- Past hour
Mrtecc started following New to Fantic
Just picked up an 88 303. Plan on riding it as a volunter checker @ a local club. It needs some TLC, but that's the fun.
Mrtecc joined the community
- Today
Little work to machine a M9x100 bolt.
MikeID2 joined the community
micklowe joined the community
The effective length of my lever setup provides very near double the leverage of a "close to the fulcrum point" setup. 105mm vs 55mm. ... just measured it Setup works best for old veteran smashed up arthritic hands. If you experience arm pump you likely need to adjust the start of the clutch lever friction zone even closer to the bars, shown in the picture is ideal such that your finger can curl one knuckle from the bars, like a comfortable trigger.
If the clutch works nice right now, I would modify the lever to address your lever problem. Shorty levers with perches moved way in on the bars and the lever adjusted so your finger can comfortably be at the clutch friction point. You will rarely bend or bust levers in a crash and never crush your grip fingers behind the lever in a fall 🤓 inexpensive modification to try.
Not to do with the size of the piston or reservoir with the bigger size clutch master cylinder , it is the position of the fulcrum being different between the two.
Thank you for the message, I was told it was 06’ but the V5 came through the door and it’s a 55 plate reg. So it could be a 05. so you think I strip it down and measure the thickness of the clutch pack and if necessary replacing the discs and the spring plate?
Are you 100% sure it's 06? The reason im saying that up to 05 they had a heavier belleville spring but in 06 they came with a lighter spring. A dragging clutch may hint at too thick of a clutch pack which also makes the clutch heavier. Personally i wouldn't waste my time playing about with master cylinders, they all use the same size piston and the differences are negligible
Beta_Jake joined the community
Gramps joined the community
There isn’t really a proper guide for making a universal trials seat like the Apico ones, so most riders just end up building their own through trial and error. Typically, it starts with a thin base plate shaped to fit the subframe, then a low-profile foam layer is added for comfort. After that, it’s wrapped in a tough vinyl cover for grip and durability. Mounting is usually kept simple with straps or basic bolt points so it can be used across different bikes. The main challenge is keeping it small and out of the way so it doesn’t interfere when you’re standing and riding.
I’m guessing here because I haven’t seen either one in real life but I’d bet the frames are identical which means you could probably take the seat off and put the standard fenders and gas tank on. Call a dealer or Sherco and ask.
Is the difference just he tank and seat? I would like the trials model in most any condition. If you remove the seat and install the trails tank is then the same as the trails model? Are the tanks available?
Also Video workshops at TRIALS PARTS USA on Youtube
Hello Manuals available at ww.thehellteam.com/tech support/gasgas info.
McMan, just in case you’re interested I found this Long Ride for you. It’s in Mt. Hood, Oregon but the price is fantastic. I live in Oregon but bought my bike from this site from a dealer in Georgia and had it shipped for $300. They routinely have some very good prices on bikes on the website. I got my 2023 Gasgas TXT 250, brand new, for $4500. I’m sure you want the standard version but I thought you might want to consider this one. Oh, I’m not affiliated with the bike or the shop in anyway so I’m not selling anything. https://motohunt.com/l/11480744/2023-Sherco-125-TY-Long-Ride
Ok great, that’s plenty to be getting on with. i was trying to adjust the lever to get it set perfectly tonight and when it’s held right into the grip/bar the bike was still creeping in 1st gear and I think that’s why I’m struggling to find neutral. I will have look at the clutch plates to start. Any ideas where you find a workshop manual? I have been pulling it close to the fulcrum point because my digit is not very long but I will try adjusting the controls around as well. thanks for the advice, really appreciated
Set the clutch plate pack thickness to the minimum thickness as advised in the manual and also use a AJP Large master cylinder if possible . There are AJP Clutch Master cylinders available with Large and small reservoirs. Also available are Braktec Clutch Master cylinders that are known incorrectly by the trials community as Braketech . Try googling them both and you will find out which is the correct one. Both are dot COM addresses. Use the long lever not a short or single digit mini blade and position the Master cylinder in board along the handle bar toward the handle bar clamps at the top triple clamp. Position the lever so that you are pulling it with one finger at the end near the ball for maximum leverage . Adjust the lever to move away or be nearer the handle bar grip using the 2 X adjusters one on the lever itself and one on the Master cylinder main body as shown in the Owners Manual. That's one way to get the easy pull at the clutch without it getting complicated and more involved plus more expensive.
I KNOW it is totally stock as I bought it brand new from BALANCE TRIALS SUPPLY in January 2022 an have the Certificate Of Origin that came with it and personally unboxed it.
JamesM joined the community
Jammydodger126 joined the community
mcman56 started following Scorpa TY 125 Long Ride convert to trials?
I would like to give a Scorpa TY125 trials a try but they are very difficult to find in the US. Is it easy to convert the long ride version? There are a few of them. What are the differences?
Oh right, I’m with you, I believe it’s a 2006, it’s red and black and shiny. 😂 Are there any ways to adjust the weight of a diaphragm clutch?
The txt came in 1999 so it would help to know what year your bike is, if its the earlier <02 type clutch or the later txt pro >02 diaphragm clutch
DustyCat started following Gas gas txt clutch
Hi, iv got myself a crackin little bike that touch wood is running great. im after making the clutch a little lighter, I shot a nail through my left hand many moons ago and i think I could practice for longer if the lever had a lighter action. any tips or adjustments I can make? Iv seen online about sanding clutch plates and putting washers under springs. any advice would be greatly appreciated. many thanks
LeoJTLM joined the community
Batuti joined the community
I think its just been proved its not totally stock 😂
Jimgo started following Fantic 240 clutch spur gear problem
Hi, I have just discovered a similar problem with a badly worn kickstart gear on the back of my 240 clutch drum. The fix posted by StevP 6 years ago sounds like a good solution, do you offer a service for this StevP? Has anyone found a cost effective solution to this problem?
Sorry about the late reply I don’t get notifications for this for some reason, I can’t see it being the sprocket as when I pull the clutch in it goes away even if I coast at 15mph if I pull the clutch in the noise stops even when both sprockets/chain are still moving but I’ll get the chain off and start with that, thanks bud
Exact replacements for that Whitehawk 175 cover are hard to find since they’re usually discontinued. Your best option is a custom seat upholstery shop that can copy the original black surround with red quilted centre design, or check marketplaces like eBay for old stock or used parts.
THANKS for all the quick responses! I should have said in my original post that the bike is TOTALLY STOCK.
