- Today
TMofCumbria started following Flywheel fit and electrics
I bought a 199A. It would not start when I went to collect it but owner said he had had it started to check it was OK that morning. No spark, but when we removed the plug but it did look as if it had run. Got it home cleaned the points and checked gap whch as correct. There was now a spark but may be not as bright or as consistent as it should be. Still no start although I think it fired a few times. Tested the HT coil and secondary winding was open circuit so bought new coil from Inmotion. Slightly better spark but still no start. Had the condenser checked by an electrician. No Mf capacitance so ordered one from Inmotion which has just arrived. When removing the flywheel the nut was not very tight, only 30 to 40 ft lbs, it should be 75 ft lbs. However the flywheel was very difficult to pull off, I had to use an impact wrench on the puller bolt. When I got it off I found there were slivers of metal on the tapers and dents and areas galled out. The key and keyway are in good condition. Because of the lumps and dents the flywheel would not go back on properly, and could be rocked about. I removed most of the high spots with a die grinder and am now lapping the flywheel onto the taper, just about got it satisfactory. When the flywheel is fully seated how far should the threads on the crankshaft stick out beyond the flywheel? Obviously the flywheel not being seated as far back as it should be and possibly not concentric on the crankshaft, will have reduced the magnetic flux in the source coil so I am hoping properly seating flywheel along with new capacitor fixes the problem. Does anyone know what the resistance of the source coil should be and who can rewind them? (please dont suggest electronic ignition, I am wanting just to get the bike running and everything else checked before I spend a lot) The timing was 2.9 mm BTDC. However to achieve this the stator plate was in the fully retarded position, which seems unusal. I have had bultacos many years ago and think the stator was usually near middle position. Unfortunately I did not clock the flywheel before removing it and it may have been running out of round due to the shards of metal in the taper. If this was the case it would affect the timing. Where would anyone expect the stator position to be? Thanks Tony
mrt675 joined the community
Hi , my sons Oset 20 has Promax solve brakes and the rear brake lever (blade ) has snapped ! Has anyone changed the blade for a cheaper alternative ie Clarks blade £8 or can you only use the Promax £19 inc p&p , or any other brake blade . Thanks
I think just the set up of the bike back in the day of course it’s not like the modern nearly bantams but maybe a forerunner,I would just like to know who built it.
In your opinion which parts have "been done rather well"?
I need help with a project I have bought which I was going to use for spares but after giving it a look over I think it might have a bit of history to it.My thoughts are that it has been built rather well,its frame has been modified with twin rails under the motor (the frame number is d10***)and is clearly bantam and the rest of the bike has been built with a lot of thought,does this ring any bells with anybody.Thank you.
They were mainly scooters and small motorcycles. Not many trials bikes.
mr neutron started following Ty250A Footrest Kit
if one has 11000 not selling bikes in stock it is good idea to finally get the money from insurance then )
The losses are more than 11,000 motorcycles and all the spare parts on site have been destroyed . the only thing not destroyed is the production facilities and the admin departments . As there is no where to store anything that is produced / manufactured at this moment , everything is paused and admin staff are working from home until further notice.
https://www.gbnews.com/lifestyle/cars/spain-honda-motorcycle-factory-fire-evacuation
Twinshockwobbler started following SWM tl320 clutch upgrade update
Hi all, just a bit more info that might help you all out with dragging clutches. As you are aware if you read my other posts, I fitted an Aprilia TX311 clutch hub to my 83 TL320. That along with the 12mm ball bearing conversion did make a huge difference. However, I recently came across a new steel internal clutch arm (the one with the kit is cast aluminium and difficult to extend) which I extended by 10mm, this again made the clutch pull a tad lighter. when riding the bike in practice or events I noticed the clutch developed a bit of drag, not enough to stall the bike but enough to make finding neutral a pain while waiting in turn at a section. I initially thought this is the plates sticking because when roughed up it seems to cure it. I obtained some new steel plates from motoswm as Martin sells the type with dimples that retain the oil better and built the stack up to the correct Aprilia spec. When I put it all together something just didn’t seem right, I’d not changed anything other than the plates but it appeared that the stack was very snug in the basket depth wise, almost not enough room for the friction plates to move about. I tried the bike and it just stalled and even when I got it going the clutch just wouldn’t clear???? I pulled it apart again and got hold of the Aprilia basket I bought with the hub. I’d been using the SWM basket as they are identical or so I thought, I measured the depth of friction plates slots in both baskets, the SWM basket came up at 29mm and the Aprilia 31mm. I fitted the Aprilia basket and reduced the stack height to a fraction just under the spec buy fitting one or two of the older plates, put it all back together and tried it….no drag, no stall, ok let’s try it out in practice. Rode it for four hours in practice which is probably more than you would in an event as your not stopping so much and had no issues at all, was as easy to find neutral at the end as it was at the start. hopefully this is an end to the SWM clutch woes oh and I use 80w oil to. Not sure if this will help out but worth a look next time you’re in the motor. I’ve attached a couple of pics showing the difference in hubs.
Both air and water are necessary for iron to rust. Remove the O2 (Oxygen) and the H2O (Water) and you have no Iron oxidation. ... and for those who did not pay attention in high school, now you know how to prevent rust from happening 🤓
20000 sq. meters burned down according to the news. This is whole Spain Honda facility as per the map
Not enough information yet to know but it appears it is only the storage area and not the production area has been affected. So theoretically nothing stopping them from manufacturing new parts. It's a waiting game at the moment as I doubt Honda/Montesa fully know the stock that they have lost yet, let alone make future decisions.
would you keep your very smart advices with you please as they are basically useless Repeat - Main question for me is availability of the engine parts in the future due to burned down factory. Wonder why there no any press release or other information from Honda Motorsport?
Did you ever get your Climber going? Did you find a aftermarket CDI or complete ignition system?
Cool, you got below 70!
Dont buy one then
obviously here
You can call it freeze, you can call it stuck, you could even call it bunged up but the truth is it's the result of rust and we all know how to make things rust fast.
When has anybody ever needed an engine part for a 4rt?
Sky1970 started following Honda Montesa Spain factory fire at 05 June 2026
Anyone knows consequences of the fire please? I consider buying used 2023 4ride from a buddy but now doubt Honda is going to rebuild the factory. Main question for me is availability of the engine parts in the future. Any advice on this regard is welcomed)
