peterb Posted June 10, 2007 Share Posted June 10, 2007 I've also used ordinary car touch up spray paint for at least 20 years. Never used wire, no insulation tape and not even hair spray! Spray paint was good enough never to let a grip loose in the Scottish and never lets rain penetrate the seal. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
the pie man Posted June 10, 2007 Share Posted June 10, 2007 Pro Taper glue and lock wire, they will never move again. Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted June 11, 2007 Author Share Posted June 11, 2007 Thanks for the input guys. I took what i was already doing glue but added wire to the outside of the grip. As my handlebars seem to find the ground often and at high velocity i realized that i had a lot of dirt under the old grips. If i keep that dirt out of there i probably have more of a chance keeping them alive. The wire on the outside seems to have really helped this weekend. The other part is not crashing. I did to much of that trying to save a dab oops now i have crashed this weekend but i am pushing myself so its all good. Thanks again! Keep up the feed back. I am making a list here. --Biff Quote Link to comment Share on other sites More sharing options...
gii Posted June 11, 2007 Share Posted June 11, 2007 Hairspray is water soluble so if you've a hole somewhere in a grip it'll eventually get in there and dissolve it. Different grips have different characteristics on the bars, some are very tight and you can just blow them on with compressed air and they'll hang on for ever. I use pro-grip 737's and they are not a tight fit on the bars (they are a very soft rubber) Hair spray is too quick to dissolve though Windlestone has several cans now sadly redundant The 'best' way is double sided tape on the bars, a quick coat of petrol, then the grips slide on and are set hard by next morning. This is how golf pro's mount grips on clubs. The cheap way is a coat of aerosol paint on the bars and inside the grips then nudge 'em on. Just watch for drips on your trainers whilst you do this. Quote Link to comment Share on other sites More sharing options...
zippy Posted June 11, 2007 Share Posted June 11, 2007 A rather generous coating of the insides with Beer! You choose if I mean the grips or the stomach. Quote Link to comment Share on other sites More sharing options...
mil Posted June 12, 2007 Share Posted June 12, 2007 I've found that if you need to remove the grip for any reason, using glue or hairspray etc leaves the bars covered in gunk and the grips ruined. It is so easy to just pour in some petrol into the grip, swill it around and slide it on. The petrol evaporates and leaves the grip solid. No hassles, no residue. Then use some proper grip wire pliers to put the wire on- it twists the wire up and you don't have any erroneous strays to pierce your palm! Quote Link to comment Share on other sites More sharing options...
essex rider Posted June 12, 2007 Share Posted June 12, 2007 petrol takes too long to evaporate and can ruin some grips.. experienced this with cycle grips. Brake cleaning fluid evaporates much more quickly and as far as i can tell doesnt damage the grips, and doesnt leave nasty gluey stuff everywhere! plus the grips are solid in about 5mins Quote Link to comment Share on other sites More sharing options...
boofont Posted June 13, 2007 Share Posted June 13, 2007 Brake cleaning fluid evaporates much more quickly and as far as i can tell doesnt damage the grips, and doesnt leave nasty gluey stuff everywhere!plus the grips are solid in about 5mins Had to change a grip at the SSDT after day 1, I used brake cleaner and rode all week with no problems. Never used wire and never had a grip twist or move. I usually use evostick as its a rubber safe glue and is cheap. One tube will last a lifetime of sticking grips. Quote Link to comment Share on other sites More sharing options...
fedralseth666 Posted July 2, 2007 Share Posted July 2, 2007 vulcanising rubber from a puncture repair kit. try it, youll be amased! be sure to give it a good day or so to dry! Quote Link to comment Share on other sites More sharing options...
gasserrobinson Posted July 3, 2007 Share Posted July 3, 2007 bit of petrol in the bottom of the grip swill it around and then pour out the excess then that makes the rubber sticky :-) Quote Link to comment Share on other sites More sharing options...
ikb Posted July 3, 2007 Share Posted July 3, 2007 The secret is decent bar ends! I have made some that clamp the end of the grip to the bars / twist grip to minimise the chance of water or mud getting in when you fall off. I am very good at falling off!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
steve Posted July 8, 2007 Share Posted July 8, 2007 All your fancy sprays and glues all take time to set. The only thing I ever used on my own bikes and when preparing bikes for Crosser and Grimbo was compressed air. Blow the grips on, stick a bit of wire round incase the ends split. Job done - you can ride immediately. Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted July 13, 2007 Author Share Posted July 13, 2007 Ok here is what i am showing from your input so far glue protaper/renthal 5 blow them on dry or gas or brake clean 5 Hair spray L'Oreal or other expensive crap 3 spray paint 3 tube repair glue or vulcanized 3 tape with gas 2 Carpet or 3m spray adhesive 2 Hockey stick tape 1 beer 1 Ideally i consider a good cold beer a wonder do everything product and i am glad that it has made it into the list. We have about 10 suggestions of bar ends and wire. Personally i used grip glue and good bar ends along with a wire tie on the end to keep the gunk out and we have been solid for the past three weeks. Thanks for your input. Quote Link to comment Share on other sites More sharing options...
richzj Posted July 13, 2007 Share Posted July 13, 2007 don,t bother with grips, superglue palms of hands directly to bars Quote Link to comment Share on other sites More sharing options...
brian r Posted July 16, 2007 Share Posted July 16, 2007 Glad to see a good solid consensus here, like always. I've used lots of ways too. I like using friction tape and brake cleaner. Quote Link to comment Share on other sites More sharing options...
