				Posts112
	  Yamaha Ty 250 Not Running Well At 3/4 - Full Throttletrialsmm replied to austin6728's topic in Yamaha On a bike that old and not ridden much, replace the crank seals, they must be hard and sucking air into combustion area.
	Use ONLY 100% synthetic coolant or the water pump will start leaking due to "cavitation" of the magnesium side cases not liking water. NEVER mix water with coolant or use 50/50 coolant. I know,,,,,learned the hard way. There should be a warning label attached to Beta bikes! mm
	As popular as trials is, why doesn't a company make die cast or plastic models of popular and vintage trials bike? I would buy them, would you? mick
	I noticed that ESPN was to air some World Outdoor Trials events, do you mean we might see this coverage in the USA? That would be to good to be true?
	So what will Toni Bou be riding next year?
	Look on the Ryan Young USA web site, he has a link to show how to install rim tape correctly. Good luck, you need to intall the valve stem first, then go from there. Most problems is air leaking around the stem and rim tape.
	I remember the hot setup was to shorten the swing arm 1 inch. Cut it near the front pivot.
	My '04 Rev3-250 and my '06 Rev3-200 did the same thing. Both bikes were used, I replaced the clutch side case, seals and bearings. I use Honda coolant and replace it often. NEVER dilute with water! The Beta dealer should sell you the parts at costs. Seems to be a common problem. I wonder if other bikes have the same problem?
	Keep tapping it lightly with a rubber mallet.
	From the pics I see posted the World outdoor rounds are going more and more "man made" sections? Are we running out of land? Will the outdoor sections just look like indoor events outside? I hope no one ever gets a serious injury. But I'm 'old school' and don't care much for the way indoor events have gotten so impossible looking, except for 2 or 3 riders. Too much like a circus act!
	  250cc Or 280cc For A Beginner ?trialsmm replied to dk_fire's topic in Trials Training And Technique GET A 200 Beta or a 125 Sherco,,,,,,,forget the 250 or larger! Unless you are a heavy weight:)
	Cavitation is the proper word to describe the problem, not corrosion. Thanks. I have noticed that most quality motorcycle coolants state; "50/50 cooland and de-ionized water to prevent cavitation".
	I was told by the Beta importer to use ONLY ELF 100% organic coolant to prevent corrosion. 50/50 was a no no. Anyone else heard of this?
