 4x the price of this ebay seller and minimum purchase of 100 units!
  6. Im Just going to go with a matching cases number as I can see any modifications been done on it. Thanks for your replies
  7. I would clean the carb again. You need to spray all the passages in the carb body to make sure they are clear. All jets and any holes in the emulsion tube. Good luck.
  8. Hi so I just picked up a 2018 evo80 Jr for my son.. bought it off the original owner who son rode it twice and never again and it has maybe 8hrs on it .. it had sat for atleast 4 years it wouldn't idle at all when we went to look at it and pulled the carb off and cleaned it all out and it runs much better but still is struggling idling for any period of time and stalls out . Ive played with the mixture screw and had varying results and it seems to run better for abit then not .. it runs great off idle so im not sure where to go with it ...plug looks good . Fuel supply is good. Airfilter is freshly cleaned and oiled. Im wondering if maybe its a jetting issue ? We are below 1000 ft from sea level ... carburetors are not my strong suit lol Cheers
  9. I would say that marking has nothing to do with what needs done right now
  10. Last week
  11. Three Ideas: Does it match with a part number for the cases? A machining note to define how much end float/shims the crankshaft needs. A job number from a previous mechanic shop to keep the parts identifiable.
  12. Hello, I finally took the time last week to start the bike. I have used 2017 Sherco 290 st series carb adjustments with 42 pilot and 128 main jet, set air screw on 1.5 turn out with needle position 4, +0.5 washer. Runs very smooth and nicely. So, I took a ride and found that top speed is 65 km.h max, instrument cluster lights on but not showing any speed, not going to dig an issue. I think it's the end of the story. I did test it on pavement and don't wish to take it on trail and put some ware on it once visually it's in pristine condition. I will try to trade in an enduro bike, won't be easy but ill give it a shot.
  13. I gues so sir, any reason they would mark the cases? Other than not fitting wrong case half's
  14. In 1064, England was at peace under King Edward the Confessor, but the succession crisis began brewing. The defining event of the year was the controversial journey to Normandy by Earl Harold Godwinson. This trip subsequently provided the foundation for the famous Norman Conquest in 1066. Maybe the mechanic who had the case apart before was a history buff too. 😉
  15. Got my 08 rev 3 250 apart for new mains and crank. After splitting the cases I found markings engraved 1064. Does any one know what this would have been done for. Its obviously the engine has been apart before as the new mains uv had are the plastic caged ones direct from beta. Old bearings were ntn.
  16. stpauls
    A 1974 -76 Honda MT 125 Elsinore front end. Yokes, forks, hub and brake.
  17. Hello JK, I bought these https://www.ebay.co.uk/itm/306807336648 and they don't fit 😁. I solved the problem by doing what I used to do on my 1980s/1990s commuter bikes... The problem is caused by corrosion inside the grooves that the seal sits in - the corroded alloy increases in volume and forces the seal tighter against the piston until eventually it is so tight that the piston can't retract when the pedal pressure is released. I took the caliper off, drained the fluid, popped the pistons out with a foot pump, and carefully prised the old seals out. It's then just a case of carefully scraping the corrosion out of the grooves - I used a right-angled dental pick which ended up in my toolbox years ago (I have no idea why!) but in the past I've also used a pop rivet shaft with a 90° bend at the end. The corroded alloy also 'grows' into the back of the seals so you need to scrape that off with your thumb nail. I then put a drop of ACF50 into the grooves before refitting the seals and piston, reconnecting the hoses and bleeding the system. The caliper has worked perfectly for the last couple of months and I only ever had to do it once on my old Yamaha commuter bikes, which I kept for many years after doing this fix. I was initially cautious about the ACF50 contaminating the brake fluid but I never experienced any problems. It takes me a few hours but it seems to be a permanent fix. I hope this helps.
  18. Hello Gavin - your story sounds similar to mine! Can you tell me how you got on with your e bay seals? Can you share a link to the item you got (if forum rules permit)? My bike is the Evo 300 from 2013 with the Braktec/AJP brakes.
  19. Good idea on the cutting board for the base, Dave! 👍 I made a skid plate for my Pukey Suzuki DR200 from similar material (UHMW, I think it’s called. 3/16” thick). I formed it with the heat gun. Should hold the staples well. Understand about getting “sidetracked” with other stuff. I have to split my diesel tractor in half to replace a leaky rear main seal. I think I’d rather work on an old Beemer…….. 🤔
  20. What is the procedure for adjustment of the clutch on the Matador? Is it like any other where you loosen the locking nut and turn the screw in until resistance and then back off 1/4 turn?
  21. Thank you. I have been thinking along the same lines. I was able to locate the fiberglass base and with a little cosmetic work it should be fine. I am toying with the idea of heat forming the seat pan out of a white plastic cutting board. I think it would hold the staples for the cover well. I have been sidetracked a bit working on my road bike, a vintage BMW.
  22. SlowDave, I recently bought '74 TY250 which probably has a top candidate for "Ugliest Seat In The World" type of seat. Has a home made seat base of plywood on the flat portion, and some sorta plastic for the part that molds/curves over the rear fender/seat pan hump at the back of the seat. I'm kinda fortunate in that my bike's yellow fiberglass seat pan is actually in decent shape, but with some very funky mounts from the seat pan to the upper/inner rear shock mount. These will reqire some mild "engineering" and fab work, as decent used parts are tough to come by, as you know. I have had no luck finding very many parts here locally in the NW part of Oregon. One Vintage parts dealer in Portland tells me the fiberglass pan and the seat are among the first thing he sells when he gets a TY in........ I don't know how YOU plan to use a rear seat on YOUR bike, regarding whether you mostly stand while riding, or plan on sitting a lot while, say, trail riding. That would probably determine just how good of a seat you'll need. Mine will be a minimalist type of seat, since 1), I mostly stand while riding anyway, and 2), my last modern trials bike had no seat, so that's what I'm used to......... I've decided to make my own seat base from sheet thermoplastic. I'm still in the "Research Phase" of this, but it seems "doable". I watched a youtube video of a guy that did this for a road bike, which was helpful. Our seats have what is a fairly simple base. Mostly flat, with an angled portion that molds over part of the seat pan. Heat a sheet of thermoplastic cut just slightly larger than what is needed in an oven at 325-350 degrees, and place it on the fiberglass pan to form to the seat's base. Wear gloves for this. If any parts of the thermoplastic cool too quickly to form correctly, a heat gun will give enough heat to form as needed. It will need to be trimmed a bit after it's formed and cooled. A bandsaw will be helpful for that, but a handheld jigsaw will work also. This stuff can be heated, formed and cooled, and reheated several times. A fairly understanding wife may be necessary to heat plastic in the oven, so the heat gun might be the best way to do the whole enchilada. I've heated and formed a part for the airbox on my pukey little '92 Suzuki DR200 (needed this after a carb swap), and made several holsters for my handguns with this stuff. This plastic can be cut, drilled, sanded, and etc.. It's not too hard to work with. I've found seat material/fabric at Guts Racing and Parts Unlimited (some fabric called "Texhide", which I know nothing about, but is cheaper than what's available at Guts Racing...... ) for the cover itself. I still need to find some suitable foam. Assembly will, hopefully, consist of stretching the seat fabric over the foam, folding it under the base, and stapling it similar to how other dirt bike's seats get re-covered. Anyway, that's my plan for my bike's seat, for now. I should have some time to start on it in a few weeks, and hopefully will be able to report on any progress I may have made on the deal, if anyone is interested. Wish we didn't have to jump through these kinda hoops for parts for our bikes, but that's part of the charm, I'm told....... Hope this might help some, or at least give some ideas and options! Jimmie Added in EDIT: A link to the video of making a seat base I mentioned above:
  23. New bushings need to be modified but after that, it is perfect. Exit the old rusty tubes.
  24. Welcome to the site in sunny GREAT BRITAIN , AKA ,The UNITED KINGDOM.
  1. Load more activity
