bucks Posted November 25, 2013 Share Posted November 25, 2013 Hi I'm new to this I've just got a bets rev 3 250 2004 and dont no what oil mixture to do and what is the best oil to use thanks mark Quote Link to comment Share on other sites More sharing options...
gjbiker Posted November 25, 2013 Share Posted November 25, 2013 This might help you decide...... http://www.trialscen...h-oil-question/ ........as for the best oil to use - buy the best you can afford but even the cheap stuff will suffice. Remembering to add some to your fuel is the most important bit? Quote Link to comment Share on other sites More sharing options...
lewis cosgrove Posted November 25, 2013 Share Posted November 25, 2013 I think that most people mix it at 80:1, which is 62.5 ml to every 5 litres of petrol. It does say in the manual for my Sherco to run it at 50:1 which is OK but when using a trials bike as its meant to be 80:1 is more suited as it wont oil up the plug as much. However if you are planning on using it more like a trail bike more oil can never be a bad thing. Quote Link to comment Share on other sites More sharing options...
slapshot 3 Posted November 26, 2013 Share Posted November 26, 2013 Bucks 70:1 or 70ml per 5 litres, with unleaded. Give it a treat once in a while with a tank of superunleaded Quote Link to comment Share on other sites More sharing options...
dadof2 Posted December 6, 2013 Share Posted December 6, 2013 #3 since handbook says 50:1 and yet you think 80:1 is OK I presume by the same reasoning you would recommend ignoring the other manufacturers instructions and only putting 2/3 required oil in gearbox or your car sump? Quote Link to comment Share on other sites More sharing options...
rqbbq Posted December 7, 2013 Share Posted December 7, 2013 i run mine @66.1 and will only use putoline mx5 mx7 or motul 710 810 the higher numbers are the better quality of the 2 brands there which i use with the same mixture on my ec300s for racing. Dan. Quote Link to comment Share on other sites More sharing options...
lewis cosgrove Posted December 11, 2013 Share Posted December 11, 2013 #3 since handbook says 50:1 and yet you think 80:1 is OK I presume by the same reasoning you would recommend ignoring the other manufacturers instructions and only putting 2/3 required oil in gearbox or your car sump? http://www.trialscentral.com/forums/topic/17883-the-great-how-much-oil-question/ 80:1 is most popular for a reason . Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 11, 2013 Share Posted December 11, 2013 http://www.trialscen...h-oil-question/ 80:1 is most popular for a reason . Not very scientific though ? Quote Link to comment Share on other sites More sharing options...
taffe Posted December 11, 2013 Share Posted December 11, 2013 Since I started mixing 80.1 using premium unleaded and expert oils in my Sherco, I found it easier to use the same mix in the ride on lawnmower, the push lawnmower and my chainsaw. All have worked well for years. I don't like the idea of using 50:1 with a muffler that cant be repacked......think Sherco. I made my muffler repackable but will still stick to 80:1 whilst using good fuel and oils. Riding in 35deg heat is a good test, been doing it for a couple of years now, so when it comes to refreshing the top end [soon] I'll see the how things have gone. Cheers Taff Quote Link to comment Share on other sites More sharing options...
dadof2 Posted December 13, 2013 Share Posted December 13, 2013 A poll is not only unscientific, lots of germans voted for Hitler but that turned out to be unwise. The words Lemmings and cliff spring to mind. As I said previously if you think nearly halfing the manufacturers recomendations for the cylinder lube is a good idea, why not cut the gearbox oil by the same amount? A correctly carburated bike will not oil the plug at 20:1 fuel : oil, let alone 50:1 Quote Link to comment Share on other sites More sharing options...
guys Posted December 13, 2013 Share Posted December 13, 2013 I used to run my 315R at 80/1 (and run my GasGas the same) and when I removed the barrel it was very well oiled. Your comparison with gearbox oil makes no sense. And here's another well informed opinion: http://www.gasgas.com/Pages/Technical/measuring-pre-mix.html 1 Quote Link to comment Share on other sites More sharing options...
zippy Posted December 13, 2013 Share Posted December 13, 2013 Quote Link to comment Share on other sites More sharing options...
guys Posted December 13, 2013 Share Posted December 13, 2013 Quote Link to comment Share on other sites More sharing options...
dadof2 Posted December 14, 2013 Share Posted December 14, 2013 I have quite a bit of respect for Jon Stoodley - but it does not mean he is always right nor do other tuners always agree with what he says. The comment about gearbox makes as much sense as ignoring manufacturers advice. Why spend a lot og £££s on a bike then risk damaging it due to lack of oil? Some recent research has shown that at 50:1 a good / top quality synthetic oil starts failing to protect piston rings at about 12,500 RPM so in theory at typical trials bike revs an 80:1 mix should be fine. But then add in some variables like water droplets, a bit of engine wear, poor carburation, variable petrol quality etc and 80:1 looks nowhere near a safe bet. I stripped a 2010 gasgas recently (gearbox fault). Run on Motul at 75:1. Rings, piston, barrel all damp with oil, some wear but still within tolerance. Quite a bit of oil in the bottom end but little end far too dry for my liking. The piston, bottom end and even the reeds were covered in dark brown deposits caused by blowby. It would seem 75:1 was providing adequate lubrication but nowhere near enough piston cooling and ring sealing. There is a serious drawback to advising 80:1 - You do't know what sort of use the bike is going to have, I have seen a beginner stuck in a peat bog rev the bike till the exhaust glowed dull red just outside the barrel. Try that at 80:1 and see how long the piston lasts. 1 Quote Link to comment Share on other sites More sharing options...
copemech Posted December 15, 2013 Share Posted December 15, 2013 I have quite a bit of respect for Jon Stoodley - but it does not mean he is always right nor do other tuners always agree with what he says. The comment about gearbox makes as much sense as ignoring manufacturers advice. Why spend a lot og £££s on a bike then risk damaging it due to lack of oil? Some recent research has shown that at 50:1 a good / top quality synthetic oil starts failing to protect piston rings at about 12,500 RPM so in theory at typical trials bike revs an 80:1 mix should be fine. But then add in some variables like water droplets, a bit of engine wear, poor carburation, variable petrol quality etc and 80:1 looks nowhere near a safe bet. I stripped a 2010 gasgas recently (gearbox fault). Run on Motul at 75:1. Rings, piston, barrel all damp with oil, some wear but still within tolerance. Quite a bit of oil in the bottom end but little end far too dry for my liking. The piston, bottom end and even the reeds were covered in dark brown deposits caused by blowby. It would seem 75:1 was providing adequate lubrication but nowhere near enough piston cooling and ring sealing. There is a serious drawback to advising 80:1 - You do't know what sort of use the bike is going to have, I have seen a beginner stuck in a peat bog rev the bike till the exhaust glowed dull red just outside the barrel. Try that at 80:1 and see how long the piston lasts. Although I do respect your opinion and what you are stating, this last example would not be average use by normal folke. I do believe the P.O.U. must be kept in mind. For putting about and occasional revving, I feel safe with 80:1. For harder running or a road trial at higher(moderate) revs for long duration, I may go 50:1, and for extreme usage as in idiot use, well this may require a bit more such as 36:1 or so, thus I choose to stick with what works for my average use. And that is not extreme, thus the ratio. Quote Link to comment Share on other sites More sharing options...
