- Past hour
Hey Jeff! Welcome to the forum. I just did a simple search and found several TY80 original wheels on eBay. Maybe I’m misunderstanding what you need though. Anyway, below are two links to a full rear wheel and a front. Good luck finding what you need! https://www.ebay.com/itm/256739081016?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item https://www.ebay.com/itm/162588017989?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item&srsltid=AfmBOoopomzC1tONF4ljLp0sdbSqOeiIC_rvqKKSSo1g02_aOgSIJGkJkpY
jeffgsx1400 started following Ty 80
Hi all I’m new to this forum and am in need of some help , I’m looking for a pair of wheel rims for a ty80 or even complete wheels , I’m am restoring a 1976 model , have been told I can possibly get alloy but that’s not the way I want to go with it as I want it original , any help would be appreciated as all avenues I seem to go down are a dead end 🤨
jeffgsx1400 joined the community
I have an opinion, but you're not going to like it. ONE OF THE BEST FEATURES OF ELECTRICS IS THAT THEY ARE QUIET!!!!!!!!!!!!!!!!!!! See, all that hollering is annoying. Yes, they are even quieter.
I didn't see the post until tonight. You're probably right. I only ride IC trials bikes but the same applies about hearing the sounds of the motor being an important part of riding trials well. As far as electric trials bikes go, I have only ridden a clutchless EM and I could hear the groaning of the motor at low RPM quite well, but someone with poor hearing may have had difficulty. Do the modern EM bikes sound different to the original ones?
ChrisCH started following Anyone (UK) insured Factor-e?
My missus is struggling to find an insurer that will cover her factor-e. The bike does not sem to appear on any of the main insurer's databases. I tried to add it to my (Aviva) multibike but they do not list it. We found a specialist trials company that offered theft but it was twice the price of my multibike (Suzuki GSX and Honda CRF) or the wife's Ducati Monster insurance. i just wondered if anyone has found a regular company that will cope with this model? The "specialist" for electric (motor) bikes I found cover the escape but not the factor-e so could not get a quote from them either. Only looking for theft cover.
I was just digging thru old posts and saw a discussion we electric geeks had in 2013 with some interesting stuff in it. Now, 12 years down the road, I recently bought a 2024 EM Pure Sport. It has an awesome diaphragm style one finger hydraulic clutch. I'm learning why its important to mechanically decouple the motor for rapid stops and starts. And I love this bike. But I'm still hankering for a sound synthesizer. The gear whine of the EM isn't loud enough for good aural feedback of RPM which is sort of critical with this grabby clutch. I posted this previously (above this post) but surprised that after 2 weeks and over 1k views no one seems to have any opinion one way or the other. But it seems like such a natural improvement for electric trials, am I wrong?
mauro joined the community
Gas Gas TXT pro 2010 rear brake caliper
faussy replied to BenFranklin's topic in General Trials Talk
Just seen this on youtube -
BenFranklin replied to BenFranklin's topic in General Trials Talk
Thanks, that makes sense. I'll wait until the shop get back to me to see if they actually stock the caliper with the angled cut, but they seem to be just as confused as me. It's strange that the picture on the website shows it and that the part numbers match, but the actual caliper itself is different to the picture and different to what was on the bike. As you you say if all else fails I can have a go at making the mod myself. -
Just a hunch, but I think the angled cut was to allow the brake hose easier access into the swingarm, which is the route it takes on your bike, when the wheel is fully forward in the swingarm. Later bikes and other manufacturers have the hose mounted outside the swingarm. Worst case scenario you can cut/hack/file this clearance into the new caliber -
Were the points open when you measured this continuity to ground? Open the points, and then also try removing the condenser, it can short to ground if faulty. You can get a new condenser at most autopart stores or online for a few quid
BJswe joined the community
Thanks @Tr1AL, I'll have a look in to the vacuum bleed kit. I'm relatively new to trials and trying to learn on the job with regards to maintenance and repairs, so any tips are very useful. -
@Charliedimmock46 DT50/DT80MX 1982 looks almost identical but has lighting coil included. take that off if you do not want it . Go to ebay to find one second hand , not cheap though. Regards Alan..
That should fit without problems the part number is correct to fit your bike. Regards Alan PS Using a vacuum kit to pull the fluid through the system helps as it can be a problem bleeding the fluid sometimes with these rear brakes. Vacuum kit to do the job is available on ebay for approx £10 delivered.
BenFranklin started following Gas Gas TXT pro 2010 rear brake caliper
Seeking advice on the above subject. I need a new rear brake caliper for my Gas Gas TXT pro 2010. The caliper that I removed from the bike had an angled cut on the caliper hanger/carrier part of the caliper. I ordered a new one (part number 365019MO0), but when it came it didn't have the angled cut, even though on the website it was shown in the picture of the caliper. I've been in touch with the shop and they say that the part numbers match up with Gas Gas catalogue etc. Has anyone else had the same issue when trying to get a new rear caliper with the angled cut on the carrier/hanger part, and does anyone know if the caliper without the angled cut would fit the Gas Gas TXT pro 250 2010 without causing problems (everything else on the caliper matches the old one that came off the bike). I was thinking that maybe the angled cut caliper was an older standard model which fits both the Gas Gas and other bikes, and maybe the version without the angled cut is a new standard model that still fits the Gas Gas but maybe not other bikes. Any advice would be greatly appreciated.
HI, Many years ago I fit a Stator form a small DT Yamaha. Worked a treat.
I'm not saying your coil is good, but oil won't cause it to short out. Lots of large transformers are cooled by being immersed in oil. Everything is in parallel with the source coil.
Get it rewound by a place that does small coils.
Charliedimmock46 started following Ty80 stator
Hi all, I’ve just picked up a ty80 to restore for my daughter when she’s old enough. unfortunately the engine casing has cracked which has caused oil to get to the stator and the ignition source coil is now giving continuity to ground. im struggling to find a replacement specifically for the ty80. Does anyone know of any other which fits? It’s a single coil stator
As said, some parts may be drop-shipped to reduce stock holding. It gives the business more liquidity, which means that they are there for you long term. It is no good going out of business with lots of unwanted stock, that does nobody any good in the long run. If you really dislike it, stick to the dealers that state on the sales site if it is in stock. You will soon learn who is up to date on their sites, and who says they have it - but don't. That in itself may be to staff not booking stock in or out correctly that means stock levels are wrong - but you will see who can be relied upon, and who to call to check they have physical stock.
New old stock piston here to have a look at if that helps. https://ebay.us/m/o9DDAJ
Copied this info from somewhere not sure if this refers to the frame colour or the side panels but might give you a start. "The colors of these frames and swingarms are all aluminum gray (RAL 9006) except for the TR77 first series which are gloss black and the TR77 second series which is green (RAL 6011)." Regards, IDC
Based on the location of the noise i thought it was 17
