- Today
Yeah - that's the newer case, that Jim points out has the stop in a different position than my older case, w/o the recess guide. Anyway, through trial & error I found a spot that works....
Looking forward to seeing the restoration!
At least you won’t have to replace that tire…perfect condition. 😉
Here are some of the parts I've. I also have some new mudguards.
@ahell For its age I would not call that a dirtbag , considering that it is a trials bike it looks fairly good. In the UK that would have been for sale in that same condition for 2000.00 Euros so you paid well under its real value if you paid 200.00 Euros for it. Lucky you.
Hi Colin, I’m in UK, Essex, Woodford Green, sorry I didn’t mention it from the beginning! 🫣
If the spur gear is made of much harder material file small v or half round groove into the gear first, then clear the holes to size with a drill through the softer material.
Once a spur gear like that spins in a press fit the only sure way is to pin it in one or more places.
I wasn’t aware of this happening, perhaps it’s more prevalent on the 300’s and 301’s due to the extra power. Maybe this is what was happening to Andy12343 in a recent previous post. Mitani do know their stuff and do quality products, I’ve used them for many years. Mark at H&D Racing knows their products well. He may have come across and fixed these before
Did not see your earlier post saying you pressed it on using some loctite. As that is the case you know what your options are so its a closed case. I am talking to myself of course.
I know who you are and that you are a serious rider on Honda machinery and therefore know what you are talking about but Mitani who have pretty good knowledge of the Honda motors engineering wise reckon this movement can happen in approx 1 year of use. With the amount of torque the motor produces and the abrupt use of clutches in trials sections ,as happens, then an interference fit steel part in a softer aluminium outer part is going to start twisting and enlarging the alloy part in the same way that the rivet holes on the clutch bell elongate in the end and give rise to slop. I am happy to go with Mitanis' view based on engineering.
Shouldn’t have come apart like that. A new one won’t be cheap but a 2nd hand one may be worth a try. I would think Richard Allen trials spares would have some. If you’re really stuck I have one on a spare engine.
I think the rules in the UK are very clear. The rule is NO STOP with stop allowed. Watch this years SSDT , a trial that is marked under the no stop allowed rule , and the top riders were stopping and then hopping the back wheel sideways about a foot before setting off again at certain sections .That in my opinion is not stopping , stopping is when you have not moved for more than about 5 minutes which is still not really stopping it is a brief lull. I hope that clarifies the current system. If stopping was stopping Doug Lampkin would have had quite a few more marks than he did along with plenty more of the field of riders. Rolling backwards is OK as long as the observer on duty thinks that it is. Remember , as long as the observer follows his own set of rules and applies them exactly the same to all participants , then it does not really matter what the actual rules are.
I can see the arguments for both no-stop and stop allowed. I'm inclined to the idea that stop allowed is necessary at national and international level but not a good idea for club riding. Both systems leave a lot of grey areas that really need to be clarified by the rules. It would really help if the ACU and AMCA (in the UK) would publish rigorous rules about stopping so that riders are no longer marked at the whim of the observer.
Perhaps something like LOCTITE 270 anaerobic permanent adhesive could help or a strong bearing retaining anaerobic adhesive. such as LOCTITE 638
@Guidoxpress Looks like a one -off home made job. You can extract the (screw threaded part ?) that is still in the post of the clutch casing and take both parts to a machine shop and get them to make a replica of the broken part or get a new or second hand casing .
mcman56 started following 2012 TXT PRO 280 clutch “piston” broke
Guidoxpress joined the community
we have a broken clutch piston, assuming that’s what this piece is called. Can’t find it anywhere and can’t find it on any parts breakdowns : any help?
No I actually believe it is a ktm directive. It used to be US companies just refused to believe that there was an outside world and wouldn't ship. Problem solved itself. They came back and said no stock. Sigh.
I believe it's the smaller gear (behind the primary gear), which meshes with the kickstart idler gear, that backs out. Mitani has a writeup about it here: http://mitani-ms.jp/info/2013/09/rtl-f-clatch-outer/ It's in Japanese, but my browser did a good enough job of translation to get the idea. Mitani makes an improved part, but it's not clear how they improve it: https://mitani-kobe.shop-pro.jp/?pid=60396201
new original piston ! 88.9kg with half tank ... I think 91 kg with a full one and the iron side stand.
@F5Dave "They weren't allowed " what is that so outsiders cannot notice that the rising price of fuel is affecting the cost of shipping adversely. Strange days. Have fun. Regards Alan
Cheers After mucho time searching. . . OK so I've ordered what I believe is the 1.2mm spring with PN MT22020GG-CGI-1 from KTM World in the US. They weren't 'allowed' to ship internationally but I'm using NZ post shipping service. So far i'm in $25 US to get it delivered inter US. - about $50 NZ. Then the same to get it to NZ. Unless they pack it in a helmet box the way the US shops seem to so it doesn't get lost by US Post. By which time it will cost the same as the GDP of Equatorial Ghana. I'll wait till it actually gets here (about when the Sun runs out) and measures 1.2mm before I buy the other parts. In the meantime I'll count to three as I let the clutch out, and by the time I get a kit together I wont need it
