gasgasrob Posted November 5, 2008 Share Posted November 5, 2008 not sure how much it is ? any one help me in my moment of thickness ? Quote Link to comment Share on other sites More sharing options...
dabomb Posted November 5, 2008 Share Posted November 5, 2008 there is loads of info on the web about fuel ratios,just google it!! Quote Link to comment Share on other sites More sharing options...
ksv Posted November 5, 2008 Share Posted November 5, 2008 to every litre of fuel add 12.5ml of oil. Quote Link to comment Share on other sites More sharing options...
anotherfive Posted November 5, 2008 Share Posted November 5, 2008 Just to make it different if your using 50:1 then divide a litre (1000ml) by 50+1 parts ie 51 so the amount of oil is 1/51th of a litre so 1000/51 = 19.6ml of oil. Easy to work out on a non drinking night!!! Quote Link to comment Share on other sites More sharing options...
sdc Posted November 5, 2008 Share Posted November 5, 2008 Your easiest way is to put 50ml of oil in 4 litres of petrol. Quote Link to comment Share on other sites More sharing options...
sam12 Posted November 5, 2008 Share Posted November 5, 2008 75ml of oil to 5 litres of fuel Quote Link to comment Share on other sites More sharing options...
gizza5 Posted November 5, 2008 Share Posted November 5, 2008 (edited) Try This So 62.5ml in a 5 litre can ............ KSV Well done Edited November 5, 2008 by GIZZA5 Quote Link to comment Share on other sites More sharing options...
ksv Posted November 5, 2008 Share Posted November 5, 2008 Well i did do a maths degree, so you would hope I could get this right. Anotherfive's method gives a ratio of 51:1 SDC's method gives 80:1 Sam12's method gives 66.6:1 Its quite simple but a lot of people get this wrong and are therefore putting the wrong amount of oil in their bikes. Just convert how many litres of fuel you have into ml (i.e x1000 for those that don't know) then divide this number by the ratio you want. So for 80:1 in 5 litres, use (5x1000)/80 = 62.5ml Simple Quote Link to comment Share on other sites More sharing options...
gjbiker Posted November 5, 2008 Share Posted November 5, 2008 Might as well jump on the band wagon here and kill some time? Should be at home right now but the glorious fog has dictated that I'll spend another night offshore Anyhooz, to work out ANY ratio (either with a good old fashioned pencil and paper or the calculator function on your mobile phone) try to remember this....... Using 80:1 as an example 100 divided by 80 = 1.25 (this is the percentage often seen on a little sticker near the tank, i.e 2% = 50:1) Using 5 litres as an example (turn litres into millilitres by multiplying by 1000) 5000 multiplied by 1.25% = 62.5 (remember to hit the % key or your answer will be out by 2 decimal places) Hey presto...........add 62.5 ml of oil to 5 litres of petrol and you'll have yourself a lovely 80:1 mix ! and while you're all here, if you haven't already voted, VOTE NOW Have a nice night GJ Quote Link to comment Share on other sites More sharing options...
slapshot 3 Posted November 5, 2008 Share Posted November 5, 2008 (edited) Might as well jump on the band wagon here and kill some time? Should be at home right now but the glorious fog has dictated that I'll spend another night offshore Anyhooz, to work out ANY ratio (either with a good old fashioned pencil and paper or the calculator function on your mobile phone) try to remember this....... Using 80:1 as an example 100 divided by 80 = 1.25 (this is the percentage often seen on a little sticker near the tank, i.e 2% = 50:1) Using 5 litres as an example (turn litres into millilitres by multiplying by 1000) 5000 multiplied by 1.25% = 62.5 (remember to hit the % key or your answer will be out by 2 decimal places) Hey presto...........add 62.5 ml of oil to 5 litres of petrol and you'll have yourself a lovely 80:1 mix ! and while you're all here, if you haven't already voted, VOTE NOW Have a nice night GJ Christ you must be bored Gav.... weather is crap right now onshore and offshore Edited November 5, 2008 by Slapshot 3 Quote Link to comment Share on other sites More sharing options...
ratman Posted November 5, 2008 Share Posted November 5, 2008 Hi all, lots of the oil bottles have the desired measuring system buit in , usually marked with different percentages on the side.. so as correctly stated 2% equals a mix of 50:1.. Quote Link to comment Share on other sites More sharing options...
swooshdave Posted November 5, 2008 Share Posted November 5, 2008 Why do math. It's HARD. Quote Link to comment Share on other sites More sharing options...
bigfoot Posted November 5, 2008 Share Posted November 5, 2008 I have a wonderful little spreadsheet that give all the mixtures in all common measurements. Unfortunately I too am stuck offshore in the North Sea and dont have access to it. If I remember when I get home I'll post a copy. Quote Link to comment Share on other sites More sharing options...
gasgasrob Posted November 5, 2008 Author Share Posted November 5, 2008 who needs a maths teacher when there is you lot out there cheers hopfully i wont seize the bike Quote Link to comment Share on other sites More sharing options...
tt5th Posted November 5, 2008 Share Posted November 5, 2008 I wrote a daft little program to help with that, you can download it from - http://www.johnholburn.co.uk/2StrokeOilMix.zip Unzip it somewhere and run the setup program, any hassles let me know. Runs in XP, not sure about vista. I can guarantee it has no virus's as I don't know how to write them! Hope thats useful to someone. Quote Link to comment Share on other sites More sharing options...
